Question about Mitsubishi WS-65905 65" Rear Projection Television
Is the liquid in mitsubishi tv poison - Mitsubishi WS-65905 65" Rear Projection Television
  • 111 Answers
Yes its ethilyne glycol (antifreeze)
Posted on Feb 04, 2010
I have a 60 inch tv and i have white dots on the screen
that is what we call dead pixel, you can remove this by following the steps below.
  1. Turn off your tv.
  2. Get yourself a damp cloth, so that you don't scratch your screen.
  3. Apply pressure to the area where the dead pixel is. Do not put pressure anywhere else, as this may make more dead pixels.
  4. While applying pressure, turn on your tv screen.
  5. Remove pressure and the dead pixel should be gone. This works as the liquid in the liquid crystal has not spread into each little pixel. This liquid is used with the backlight on your monitor, allowing different amounts of light through which give off different colours.
    Hope this helps.
May 28, 2011 | Mitsubishi Televison & Video
Mitsubishi TV Screen Water Stain Problem
You can use warm water and a soft cloth to try and clean it, but it will probably leave some evidence that liquid existed between the two layers at some point. Mitsubishi will deal screens directly to their customers if you ask nice enough and are willing to install yourself.
Jul 05, 2010 | Mitsubishi WD-62525 62" Rear Projection...
My model RTW22 plastic hose crumbled that goes to
freon isn't poison. but should not be taken internaly. the tube is probably the cond drain tube and the bad liquid is algi/ water /dirt /grease/ sccume/ ect . replace the tube with a factory replace ment as it has special turn's in it . or use a 1/2 id hose and run it to the pan under neath .. now wasn't that easy **** ..
Dec 07, 2009 | Washing Machines
The liquid in my mitsubishi rear projection tv just came out of no where once i started to unscrew one of the color tubes...... does this sound right or make any sense??
Yes it does, you should not unscrew the red screws only the gold ones in the corners of the tube.
What is the symptom of the problem that you are having.
You will need to ensure that all of the liquid is off of the circuit boards as soon as possible as it will wick under the IC's on the board and quickly ruin them.
Please let me know if you need more help or assistance.
asnowman
Nov 28, 2009 | Mitsubishi WS-65905 65" Rear Projection...
Video is double and no sound
This model TV is known for coolant leakage from the picture tubes. If this is your problem you will find liquid on the circuit board by removing the back panel.The spilled liquid causes a plethora of problems depending on where the liquid collects on the circuit board.
Also possible convergence IC failure.
Call a good TV Tech.
Jul 30, 2009 | Mitsubishi VS-50705 50" Rear Projection...
Mitsubishi VS-50705 50" Projection TV
I jus posted a response to tell you where else to look for that liquid as its most likely the CRTs leaking.
Jun 14, 2008 | Mitsubishi VS-50705 50" Rear Projection...
How to replace projection lights in 42' TV?
Hello mdmaxwell,
The CRTs are usually what they call a matched set, meaning if you replace one you should replace them all this is going to cost you about at least $400.00. The liquid you felt was coolent for the blue tube, by the way I hope you cleaned your hands after touching that stuff it is a kin to glycoalochol which is poison. I would suggest www.electronix.com as a place to begin to look for the part or parts (I suggest replacing all three CRTs to manitain the matched abilities of the tubes).
I hope this helps
Thank you,
Shuttle83
Oct 11, 2007 | Sony KP-46WT500 46" Rear Projection...
Corroded Board
The best place for board repair or replace is PTS 1-800-844-7871 Yes you would need to fill the CRT's fluid level back up. The liquid is Glycnol(Liquid anti-freeze) Poisonious yes is swallowed! So take precautions. You can get if from places like MCM electronics, Tritronics, bluestar-online.com, etc. It's called CRT coolant fluid. Yes and you would need to fix leak, probably a gasket or seal. Hope this helps!
Sep 14, 2007 | Mitsubishi WS-55807 TV
Mitsubishi WS-65905 65" Rear Projection Television Logo
95 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
