Question about Vision Panini My X 60 Check Scanner
Wont scan some checks and wont scan money orders
    New Friend:
  • 28 Answers
This is for the protection of the idem. It is not to be duplicated and the waivy lines you cannot see the scanner does see and refuses to scan them. However you can copy them or you can print screen them from a document. Copiers don't care.
Posted on May 05, 2016
    President:
  • 1,738 Answers
The software for your device has special security features programmed in that will recognize commonly counterfeited items.
This software will prevent unauthorized scanning of security documents like cashier's checks, money orders, United States currency, etc.
There is no way to remove this feature from your scanner's software. However, some software allows for very low resolution (100 DPI or less) scans of these documents.
You'll just have to experiment and see if you can scan these documents with your scanner at these lower resolutions.
Posted on Feb 07, 2010
1992 expo lrv wont start
Hi, First have your battery checked out. Second, Go and get or have your car code scanned. You will save time and money searching for the problem(s). Good luck.
Mar 30, 2015 | Cars & Trucks
Car wont start. used starting fluid and it wont even fire. it just cut off as i was driving
You don't say any specific info on the car as to year, make or model but if it is a newer car then the system that runs the engine is fully electronic, so when a problem like you now have occurs it will set a fault code in the memory of the computer that controls the systems fuel and ignition systems. In order to see what the fault code(s) are in memory you must have the system read with a special tool called a scanner or a basic fault code reader. Guessing is a very bad idea and can eat up your money very fast, so pay to have the diagnostic scan run even if you do the actual repair work yourself.
Jan 24, 2012 | Cars & Trucks
Check engine light is on and the car hardly can't start..Suzuki vitara.How can i know what the problem is?
CHECK ENGINE LIGHT ON ENGINE WONT START.BEST CODE CAN VECHICLE.IF ENGINE WONT TURN OVER.COULD BE WEAK BATTERY DUE TO ALTERNATOR FAILURE OR CRANKSHAFT POSITION SENSOR OR CAMSHAFT SENSOR FAILED.EGR VALVE STUCK OPEN.ECM HAS FAILED MANY THINGS WILL CAUSE THAT PROBLEM HAVE VECHICLE CODE SCANNED SAVE YOU MONEY AND TIME..
Sep 25, 2011 | 2003 Suzuki Vitara
What do i check if wont start but cranks ford 6.0
On a 2006 I would begin by scanning the engine computer to see if there are any fault codes. This could be caused by a problem with the Antitheft System, It could be caused by a communication problem between the Engine Control Module (ECM) and the Generic Electronic Module (GEM) and /or the Instrument Panel Cluster Module (IPC). (If all the computers are not talking to each other, the ECM shuts off the fuel and the spark.) Then it could be simply out of gas...But I would begin diagnosis with a scan to help point the direction so you don't spend days spinning your wheels and "guessing". You can also waste a lot of your hard-earned money this way....Money that could be used better by having the problem properly diagnosed.
When I say "scan", I mean actually looking at the computer data to verify that the engine is recieving the signal from the ignition switch, the crank sensor, the cam sensor, the mass airflow sensor, etc. - NOT just pulling codes.
Jan 30, 2011 | 2006 Ford F 350 Super Duty
2002 chrysler van wont start changed battery dry gasdo to cold temp cranks but wont start smell gas
SMELL LIKE FLOODING BUT CHECK AROUND FOR FUEL LEAKS UNDER THE HOOD AROUND ENGINE COMPARTMENT WHERE FUEL LINES ARE AND CHECK UNDER THE VECHICLE FROM FRONT TO THE BACK WHERE FUEL LINES GOES TO FUEL TANK.LOOK FOR GAS DRIPPING.BEST TO SCAN VECHICLE WITH A SCANNER.MANY THINGS WILL KEEP IT FROM CRANKING UP.CHECK IGNITION FUSE MAKE SURE COIL GETTING POWER.IF ALL IS GOOD YOU REPLACED SPARK PLUGS AND WIRES HAVE VECHICLE THAT WAY YOU WONT SPEND A WHOLE LOT OF MONEY BUYING A LOT OF NEW PARTS.
Jan 13, 2011 | Chrysler Town & Country Cars & Trucks
It wont crank over, Have changed the crank censor, knock censor and body modual censor still wont work . If I diconnent the battery and main computer for a few min. it will start but once it is turned off...
Without test main componets on the vehicle we would only be guessing . Doing electrical checks , hooking up a professional scan tool an viewing engine data etc. your best bet ,take it to a qualified repair shop . Spend the money for an hour diagnostic time .That is unless you like guessing an just replacing parts
047 Engine Hard to Start or No Start Scan Data for Ignition
048 Engine Hard to Start or No Start Scan Data for Starting Problems
Sep 06, 2017 | 2005 Pontiac Montana
Engine runs smooth but at times it will shut off completely but then within seconds it will catch back up and be running again. Sometimes too it wont start until about the 5th time you turn it over. Have...
yes. scanning can help save time & money it is most likely the crank shaft sensor ,and will eventually quit re starting,so you should git it scanned or you will be at the least inconvenienced,hope this helped.
Mar 23, 2010 | 1999 Dodge Avenger
Keyless entry wont work 2002 chevy s10
The only way to program them is with a scan tool so you'll need to visit your local dealer to have it done. Here is how it is done.
  1. Install a scan tool.
  2. Use the scan tool in order to access programming: Vehicle Control System/Computer Integrating System/Module Setup/BCM/Program Key Fobs.
  3. Press the START soft key on the scan tool. Important: The scan tool must stay connected until all of the transmitters are programmed.
  4. Press and hold the LOCK button and the UNLOCK button simultaneously on one transmitter. After a delay of 5-10 seconds, the scan tool will indicate that the transmitter is programmed.
  5. Repeat the previous step in order to program up to 4 transmitters.
  6. Remove the scan tool.
  7. Operate the transmitter functions in order to verify correct system operation.
Sep 02, 2009 | 2002 Chevrolet S-10
948 people viewed this question
Top Vision Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Vision Office Equipment and Supply Expert? Answer questions, earn points and help others
