Question about Xerox DocuColor 12 Color Copier
I need help with xerox.
Xerox majestic 5760, which has error code of 08-300. Running single color ( say black) jams going into, but before getting into fuser rollers. Multicolor mode passes fuser entrance 1 time and then stops with error code 08-300. This machin is in my home and gets little use. This problem just started and happens every cycle. Please help. Thank you.
  • Gary Lassiter
    Gary Lassiter Feb 21, 2008
    Thanks for the help Mr. Tryit. I have not done anything to this unit. I am not very familiar with color copiers, but have years of experience on black and white models back in the 80's and 90's. This unit the paper attaches to the drum in order to put the 4 colors onto page. The paper in new with no wrinkles , not refurbed paper, nothing like that. Doesn't appear to be an actual jam. Seems like whatever is causing error 08-300 is stopping the machine, no jam. I have cheated the door and watched paper coming off of drum, no hesitation. Paper does not get into fuser rollers but does pass a photosensor. This sensor may be bad? Sensor plug is J147. The trasfer/seperation coronas look good, no arcing or traces of that.Pick off pawl from drum to fuser is working. Again thanks for help.
  • Gary Lassiter
    Mr. Tryit, just reread your post. There is image on paper and it is aligned correctly. You mentioned resetting the NVM? What or how is this accomplished? In order to clear the error 080-300, machine has to be turned off and back on.
    President:
  • 2,072 Answers
It really sounds like there is a sensor that is hanging up.
Or if its an optical sensor its dirty.
Leave the machine off for a while and inspect the fuser area for actuators in the paper path.
You may have a spring off of on of those sensor assemblys or it is hanging up on a cover.
That sounds like what you are describing since you can make one color copy.
Also, make sure your paper size settings are correct. If you have the setting different from the actual paper size in the machine, it will shut off with more or less a false jam due to the machine expecting a size paper and the paper path sensors do not see that size as the machine is running.
Posted on Feb 21, 2008
  • 2 more comments
  • Rick Kasper Feb 21, 2008
    Fault code 8300 is a transfer/fuser drawer fault. Is the transfer seated properly, did you look at all the drives, cheat the interlocks and watch the paper run across the transport for stalling?
    Reset the NVM for corruption clearance? I have no idea what you have done.
    Is the paper damaged? Corners folded? Or just stopping undamaged on in the transfer fuser area?
    Is there any noticible stuttering as its passing through the paper path?
    Is there an image on the paper? Is the transfer arching? Lots of possibilities.
    Seems to be a sensor issue, yes. But as you know, it would have to not be 100 percent failed because you couldn't clear the jam if it was.
    It's been several years since I worked on that family and something obvious is escaping me.
    Still seems to me a sensor has or is failing since there is no damage to the paper, and you see no eratic paper movement.
    Only thought is are you 100 percent sure the fuser is driving correctly. Not a bad pressure roll bearing or the heat roll is actually slipping inside a bushing? Good one..
    Color paper paths are identical to B&W paper paths.
    Here is a procedure. but the tool you most likely
    Perform the following Check to ensure proper CTR Drum Assembly alignment, which will allow for a more efficient transfer of image and transport of paper.
    NOTE: A CTR Alignment Shaft (P/N 6E58300) is required to perform this procedure.
    Check
    1. Switch off the power and disconnect the Power Cord.
    2. Open the front door and pull out the CTR Assembly (PL 7.1).
    3. Remove Knobs A, B, and C and the CTR Cover (PL 7.2).
    NOTE: If there is difficulty inserting the Alignment Shaft in step 4a / 4b of this procedure, or there is a problem with optimizing for mottle, it will be necessary to remove the CTR Film (REP 7.2.1) and realign the Front and Rear Rollers of the CTR Drum Assembly by performing the Alignment Procedure that is listed on the next page.
    4a. For the 5760 / 5765 (7 holes), insert the Alignment shaft and:
    1. Rotate the CTR to align the 7 positioning holes.
    2. Insert the Shaft in the round hole in the CTR Frame that aligns with the oval hole in the front of the CTR Drum Assembly. Continue inserting the Shaft through the Front Roller, the Drum Assembly Frame, the Rear Roller, and through the rear of the CTR Frame. (Figure 1) on attached file.
    NOTE: If the shaft cannot be fully inserted, proceed to the Alignment Procedure.
    4b. For the 5790 (4 holes) insert the Alignment shaft and:
    1. Rotate the CTR to align the 4 positioning holes.
    2. Insert the Shaft over the top of the front of the CTR Frame, and through the oval hole in the front CTR Drum Assembly. Continue inserting the Shaft through the Front Roller, the Drum Assembly Frame, the Rear Roller, and butt it up to the rear of the CTR Frame. The shaft must remain in contact with the CTR Frame and CTR Drum Assembly throughout the procedure. (Figure 2)
    5. If the shaft inserts easily, then The CTR Rollers and the CTR Inner Frame are in proper alignment and are not the cause of the machines problems.
    Alignment Procedure
    1. Remove the TC Baffle Assembly. (REP 7.9.4)
    2. Remove the CTR Film. (REP 7.2.1)
    3. Loosen 7 screws by 1/2 turns:
    a. 3 in the Front Roller marked with red. (re-position the CTR as needed with the Cam handle)
    b. 2 in the front collar (marked with white)
    c. 2 in the rear collar (1 must be accessed through the TC rail (PL 7.6) with a small shaft phillips head screwdriver).
    (NOTE: You must remove a ground strap for 5790 only)
    4. Loosen the 2 screws at each end of the Tie Bar. (PL 7.6)
    5. With the CTR in the "open" position, carefully insert the Alignment Shaft through the holes as shown in the following figures and continue until the shaft has been inserted all the way to the rear of the CTR Frame.
    6. Tighten all the accessible screws previously loosened, including those on the Tie Bar. It will be possible to access only 1 of the Front Roller screws and 1 of the rear collar screws at this point. With all accessible screws firmly tightened, gently withdraw the alignment shaft and reposition the CTR as needed to tighten the remaining 2 Front Roller screws and the last rear collar screw.
    7. Be sure the Alignment Shaft can be inserted and removed easily. Return to step 4 of the Alignment Procedure if needed.
    8. Reinstall or replace the CTR Film as appropriate.
    9. Run DC928 (TR0), and check/perform the geometric adjustments as needed. (IQ 3.2.3 Setup for Geometric Checkout for TR0, Ros Scan Timing, and CTR Tacking only)
    10. Optimize the Transfer Blade for mottle. (IQ Defect Sample #14 and perform the corrective action)
    NOTE: Save the Alignment Shaft. There may be a need to align the CTR Frame in the future. Be sure to store the shaft in a place that it will not be bent.
    do not have.
Error code 7-402
Error codes 7-401 to 7-404 are life end for the tray rollers. If no jamming probs then enter diags mode (Back and'i' buttons and switch on) scroll down to NVRAM access and select. find CRU counters and select, clear each tray counter and then exit.
Jun 01, 2009 | Xerox Phaser 7750DN Laser Printer
Phaser 8560 Error Code 09,005.40.5185
Hi mark711:
Here is you problem.
9,005.49: Ink loader fault. The cyan ink melt heater is on, but the ink does not
appear to be dripping.
Troubleshooting Procedure
Step Questions and Actions Yes No
1 1.
Are the ink sticks all Xerox ink? Go to
Step 2.
Advise
customer. Run
clearISCfault
test to clear the
error.
2 1. Manually verify that the ink stick is able to
advance in the ink loader chute.
Go to
Step 3.
Remove any
blockage and/
or replace the
ink stick.Run
clearISCfault
test to clear the
error.
3 1. Run the appropriate Ink Melt [1, 2, 3, 4]
Heater
test.
1 = Yellow
2 = Cyan
3 = Magenta
4 = Black
2. Did the test pass?
Replace
the
printhead.
Replace the ink
loader
assembly. Run
clearISCfault
test to clear the error.
Hope this helps
Apr 23, 2009 | Xerox Phaser 8500/DN Printer
Paper jam
I would make sure you opened and closed EVERY section of the machine that was indicated on the op panel.... even if you found the paper already..
Apr 11, 2009 | Office Equipment & Supplies
Xerox Regal 5790 Paper Jam
Wat is the code about this problem 08-300 its maine the Füser is not start on the same time when the cluts is not werking oder the pall is not gooing to this point open the front dore an you cann sche small cluts this is no good contact of its not working then you can puss the small wiel to the bik rol en the paper wil to the füser turn the green wiel and the paper go to füser out. I had this problem also with Xerox 5760 the same .
Apr 10, 2009 | Xerox Office Equipment & Supplies
Xerox 5760 Color Copier has fault 03-302 at start-up
Xerox 5350, 5352, 5760 Code Description 00-009, 030, 031, 032, 033 A door was opened while paper was being fed 00-047 Paper in duplex 00-1 Auditron 00-2 Diagnostic error 00-3 Faults error 00-4 Ric error 00-5 Job manager system error 00-6 LLM interface 00-7 Standby error 00-8 Communications error 00-9 Xerographic error 01-300 Front interlock 01-310 Right upper interlock 01-315 Left upper interlock 01-320 Left lower interlock 01-325 Fuser interlock 02-910 Key counter missing 02-920 Wrong combination of accessories 03-302, 321, 322, 326, 327 LLM to ISIL communications problems 03-328 IOT communications problem with duplex or tray 4 03-330 IOT communications problems with HCF 03-335, 336 LLM communications problems with edit 03-340 NVM memory 03-341-347 Communications problems between IOT and sorter 03-350-354 Communications problem with LLM and user interface 03-363, 364 Communications problem between LLM & optics 03-370-03-373 Communications problem between LLM & DADF 03-380, 384 03-416-422 RAM memory problem 03-424, 426 NVM memory problem 03-430, 432 Billing problem 03-439 GRAIB communications problem 03-440 RIC communications problem 03-441 RIC NVM problem 03-442 Modem 03-443-458 RIC problems 03-460 Serial communications processor problem 04-300 Main motor or drive problem 05-100-108 DADF registration sensor 05-110 DADF exit sensor 05-115, 120 DADF jams 05-305 DADF document drive 05-310, 312 DADF document sensor 05-316 DADF registration sensor jam 05-325 DADF exit sensor 05-335, 341, 345 DADF interlock switches 06-300-310 Scan problems 06-315 Scan drive 06-320A, 320B, 320C, 325 Scan problem 06-330 Lens drive 06-340 Exposure control problem 06-342 LLM CPU problem 06-344-350 Exposure cvontrol problem 06-352 IOT CPU problem 07-300, 315, 330, 345 Tray faults 07-360-370 HCF problems 07-375, 380A, 380B Duplex problems 08-100-110 Feed problems. Lead edge of copy paper is late getting to feed sensor of tray 1 08-115-162 Feed problem. Lead edge of copy paper is late getting to registration sensor 08-165 Paper jam at registration sensor 08-310-370 Paper at a sensor when power is turned on 08-330 DADF nudger sensor 08-380 Registration side to side problem with home position 08-390 Nip 09-300 Copy cartridge finished (drum unit) 09-310 Add black toner Add color toner 09-320 Add color toner 09-330 Wrong copy cartridge (wrong drum unit) 09-340 Drum cartridge not installed properly 09-350 Waste toner full 100 A fault has occurred 10-100 Exit jam 10-105 Exit jam 10-110 Vertical sensor jam 10-120, 122, 125 Duplex jam 10-150, 155 Too much or not enough paper in duplex tray 10-300 Fuser thermistor 10-302 Low fuser temperature 10-304 Bad fuser temp 10-308 High fuser temperature or open thermistor 10-310 High fuser temperature 10-312 Fuser not up to temperature after energy save 10-314 Fuser problem 10-320 Fuser web finished 10-330, 335, 340 Exit switch, vertical sensor switch actuated when power is turned on 11-100-116 Sorter jam 11-150-176 Sorter auto stapler jam 11-310, 314, 316 Sorter interlock 11-325A,B,C,D,E,F,G Sorter index 11-352, 354, 356 Sorter auto stapler interlocks 11-365A,B,C,D,E Sorter auto stapler bin 11-370,371,372A,373A,373B,374 Sorter auto stapler staple failure, staple home problem or tamper home problem 11-385A,385B,390A,B,C,D,E,396A Sorter auto stapler staple failure, staple home problem or tamper home problem 301 Fuser web must be replaced 302 Copy cartridge (drum unit) must be replaced 501 Tray 1 must be rebuilt 502 Tray 2 must be rebuilt 503 Tray 3 must be rebuilt 504 Tray 4 must be rebuilt 505 HCF must be rebuilt 506 Bypass must be rebuilt 507 Duplex unit must be rebuilt 508 Replace black developer 509 Replace red developer 510 Replace green developer 512 Replace brown developer 513 Copy cartridge (drum unit) will need replacing soon 514 Fuser web will need replacing soon 515 DADF belt should be replaced 516 DADF feed rollers should be replaced 517 Replace exposure lamp 518 Replace suction filter 519 Replace ozone filter 520 Replace optics filter 521 Replace particle filter 522 Replace upper fuser roller 523 Replace fuser pawls 524 Replace pressure roller 525 Replace pressure roller pawls 900-905 Key operator calls
Jan 16, 2009 | Office Equipment & Supplies
XEROX 8550 DP ERROR
when are you getting this error message?
Oct 28, 2008 | Xerox Phaser 8550DX Laser Printer
Error Code 09,038.46:103468 help!
That code is a back stick count failure.
You want to look in your ink loader, see if there is a stick jammed, twisted, broken or in anyother way out of place or hung up in the slot.
Be sure you loaded a 8550 stick also, since the shapes on the different phaser printer sticks are all different.
You may have to carefully remove the black sticks and reload them. You can take a screw and screw it into the ink stick, slide it back and remove.
Most likely you will find a gap in the ink sticks causing the problem. Here are the Xerox support page instructions.
  1. Open and close the Top Cover to resolve the problem.
  2. If the problem persists, arrange the ink sticks until there are no spaces between sticks of the same color.
  3. Check for non 8500/8550 ink sticks jammed in the ink load chutes. If non 8500/8550 ink sticks, whether manufactured by Xerox or by a non-Xerox ink vendor, caused the ink sick jam, contact support to place a service call.
Mar 20, 2008 | Xerox Phaser 8550DX Laser Printer
PHASER 8500DN ERROR CODE: 09,038,46.8515
That is a black ink stick count failure.
It is not seeing the black ink stick.
See if a stick is broken or not in place. One may be twisted or just jammed.
Outside chance you would need an ink loader because the sensor is not detecting the ink
Check the black sticks see if you can clear it by moving them around or sliding them up and out and reloading.
Mar 08, 2008 | Xerox Phaser 8500/DN Printer
Docucolor 12 error code HELP
9-357.
Black toner problem.Probably You have low toner sensor defect.
But try first to vacuum and clean black toner dispenser.You must vacuum whole path wich is used to transport black toner to developer unit.Then if printing B/W print only, you must print 10 full color sheets every 100 copies.
Sep 13, 2007 | Xerox DocuColor 12 Color Copier
Xerox DocuColor 12 Color Copier Logo
241 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
