Question about ASUS P6T7 WS Supercomputer Core i7 / Intel X58/ DDR3/ Crossfirex & 3-Way SLI/ A&2GL/ Ceb Motherboard
HOW DO THE CONNECTIONS TO THE SCREEN ON X38C LAPTOP CONNECT? HAD TO TAKE APART AS SD CARD GOT JAMMED. NOW BOOTING OK BUT NO OUTPUT ON SCREEN? HELP PLS! EVEN A LITTLE DIAGRAM TO MAKE SURE ITS ALL PUT TOGETHER OK WOULD BE A GREAT HELP.
  • Harleen Nash May 11, 2010
    1. Do you have a hdmi connector to the Monitor or VGA ( usually blue) HDMI is usually (white).? 2. Did you re installed the new mother boards software to the hard drive after the disassembly of the PC> 3. With your new mother board should have been an installation manual. 4. The manufacturers site will have a diagram of the board layout usually in PDF format and is downloadable. 5. If you have another PC connected to your home network you can download and print this information out.
    President:
  • 1,768 Answers
From reading your issue again I gather that when you dismantled the laptop unit you inadvertently disconnected the video card ribbon cable or connector an therefore no video screen.
Posted on Feb 04, 2010
Where is the sd card slot on acer laptop
Usually it is located in front of the laptop, under the touch screen mouse. Also check your laptops specifications, maybe it does not have SD connector.
Apr 07, 2014 | Acer Aspire 5736z 4460 Laptop
Screen is white with black vertical lines upon booting up. I can't get beyond this screen.
The video card (built-in on the motherboard) maybe faulty or the LCD screen is faulty.
Connect an external monitor to the video port of your laptop, power up the monitor first then boot up your laptop. If the video card id OK then the laptop will automatically divert the video to the external monitor. Then the problem is a faulty LCD screen.
If the external monitor also displays black vertical lines then you have a faulty video card and since it is part of the motherboard it is impossible to fix.
Feb 11, 2012 | Acer Aspire One Netbook 8.9" Notebook
Laptop screen has vertical lines of garbage 3/4" wide about 3/4" apart. sound system starts making choppy noise after only few minutes powered up. Trying to fix this laptop for a friend - I'm a desktop...
Connect an external monitor to the VGA-output port on the laptop, to see if the video-effects are being caused by the video-card, or by a damaged "internal" LCD screen on the laptop.
Take any genuine Microsoft Windows XP/Vista/7 CD/DVD disk, and "boot" from it. Do the vertical lines appear when booting? If so, you have a hardware problem. If not, then only the currently-installed version of Windows is messing-up your display.
If all else fails, backup all the user's files to an external device, reformat the disk-drive, and reinstall Windows, to see if it's a messed-up version of Windows that is causing the symptoms.
Jul 03, 2010 | Dell Inspiron 9400 Notebook
My monitor comes on for about three seconds when I turn the computer or the monitor off/on and then it fades to black. It looks like the computer is booting up fine when I can briefly see the screen but...
Connect the monitor to the "video-output" port on your laptop, to see if the monitor is working correctly.
You make have to tell the laptop to send the video-output to "both" the internal LCD screen and the external monitor.
If it works, then your monitor is OK.
Restart your computer, and keep tapping the F8 key, until you get a menu of startup items. Choose the 'VGA' startup option, to select the "minimal" device-drivers for your video-card. With the "minimal" drivers, your monitor should still be working.
May 31, 2010 | Computers & Internet
WHEN I TURN ON THE WIRELESS THE LAPTOP SHUTS DOWN
Most likely you have a bad driver. Try connecting your machine directly to the wired network. Go to your manufacturer and download the latest drivers.
If your machine does not have a hardwired port, you can bring the drivers with a flash from another machine.
Also, you might try booting in safe mode. After booting, press F8 until you get asked for what you want to do. Try booting in safe mode with networking. If you are able to boot here, you know that the wireless card itself is ok. So, get the latest drivers.
Hope that helps.
May 25, 2010 | JVC MPXV841US Notebook
My laptop does not realize i have inserted my SD card.
Try restarting your computer before putting the card in. If it doesn't how up after a restart when you are in My Computer try hitting F5 on your keyboard to manually refresh the screen. It's possible there could be dust in the card slot but the connections are usually self cleaning. If this doesn't help try the card in another computer or if you can hook the camera directly to the computer eith the appropriate cord.
Jun 19, 2009 | Electronics - Others
Laptop not booting up
Ok it's probably not the battery. Try taking the battery out and run it just by the cord, if it works, than return the battery and get a genuine HP one. If it is a genuine one,save it.If fails i'ts the power board or even worse, the motherboard. Now it could be a CPU overheat, look up on google "taking apart HP zT1260". and clean fan and mainboard. if that fails, it's the video card, again look and take apart and see if the graphics card is removable, if it is replace it, if not. You got ripped off and he was bluffing :( Trust me I'm a computer IT worker. Try returning it, if that fails, tell people that he shouldn't be a repuatable seller. Good Luck
Nov 29, 2008 | HP Computers & Internet
No data output on visual o/p
onboard video or a seperate card? try putting in a video card besides the one that is in there. if the previous one is removeable pull it out and just try booting with another test card. it may be that the video cardis shot. one of the first things the bios looks for is where it should output video so you can see whats going on. if it cant find any video. it will halt the boot. try that and get back to me. if it doesnt help. i'll be glad to see what else i can think of
May 21, 2008 | Intel Motherboard
S-Video Output and SD Memory
S-Video would allow you to run your laptop onto a TV, you would have to buy an S-video cable and have a tv or box that is s-video compatible or buy a converter. You would connect the cables to the tv from laptop and Using th <FN> and <F5> toggle between lcd/external/both
SD media card reader just reads SD card you have e.g. camera memory cards, data transfer etc.
sd card is inserted pin side down and pushed in till it clicks in place
Apr 21, 2008 | Computers & Internet
Installing a SD wi-fi
First remove the SD Card, then remove the drivers for the SD card. do a soft reset. install the driver for the card. go to settings, system, then remove software and check tat the software shows up. Oh by the wy make sure you have the HP SDIO fix install first. ok make sure that bluethoot is off. Install the SD Card. now go to settings, then connections tap on connections. tap the Advanced tab, tap the Network Card. you should see the SD Card listed. tap the Card. the next screen ask if you want to set the IP address or have the server assign the IP. I leave it at the default and let the server assign the IP.
Tap ok 3 time that should close everything. and you should be set. if you have a wi-fi setup you need to tap on start then programs, then tap on "WLAN" this program is what you use to check your signal strenght and check if you are getting a signal from your wi-fi. Once the signal strenght is strong enough you will see that an IP address will be asigned and you will be asked if you want to connect.
I hope this Helps
Oct 17, 2007 | HP iPAQ H2210 Pocket PC
ASUS P6T7 WS Supercomputer Core i7 / Intel X58/ DDR3/ Crossfirex & 3-Way SLI/ A&2GL/ Ceb Motherboard Logo
90 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
