Question about Refrigerators
OUR AMANA TR25VW REFRIGERATOR W/ TOP FREEZER, RUBS AS YOU CLOSE THE DOOR IN THE LEFT LOWER CORNER.
  • 52 Answers
Check with your owners manual, that will show you how to re-align the doors. Or, worse case scenario, the internal rail is bent and needs to be replaced. Do a visual check on that.
Posted on Feb 06, 2010
I have an Amana refrigerator, TR25VW. There is water, ice formed on the ceiling of the bottom part, not the freezer lately. Is it the sealing rubber issue?
freezers are frost free but not fridges.if the seals are bad(look along the edges with the door shut)ice will build up very quickly.adjust doors/rubbers as req.
wipe out regurlarly/syringe drain holes with clorine bleach/vaccuum vents,(most people complain of water under the veg tray,dont they see steam on bathroom mirrors.....same thing)
Jul 02, 2010 | Refrigerators
Do the door hinges ever wear out
I did my own search for the same problem and saw Dougs question and lack of a solution. I have the same sagging door problem and was looking for a fix.
First, when I removed the weight of the items from inside the door, the door closes properly. This means that the door is not very sturdy and cannot hold the weight of items placed on door shelving. There are NO adjustment mechanisms on the door hinges either. Bad on Amana. The GOOD NEWS is that I fixed the problem.
Take out all items from the door shelves. I removed the top hinge with the door closed to keep it from falling. I took the door off and placed it on the floor. The lower hinge has a plastic pivot over a steel pin - remove that for a moment. Place steel washers over the steel pin - about .080" or so thickness. Replace the plastic pivot. Replace the door. Add the normal weight of items back on the door shelves. The door closes perfectly. At least until the door sags again and I'll need to add another shim.
Jun 21, 2010 | Amana ABB2524DE Bottom Freezer...
We have an Amana side by side. The freezer door
hi. First of all, finding the model number can be a bit of a challenge. here are the places to look:
  • Inside the refrigerator or freezer, on the upper left or right side wall
  • Behind the lower crisper drawer
  • Behind the lower toe kick-plate
  • On the face frame of the refrigerator body
  • Nov 17, 2009 | Refrigerators
    I just replaced my door seal on my refrigerator and now it won't seal on the lower left corner. I've checked all the hardware and everything looks good. I believe the door has been sprung. Is there...
    First, try to use a hair dryer to see if it will seal that way. Then try to let it set all night without opening the door to seal it.
    Secondly, look at the hinges to see if they are working properly.
    We hope this answers your questions and solves your problem.
    Nov 04, 2009 | Amana Top Freezer 20.6 cu. ft....
    Freezer door opens easily
    The freezer door has a rubber gasket fitted with magnet beading. In case the gasket is torn or the magnet strip is missing due to continuous use the door does not close. Just replace the gasket and you will see that the door does not open unless you physically open it.
    Jul 13, 2009 | Refrigerators
    Refrigerator top freezer door slightly rubs to inside freezer bottom while closing the door that opens on right side. Due to this after closing the freezer door, the door opens less than a mm near the left...
    I think I can help. Usuly the doors have been swapped around in this case. look closely at the freezer door on hinge side. there should be a small metal piece that covers the hinge to prevent anything from jamming hinge. this shield also serves as a spacer. this is what sets the door at the correct height. if the piece is missing you can have your local appliance dealer order one for you. it only takes a few minutes ts to install. you will need to remove the freezer door to do this. Hope this helps and good luck.
    May 07, 2009 | Whirlpool ET1FHMXLQ / ET1FHMXLT Top...
    Freezer door hard to close
    Any adjustment is at the hinge, you probably find that you have fitted it too close and it is pinching the gasket in the corner. Tilting the fridge back can help, but the doors must be able to swing closed freely first. This can be done by adjusting the footing screws below the front of the fridge.
    Mar 23, 2009 | Amana ATB1832AR Top Freezer Refrigerator
    Freezer door rubbing
    take the freezer door off and put a washer or two on the bottom hinge. sometimes there are extra plastic washers on the top hinge that you can move to the bottom to lift it up.
    also check if the hinge is bent or loose, as this may cause the problem.
    Jun 28, 2008 | KitchenAid Architect KTLA19KRSS Stainless...
    Lower door wont stay closed
    I doubt it. The problem is probably that the unit is on an uneven or unlevel floor. Make sure all 4 corners are 'solid' and the unit is level. Is the door overloaded? Any hinge damage to either door or loose hardware?
    Jan 10, 2008 | Amana ABD2533DEW / ABD2533DEB / ABD2533DEQ...
    Refrigerators Logo
    167 people viewed this question
    Top Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
