Question about VeriFone PRINTER 250 RS232C INTERFACE
Ian_harte i need to conect the printer on my PC on serial port, but the cable is DIN type. When i find the pin-out to make it an serial port interfase cable with DB-9 female connector in a extreme?. Thanks.
Some of the credit card printer supliers sell a cable that you need. I don't know the exact pin out myself.
Posted on Mar 24, 2009
What is the 6 pin din socket on a brother m4309 printer for? is it a Commodore serial port?
This printer is so old there is no technical info online for it.
The DIN connector is probably for the power supply.
Mar 13, 2015 | Brother m4309 - M4309 Printer
Does the gateway sx2370 have special printer ports
All PCs have ports that can be used to operate printers and other peripheral devices. Most modern desktops have two ports that may be used for printers. A USB, or a serial printer port... it has lots of little holes in it on a socket. Depending on the type of printer you have, one of those will connect to your printer, if you have the cable. If you need to buy a serial cable count the number of holes and tell the place you need a serial printer cable with (number of holes) pins.
Jun 15, 2014 | Gateway Sx2370-Ur10p Desktop Black
Kids gave me a printer/scanner Epson model number c171a. Need the cable to it. AN oldie but looks like a pretty nice printer. Can you help??
The cable you need depends on the unit. I am not aware of a C171a model from Epson. I have seen it listed as a version of the RX500. In that case you need a USB cable with A/B male ends.
Otherwise, most printers (from about 1997 on) will use a USB cable. This has two male ends - a square end goes into the printer and a rectangular end that goes to the computer (called A/B). For older printers (there may be multiple ports or just one), you may see a parallel port (the cable has a wide rectangular plug on both sides with 36 pins) or serial port (the cable may have DB9 (9 pin), DB25 (25 pin) or both). Often it is called a RS-232 port. For a parallel port connection, you would need one that is designed for scanners and bi-directional communication (USB to parallel adapters are available to connect this to a new computer but you still need the bi-directional version). Similarly, USB to serial adapters are available.
Generally you can tell what cable you need by looking at the back of the unit where the ports are. (Although some all-in ones have the USB cables in other places - routed through the side of the unit but the plug is near where the ink cartridges go.) Then the size and pin counts for parallel or serial tell you what cable to get. There is usually a symbol indicating the cable type as well near each port. USB cables are usually indicated by a tree like symbol with curved branches.
I hope this helps.
Jul 25, 2010 | Epson Office Equipment & Supplies
How can i watch downloaded films on my computer on my big screen tv
u can connect your computer to ur TV thru an adaptor(search in google) that can connect to ur PC's display port (the port on ur PC were u conenct ur monitor) the adaptor will have on one side the similar plug as in your monitor cable and in the other end it will have RAS cable plug
or u can use a DIN plug...but ur computer must have a DIN output...
or u can use something like an external TV tuner card box or ADS instant DVD box....
or u can use a convertor box or cable...it will have a 5 pin DIN connector on one end and RAS plug at the other.
Sound is connected from your sound output(the point which has ur speakers connected) plug/output on PC to the sound in of ur TV...again u can use different combination of pin types...RSA or an ordinary sound connector cable
i found this on Ebay...check this out...
http://cgi.ebay.com.sg/PC-Laptop-to-TV-Connector-Watch-Movies-on-Big-Screen_W0QQitemZ150399235227QQcmdZViewItemQQptZLH_DefaultDomain_216?hash=item23047e349b
Dec 31, 2009 | HP Pavilion dv4000 Notebook
Epson Photo PC Mini Cable
you can use the same serial cable for the model photopc 500 600 700 it is 8pin NOT 5pin
you can see the specs here for your camera
http://files.support.epson.com/pdf/phpc__/phpc__sl.pdf
and it it at ebay just type the right name
EPSON PHOTOPC SERIAL CABLE 8 PIN
Oct 08, 2009 | Epson PhotoPC 650 Digital Camera
Does my dell dimension 2350 have a dvi port?
No, it does not.
Check the specs of your desktop PC here:
Ports and Connectors
Externally accessible:
Serial
9-pin connector; 16550C-compatible
Parallel
25-hole connector (bidirectional)
Video
15-hole connector
Keyboard
6-pin mini-DIN connector
Mouse
USB
two front-panel and four back-panel USB 2.0–compliant connectors
Network
RJ-45 connector
Audio
three back miniature connectors for line-in, line-out, and microphone
Headphone
one front miniature connector for line-out
Serial
Parallel
Video
15-hole connector
Keyboard
Mouse
USB
Network
RJ-45 connector
Audio
Headphone
http://support.dell.com/support/edocs/systems/dim2350/specs.htm#1107078
Jul 26, 2009 | Dell Dimension 2350 PC Desktop
Zebra 105SE 25 pin serial cable
error can be on the pc.side or the printer's:
check
- if in windows the LPT ports are addressed properly (if u got a many usb ports, then windows adresses these first and skips the older lpt's- same applies when using an external usb-hub/splitter!)
- that there are no dma or irq conflicts
(see device manager)
- if the right driver is installed, if it suits the windows version u are using/has been written for it
- doublecheck printer against another printer
on your pc using same port
- and/or try to connect it to another pc
so u make sure on which side the error ocurs!
least: check the cable itself
Jun 13, 2009 | Zebra 105Se Thermal Printer
Want to connect to my computer
What connector/interface does your PC has
9-pin or 25-pin connector
If it has 9-pin connector: use the following:
DB-9 RS-232 Serial Connection
or
DB-25 RS-232 Serial Connection
If it has 25-pin connector: use the following:
DB-25 Serial Connection
or
If you are configuring the computer to use an RS-422A serial port, you need a special cable. Contact the computer or printer network manufacturer to see if an RS-422A cable is available. If no cable is available, contact your computer manufacturer for your computer pin assignments and have a cable constructed.
The default configuration for the serial port on the printer is for RS-232C serial communication. To set the printer to use RS-422A serial communication, change the control panel Serial Menu’s SERIAL setting to SERIAL=RS-422.
Oct 29, 2008 | HP LaserJet 4 plus Printer
Trying to setup a Zebra TLP 2844-Z on serial port
Two possibilities are the port configuration and the type of serial cable.
The printer has a feature that will try to match itself to the PC's configuration. Press and hold the feed button until the green status led flashes three times. While the led flashes send a ZPL format to the printer (hopefully you can do this through Design Pro by trying to adjust the printer or print labels, but the labels will not print). When the printer and PC are synchonized, the led changes to solid green.
If you can synchonize but still can't print, the problem might be the serial cable; not all serial cables will work. You should use a full null model cable (all pins connected except 1 and 8).
Sep 19, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Interfase doesnt work, cable is damaged.
I should be a scsi 2 cable -- 50-pin mini-din male/male...
Double check the scanner and the card, if you don't know the difference between mini-din and regular, let me know and I'll try to find images to show you.
Maggie B
Feb 21, 2008 | Agfa Arcus 1200 Flatbed Scanner
197 people viewed this question
Top VeriFone Office Equipment & Supplies Experts
Marvin
Marvin
George Mclaughlin
Willie Cooper
Willie Cooper
Are you a VeriFone Office Equipment and Supply Expert? Answer questions, earn points and help others
