Question about Dryers
Whirlpool gas dryer Model #WGD5530SQ0 not heating properly
I just changed timer due to burner only running for 3 minutes then not working again but glow comes on for a few seconds. After installing new timer ran dryer for 20 minutes no problems put a load in it and now it does the same thing as before. what else could it be? Thanks. PS timer was a suggestion by Whirlpool.
  • 39 Answers
If your dryer heats when you first turn it on and after a few minutes it does'nt. check the ignitor to see if it is glowing. It should glow bright then you will hear a click and the burner will light. If the ignitor glows bright but you hear a click but no flame and if you watch this for several minutes and this process continues of glow then glow goes out no flame, then you have a bad burner coil. There are 2 black solenoids sitting on top of gas valve. One of them is shorting out after it warms up. Replace both solenoids. You can usually get them as a kit from parts store.
Posted on Feb 04, 2010
Testimonial: "Will check this out. Thanks!"
I have a whirlpool gold gas dryer model#GGQ8858JT1. When I push the start button the dryer starts and spins but the heat does not come o
does the igniter glow? If not check for 110 volts at igniter .
Check for 110 volts at gas valve if no volts check hi limit thermostat , operating thermostat, safety switch on motor,
the coils on the valve & the timer contacts that feed the voltage to the burner.
Mar 02, 2014 | Whirlpool LGV4634JQ Gas Dryer
Maytag DG410 gas dryer-no flame, no heat. I replaced the ignitor - that apparently isn't the problem. Other ideas?
Motor runs, but main burner will not ignite
1.heat switch set wrong---correct switch setting
2.defective timer or timer circuit---check timer wiring--replace timer motor or switch as needed
3.defective centrifugal switch in motor---clean switch or replace as needed
4.gas supply valve closed----open gas valve
5.inoperative solenoid coil---test coil for open circuit & the voltage to it
Pilot burner goes out
1.insufficient gas supply---- low gas pressure or clogged pilot filter or partially closed gas valve
2.carbon deposit on thermocouple tube---clean tube & check pilot burner for proper combustion
3.improperly adjusted pilot flame--adjust pilot flame until faint yellow tip begins to appear
4.faulty ignition or reset valve or thermocouple---replace
Clothes not drying, but dryer runs & heats
1.defective operating thermostat---test thermostat, replace if defective
2.fan or it's pulley loose on shaft---tighten set screw
3.incorrect heat or timer settings---reset timer
4.clothes to wet when placed in dryer----wring out or extract water from clothes before placing in dryer
5.clogged lint screen or duct (little air motion)---clean out lint screen & duct
Sep 22, 2011 | Maytag PYG4500A Gas Dryer
I have an Amana Designer Series Gas Dryer. It worked fine for more than 10 years. Suddenly, yesterday it still ran, but there was no heat. I opened the bottom panel while it was running, and...
Sep 22, 2011 | Amana ALG331RAW Gas Dryer
Dryer timer won't shut off at end of cycle. Dryer runs, but no heat. It is a Whirlpool model number LGR4634JQ2.
Since you say that the dryer runs but have no heat, plus the timer won't shut off the odds are the timer is bad. The timer would tell the burner when to be on and when to shut down.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=265840&diagram_id=28265980#d28265980
21 partimage.aspx?imgid=z3bqljbfahrfndg1njc5my9mufcvc290b2hwdhjhcc8%3d
Enlarge Photo
Timer
Part Number: AP3037407 made by WHIRLPOOL $91.55 In Stock
Order now and it will ship Today
Jun 09, 2011 | Dryers
I have a Whirlpool gas dryer model #WGD5530SQ0 that will not start when the button is pushed, It has power, the light is on inside. Whats my problem?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 24, 2010 | Dryers
Whirlpool Gas Dryer Model # LGR7646JQ0. Bought it used, warranty useless since the shop I got it from went out of business. Everything works fine. The drum turns, the timer works but the thing doesn't heat...
Hi and welcome to FixYa. I am Kelly.
Your power for the burner assy goes on a series circuit from the timer to the high-limit thermostat to the operating thermostat to the thermal fuse to the gas burner assy, thru the motor centrifugal switch to the door switch. EACH of these must be functioning for the burner to light.
This manual will help with some of the how to do it as far as component access, removal and replacement of parts.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/4829abde74a34d7f85256ab000620794
Also this link has loads of information on what to check.
http://fixitnow.com/wp/2006/09/19/how-to-check-the-burner-components-in-a-gas-dryer/
The 3 most common failures are
Igniter:
Gas Valve
High Limit Thermostat
Compnents : http://fixitnow.com/appliantology/gasdryer.htm
Note the LINKS!
Here is a 9 min video that pretty much covers everything you need to check: http://www.howcast.com/videos/371390-How-To-Troubleshoot-a-Gas-Dryer-That-Wont-Heat
Thanks fo choosing FixYa.
Kelly
The
Aug 20, 2010 | Whirlpool LGB6300 Gas Dryer
Have Whirlpool Model # LGB6200PQO dryer runs but does nut dry. Burner kicks on with fire on gas dryer but after about 5 min kicks off after a few minutes the igniter glows on but no fire then kicks off...
The moister sensor can be bad or good. If the exhaust tubes are clogged with any lint build upo the sensor is working putting the burner into check
Jul 28, 2010 | Whirlpool Dryers
Gas dryer not heating properly, burner ignites at start up, then runs a little while, then wont start again
The gas valve coils are getting weak. Replace the gas valve coils.
Go to repairclinic. com and out in your model number for a good price.
Jan 06, 2010 | Whirlpool Dryers
Dryers Logo
576 people viewed this question
Top Dryers Experts
