Question about Conair Health & Beauty
My conair HC318D came apart near the blades. How do I put it back together? Is there and on-line manual?
  • 32 Answers
It is designed to come apart for replacement. Look at page 3 of manual for instructions.
http://www.conaircanada.ca/en/pdf/ibs/en_HC318DWXCSC.pdf
Posted on Feb 04, 2010
I have clippers model number HC95WV. I can not get blades back together
Ok place the small metal cutter on top of the large metal comb, place the white plastic piece into the top of the cutter with the protruding bit at the back, place the metal bracket with 4 holes on top first locating the front into the white plastic slot, then place the last metal bracket on top with the raised part to the front, then simply hold it all together and put the screws in form the back!
Hope I got the right blade style!!
Mar 18, 2014 | Conair Health & Beauty
Clippers stopped clipping. I changed to a new blade but it didnt help. I took the clippers apart and put in a new holder for the clippers. I put the clippers back together and although they clip a little...
Sound as though the blade drive needs replacing, commonly you will notice tram lines in the cut on your longer blades or the shorter blades struggling to cut
Jul 05, 2011 | Andis AGC2 Hair Trimmer
I took my oster trimmers apart now i dont know how to put them back together can u help me
Unfortunately, Oster does not publish any real maintenance manuals. Basically, if you only took apart the cutting blades and the oscillator, it's not too hard. If you tried to take apart the electric motor, that's a whole different story. If it's just the blade assembly, carefully align the blade assembly with the groove pointing into the trimmer handle and hold the blades together so that they are parallel, not crooked and reinsert the screws. You will see how the blades align, based on the wear marks on the bottom blade guide. If you took apart the oscillating arm, then line up the cam pin with the round hole in the arm, then replace the screws that attach the top blade to the oscillating arm. You may have to push in the tension arm so that you can align the screws with the threaded holes on the handle first. Final step is to screw the bottom blade guide back onto the handle, again align the guide with the blades so that they are parallel and not crooked. The best way to do this is to start threading the screws, then before tightening them all the way, align the blades first. If none of this works, go to this website: http://www.osterstyle.com/CustomerService.aspx and locate an authorized Oster dealer/support center near you. You'll probably have to mail the clippers in to one of the sites.
JB
Feb 25, 2011 | Oster T-Finisher 76059-010 / 76059-030...
I can't find the manual of my Conair GMT 170X. I took the blades apart to clean and lube and now I don't know how to put the spring assembly back together with the blade. Please help
their is 2 long wires with a l shaped hook on the the smalles blade that goes on the bottom the points of those wires go in the holes in the bottom of it which is a white thing with 2 groves in it make sure the blade is facing away from where the screws go the take the plastic pad and put it in the 2 holes of the top blad the set it on their facing the same direction the push down till its flush the put the 2 screws back in
Dec 17, 2010 | Conair GMT 170 CS Beard Trimmer
The trimmer is not cutting the way it should, the bottom blade seems out of place and I cannot put it back in place
Conair trimmers are only good for about a year and they are hard to put back once you have messed with them. does your blade pop off or does it have two phillips screws holding it in? If you take the blade off completely you should see two arms that are in there, you have to place the blades back on correctly and hold them together while putting the screws back in. be very careful not to tighten the screws too much. Oil your blades with 3-1 oil and then turn them on. adjust the trimmer and see if everything is level, if it is try cutting withem and see what happens. If the motor sounds good but the blades are pulling your hair rather then cutting it then you need to replace your trimmers because your blades are daul.
Oct 05, 2010 | Conair HC100RCS Hair Trimmer
Conair GMT200 Assembly
Hey dude i had the same problem n_n. Attach the screws in place and try to screw one by one gently. Soon this pressure will keep the spring tighten (instead your finger's pressure) then it will be easier to reassemble the component. I know you'll fix it n_n.
May 20, 2009 | Conair GMT200TD
Conair Champion Hair clipper
i have an "hc318d" conair hair clipper. i took the two screws off to oil the inside and now i can't get it put back together properly. can u help?
Aug 04, 2008 | Conair 5200
Fell apart..help please!!!
The larger white pieice that has holes in it should be connected between both the spring and the smaller razor, The bottom of the larger white peice has to be able to fit in the peice of medal that moves in a circular motion inside the top part.
First, Try to make the hooks of the spring go in pretty securly inside the small holes. The flat side of the white peice has to be connected to the flat side of the smaller razor. They should kinda snap together on the top hole. I had to gently place the parts together and push the larger white peice in the medal by placeing the larger razor peice right on top and pressing down really hard. You might hear some snapping but the peices should all connect together and the large medal peice should connect to the black groves and press hard. Hold in place while putting the screws back in.
Jun 21, 2008 | Conair GMT182CS
Conair hc318d reassembly
i have hc318d clipper it been use two time and havent use it in a year so was going to use it last nite and the small blade fell out. i try to put it back in and it want hold keep falling out
Dec 17, 2007 | Conair HC100RCS Hair Trimmer
Health & Beauty Logo
1,030 people viewed this question
Top Conair Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
 Mikey
Mikey
Are you a Conair Health and Beauty Expert? Answer questions, earn points and help others
