Question about Panasonic DP-C264 Copier
Getting Machine Error E04-14
I'm getting this error code. I've already checked the fan, and all seems well with it. I'd like to proceed with "EC PWB connector CN510" fix proposed on this site, but I don't know what those things are or where they are on my Panasonic DP-C322 machine. Can somebody please help? Thanks.
  • Panasonic Master
  • 6,161 Answers
Recommended you take it out and blow fan with can air. If the fan is good then you will need to replace the circuit board:( mite order a new fan first and connected then you will know if you have to order the board unless you fill confident to locate the main board and then locate the connector on it. unless some one has unpluged the connector doubt it is lose or bent pin inside it. Best to ask for a pansonic servive provider.
Posted on Feb 21, 2010
IM GETTING AN ERROR CODE C4-00 ON MY SHARP MX2314N. I HAVE CHANGED BOARDS, STILL NOT FIXED. HOW CAN I FIX THIS ERROR?
mx 2314n error code c4-00. You could have one or more of these bad-PTC unit, Secondary transfer PWB, PCU PWB, a connector or harness connection problem.
Apr 11, 2017 | Sharp Office Equipment & Supplies
How do I fix the error code 'U2-30'on my Sharp MX 2300N color copier?
please reset the machine by eject the power and data cable for a one minute and also re installer the printer driver
Nov 22, 2014 | Sharp MX-2300N Color Copier
EC error code meaning
Hello friend, thank you for your inquiry!
I understand that you are getting an "EC" error code on your Frigidaire air conditioner. However, it appears "EC" is an invalid error code. It is possible that the error code is missing characters? I show that the error code "ES" or "CS" is valid. In the meantime, I suggest resetting your air conditioner. You can do this by flipping the household circuit breaker for roughly ten minutes. If resetting the power does not correct the issue, could you please inform me of the new error code or if your air conditioner continues to display "EC". I look forward to assisting you. -Matt
Aug 28, 2014 | Frigidaire Heating & Cooling
MX 351U SHOWING E7-90 ERROR CODE WHAT THE SOLUTION
This is a PCU PCB Communication error. 9 times out of ten it will reset by simply switching the machine off and then on again. If the problem persists here is the section from the manual that describes the possible causes and remedies.
E7-90
MFP - PCU PWB communication error
Trouble content
Detail
MFP
Cause
PCU PWB connector connection trouble. PCU PWB - MFP PWB connection trouble. PCU PWB trouble.
MFP PWB trouble.
Mother board trouble.
Check & Remedy
Check connection of the PCU PWB, the MFP PWB, and the mother board.
Check the ground.
Replace the PCU PWB.
Replace the MFP PWB. Replace the mother board.
I hope this helps
Good Luck
Follow me on Twitter @CDOS_Service
Jan 14, 2014 | Sharp Office Equipment & Supplies
We are having xerox 1038 model usa made . we are getting the error u6 when we switch on our machine . so plz suggest us the best possible way to fix up the problem ...`````
U6-1 The main PWB failed checking the ROM.
Shut down and restart the copier. If it appears again U6-1, replace the main PWB.
U6-2 The main PWB failed checking the RAM.
Shut down and restart the copier. If it appears again U6-2, replace the main PWB.
U6-3 and U6-4 The main PWB failed to check the battery MNV (U6-3). Or the main PWB does not properly initialize the NVM (U6-4).
Follow the procedure in the development of memory to initialize the NVM, code 20-96. Shut down and restart the copier.
Jul 20, 2011 | Office Equipment & Supplies
Getting error code c5354 . bizhup c352
Hi the issue you are getting with error c5354 is an issue with the ozone ventilation fan motors failure to turn
check the connector of the motor make sure the connection is good check the fan for possible overload and correct test operation of motor m18
if you change motor and still have problem change pwb-mc
Jan 20, 2011 | Minolta BIZHUBC351 Color Copier
KYOCERA PRINTER GETTING THE FOLLOWING ERROR CODE: SERVICE CALL 7410:0078596
Drum unit non- installing error
The drum unit is not installed or not
installed properly.
The drum PWB EEPROM does not communicate
normally.
1. Install the drum unit
2. Check the connection of connectors drum
PWB (YC1) and connect-L PWB (YC3).
3. Replace the drum unit
4. Replace the engine PWB
Mar 03, 2010 | Kyocera FS-4000DN Laser Printer
I have machine error E04-14 on display
E04-14 is the Fuser IH Driver fan rotation.
Fan is disconnected, or defective, EC PWB connector CN510 is disconnected, or EC PWB is defective. If you have replaced the fuser recently on a PM call, you may have not seated the connector back in properly, or in some cases there may even be something caught in the fan itself. That is a very solid machine, so I would look for the obvious before I start looking to board problems.
Oct 27, 2009 | Panasonic DP-C264 Copier
DE code on WM0642HW TROMM washing machine We've been getting this error code on our washing machine for some time. The code is coming up quite frequently now. It stops the cycle so the load is not...
HI, this is a Door Open Error.
Possible Causes are..-
* Door not all the way closed
* Loose electrical connections at door switch and pwb assembly(Control Board)
* Door switch assembly is out of order(Miss aligned)
* Gasket on door may be creased in
Most common issue here will be a defective door lock switch. check all causes before replacing the switch.
Jul 11, 2009 | LG Washing Machines
I get error code c-0046 and now machine will not work. What do I do?
C0046: Fusing Cooling Fan Motor /1’s failure to turn
Relevant Electrical Parts
Suction Fan Motor (M12) Control Board (PWB-MC)
Step Action
WIRING DIAGRAM
Control Signal
Location
(Electrical
Component)
Check the connector of motor for proper connection
and correct as necessary.
Check the fan for possible overload and correct as
necessary.
M12 operation check PWB-MC PJ18MC-9 (LOCK)
PWB-MC PJ18MC-7 (REM)
6-P
4 Change PWB-MC — —
Fusing Cooling Fan Motor/1 (M9) DC Power Supply (PU1)
Step Action
WIRING DIAGRAM
Control Signal
Location
(Electrical
Component)
necessary.
3 M9 operation check PU1 PJ17PU1-5 (LOCK) 2-K
4 Change PU-1 —
Jun 05, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Panasonic DP-C264 Copier Logo
324 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
