Question about Mitsubishi VS-60703 60" Rear Projection Television
Hello, I am thinking of taking a friend tv that he wants to give me but it is not working. It is a Mitsubishi VS-60703 60in and he says that as soon as you turn it on, it turns its self right back off. What could be the problem with this, and can it just be a burned out bulb that would be an easy fix? Thanks, Justin
  • nhislight Feb 04, 2010
    I have done some tv repair, but don't know how involved this repair would be if I have to replace the power supply? Do you have any idea what the cost of mateials would be if the power supply has to be replaced?
    Thanks,
    Justin
    Hello, I am thinking of taking a friend tv that he wants to give me but it is not working. It is a 2000 Mitsubishi VS-60703 60in and he says that as soon as you turn it on, it turns its self right back off. What could be the problem with this, and can it just be a burned out bulb? If this is a power supply board what would be the cost in fixing it myself?
    Thanks, Justin
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
Two suggestions:
1.) It is a 1998 model--it may or may not have the self check feature. When it shuts off press both the Menu and Input buttons on the front of the set for at least 5 seconds and release both--if it has the self check the power light should blink an error code--most common is 2, a pause and 2, and it will repeat the error several times.
2.) Do a visual look at the front few inches of all the boards (there is an inspection plate on the front behind the speaker cloth grill). Look for any signs of Glycol; it is a coolant used to cool the face of all three tubes and these sets have a history of it leaking out and getting on the circuit boards.
If you see it--it is a clear liquid and VERY TOXIC--do not touch it. It will short things out and solder connections or parts will be discolored or look like coroaded metal. Sometimes it will be white looking or like model airplane glue.
If you find signs of this it is the end of the set as you would not only have to clean it away and repair all damage it has done but you would also have to remove whichever picture tube or tubes is leaking and reseal them etc.
Let me know what you find--I have seen a lot of these with Glycol problems--use a flashlight and look carefully.
SD TECH
Posted on Feb 04, 2010
  • SD Tech
    SD Tech Feb 04, 2010
    Try what I suggested--NO CIRCUIT BOARDS FOR THIS SET ARE AVAILABLE FROM MITSUBISHI- whatever problem it has will have to be found and parts replaced IF it is even repairable.
    SD TECH
    Brigadier General:
  • 8,619 Answers
Hi Justin,
Thanks for using FixYa. From what you have described it seems that this might have happened due to over-voltage. Please check the power supply unit for swollen/bulged capacitors and burnt wires/components on the power supply board of the TV. The reason it wont turn on could also be due to the power supply going bad and you might have to replace the board completely. Please make sure to turn off and unplug the TV for at least 1 hour (this will drain off current from all components especially capacitors) before you perform any repairs. Also note that the TV consists of very high voltages even when it is in OFF condition. All this is only recommended if you have electrical expertise and know how to solder/re-solder components.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
  • Rylee Smith
    Rylee Smith Feb 04, 2010
    Hi Justin,
    Thanks for your reply. If you want to repair it yourself you'll need a soldering iron, solder, voltmeter and a power supply board. I think its better to replace the board completely however you can check the board if only the capacitors are bad then replacing the capacitors would be nice. If you do it yourself the repair should cost you around $200 depending on the parts that have gone bad. Please do accept the solution if the issue is resolved or else revert for further assistance.
    Thanks
    Rylee
  • Rylee Smith
    Hello justin,
    As I have advised you power not turning on could be due to the power supply going bad nothing else. Please do accept the solution if the issue is resolved or else revert for further assistance.
    Thanks
    Rylee
Hello I cannot turn my tv on. We have tried several locations in the house, but the green power button flashes on and then goes off.
Power suppy issues most likely.
These older style tv's do have lots of surface mount stuff that occasionally develops breaks that cause power up issues.
You need to find someone with TV experience who will do an at home check of your set. My friend got a guy who moonlights to do it for a couple hundred bucks a few years back. I think thats the best solution for the unit at a reasonable cost.
Good luck and be careful.
Mar 17, 2010 | Mitsubishi VS-60707 60" Rear Projection...
Mitsubishi VS-45603
You will need to go into the menu, setup, a/v connection, then make sure the locked to input is selected to no..
Good luck..
Sep 17, 2008 | Mitsubishi VS-45603 45" Rear Projection...
Mitsubishi vs-5041 -after a few hours on, the tv goes black
Get the projection bulb checked if fine its something internal in your tv but i think you need new bulb
Aug 01, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Gradually lost picture; Mitsubishi VS-50501A
you need to buy a new lamp and replace the old one thats your only problem its about $200 for the lamp
Mar 27, 2009 | Mitsubishi VS-50501 50" Rear Projection...
NEED THE PIN CODE FOR A 1991 MITSUBISHI MODEL # VS-4003R PROJECTION TV
Hello, If you're recieving satellite tv, there a selection in your menu which will give you those codes, but I think the code is # 080.
I hope this helps.
Jan 23, 2009 | Televison & Video
Mitsubishi vs-5051
First you can safely take off back and look for Screen controls&Focus, Gently turn up the 3 screen controls this will add light to picture, but you need to evenly turn up, the 3 colors are red, blue, green. the other 3 knobs are for focus. Do not turn them if you do you will need to realign the focus also. And if this doesn't help then there is a high voltage capacitor leaky in the flyback area.
Sep 14, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Only Picture in Picture Works...????
Its possible some of the surface mount capactors has failed on the pip board is so the unit will need to be replace or repaired.
Mar 18, 2007 | Mitsubishi VS-45603 45" Rear Projection...
Televison & Video Logo
63 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
