Question about Canon PIXMA MX300 All-in-One Printer
How do i disassemble canon pixma mx300 to clean rollers?
dmbgo
  • 58 Answers
SOURCE: Canon Pixma MX310: misfeeds
Hi Paper misfeeds are normally caused by something obstructing the paper path. Look really carefully both above and below the path that the paper takes through the printer. The jammed paper itself can give you a clue about which side the obstruction is on, there wiil often be some sign, such as a bent corner on the page etc. Also check the sliding guides that keep the paper straight, they should be slid in until they are a snug fit with the paper, but not so tight that they stop it from feeding
Posted on Jun 21, 2009
  • 52 Answers
SOURCE: canon pixma mx300 drivers for vista
hi i am a certified Canon4.gif repair tech for this printer. if you follow the link below this will take you to Canons support site where you can download the software for your printer. hope this helps
http://www.usa.canon.com/consumer/controller?act=DownloadIndexAct
Posted on Jan 09, 2008
SOURCE: canon pixma mx 300 won't send or receive fax
how do u fix the fax to fax and not go on auto redial
Posted on Feb 01, 2009
SOURCE: Canon Pixma MX300, error code 5100---won't print
For me cleaning the encoder strip fixed it. Needed to clean every little bit of it, even the area back where the printhead parks on the far right.
Posted on Aug 06, 2009
pineworks
  • 4041 Answers
SOURCE: Canon Pixma MX300 - error code 5B00 - check
Try it works for most Canon
Hi you can try
Solution:
  1. Turn on the machine
  2. Press MENU
  3. Press SCAN COPY SCAN to enter service mode
  4. USE > to got to NVRAM ACCESS
  5. Set ABS-M LEVEL to 0
  6. Set ABS-P LEVEL to 0
  7. Press STOP to EXIT
All The Best: Pineworks
Posted on Jan 25, 2010
Canon Pixma MX300 ink absorber cleaning video ; how can I clean the ink absorber?
When the ink absorber pads are full, you can easily remove and clean them on most Canon printers. Fill a large bowl with warm, soapy water and set it aside. Put on the rubber gloves. Open the ink cartridge compartment.
How to Clean a Canon Ink Absorber ' Chron.com
smallbusiness.chron.com/clean-canon-ink-absorber-57609.html https://www.google.co.uk/webhp?sourceid=chrome-instant&rlz=1C1CHBD_en-GBGB719GB719&ion=1&espv=2&ie=UTF-8#q=Canon+Pixma+MX300+ink+absorber+clean
Nov 26, 2016 | Canon Office Equipment & Supplies
Canon Pixma MX300 printer had a paper jam. I took out the paper, and it was all there with no missing parts. It continues to say there is a paper jam - there appears to be no reason for the jam. I...
Try checking that a foreign object is in the paper feed rollers- do this by inserting a thin piece of plastic about 2 cm wide through the rollers from the paper exit side. Plastic like that from a shirt box (about 2cm wide by 20 cm long and 1 mm thick works well. I have solved this problem many times with my mx300 and it clears out objects which have droppped into the paper feed, such as Pens , yes pens. and paper clips etc which are otherwise hard to detect on this printer.
Sep 25, 2010 | Canon PIXMA MX300 All-in-One Printer
Canon mx300 ink absorber full
my canon mx300 printer box flags that the ink absorber is full and the yellow alarm light comes on. i press o.k. and i can continue to print without a problem. can anyone suggest how i address the ink absorber - replaceable, cleanable, etc.?
thanks for your help
alan
May 13, 2010 | Canon PIXMA MX310 All-In-One Printer
Canon mx300 that had a spill on the control panel
Hi there
Why not try spraying WD-40 on it first this will not harm any thing on the printer.
Feb 27, 2010 | Canon PIXMA MX300 All-in-One Printer
Cant print using Canon Pixma MX300
Hi
1. Disconnect the power cable
2. Connect it while holding down the power button
3. With the power button still down, press twice the "Cancel/Stop" red button
4. Release the power button
5. The prints turns into a kind of factory mode...(wait for about 10 seconds, utile it says "Idle")
6. Press the ">" (next to the "OK" button) once.” Shipping Mode 3"
7. Press the "OK" button.
8. Press "OK" again for "Without cleaning"
9. A test page will print.
10. Open the cover, like you are about to change the cartridges.
11. Disconnect the power cable again.
12. Take out both cartridges.
13. Close the cover.
14. Connect the power cable once again.
15. Turn the printer on.
16. Now just put the cartridges back...
Or try this
Here the Solution to reset the ink level for Canon Pixma MX300 follow this steps to reset the ink level in your canon MX300.
  1. Switch off the Canon MX300 and disconnect the power cable.
  2. While press and hold the power button, Connect the power cable to electric socket.
  3. While pressing the power button, press the “Cancel/Stop” button (red button).
  4. Now release the power button and the printer turns into a kind of factory mode. Wait for 10 seconds until it says “idle”.
  5. Press “>” (next button) once “Shipping Mode 3′ then Press the “OK” button. Press “OK” again for “without cleaning”.
  6. A test page will print.
  7. Open the cover, like you are about to change the cartridges.
  8. Disconnect the power cable again without switch off the printer.
  9. Take out the both cartridges.
  10. Close the cover.
  11. Connect the power cable and turn on the printer.
  12. Now just put the cartridges back and the ink level in the canon Pixma MX300 have full again.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
Sep 08, 2009 | Canon PIXMA MX300 All-in-One Printer
Canon Pixma mx300 printer has paper jam message.
Canon Pixma MX300
- new cartrige for Black ink
- can scan
- can photocopy documents
BUT can't print documents from my MacBook eventhough the paper feeds and goes out at the other side
Aug 10, 2009 | Canon PIXMA MX300 All-in-One Printer
Canon Pixma MX300 REG SERVICE SOON
There is no service info for this machine, during the warranty period Canon will exchange the whole printer, after that you just toss it and buy new...
Jun 25, 2009 | Canon PIXMA MX300 All-in-One Printer
Canon PIXMA MX300 All-in-One Printer Logo
1,065 people viewed this question
old marine
old marine
