Question about ASUS PCH-DL Motherboard
Motherboard My pc wont boot up it powers on but there isn't any bios information or any thing showing on the display I have swap the mainboard and xenon processor but still unable to find the problem I would appreciate your help Thanks
  • dmsguru Feb 12, 2009
    Tried upgrading RAM previously to 1024MB from 128, PC booted but no mouse or keyboard response. Tried only 1 stick (512 MB). Same thing. After many different scenarios including going back to the original configuration, I don't get any beeps. Removed CMOS battery for 30 mins to no avail. Tried another cpu (800 Mhz) with various memory. Seems to be stuck in this non responsive mode. I am assuming I fried the mobo, but don't want to guess. Suggestions please.
How about your screen; is it good?
Your monitor cable, is it damaged?
Does the computer beep, to tell of booting progress?
Is the new MoBo really new? What about the video card?
Try different RAM. Bad RAM will not let a computer boot.
Try booting the MoBo out of the case: lay it out on wooden surface and plug in power supply and monitor, then turn on. Listen for beeps, HDD cranks. Also watch the screen.
Come back after doing these checks so we can isolate the problem.
Posted on Feb 21, 2008
D845GVAD2 no bios screen no beep no boot
Hello here is the intel homepage:
https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%C2%AE+845+Chipset+Family+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+D845GVAD2
Try to renew the power supply, with one you know is working.
I think that`s the problem.
The problem could ofcourse also be the mainboard itselves failing.
There is not much to do about that, other than renew the mainboard or buy a new pc.
Good luck
Apr 08, 2013 | Intel D845GVSR Motherboard
Acer 5570z wont boot to bios. LCD screen lights up. Hard drive is spinning, but nothing happens. Have two different motherboards and it does the same thing with both.
OK. So when you power the Laptop on, what display do you receive? What do you mean when you say, the LCD lights up? Do you recognize a backlight to the LCD or is there any information being displayed? What key are you pressing to load the BIOS settings?
Sep 19, 2011 | Acer Aspire 5500 5570-2609 Laptop
When i connect a pen drive to the usb port of my G31D M7 mainboard,a dialog box pops up,showing, ' This device can perform faster on connecting to a high speed usb port'. So i downloaded the usb...
If you're comfortable having a look at your BIOS screens, then have a look for an entry mentioning USB 2.0. See if it is enabled. If it isn't, enable it, save changes, and reboot.
You can usually get into BIOS by tapping the Delete key on your keyboard during bootup, but some motherboard manufacturers have different ones. Just read on the screen during boot up what button to look for.
Hope that helps.
Cheers from NZ
May 09, 2011 | Biostar Computers & Internet
We received system problem with no display...then we replaced mainboard.after replacing it ,when i switch it on display is coming but it is splitted into six...BIOS screen also like that.... i replaced...
If you go back to basics, it may show up the error.
Remove the hard drive connectors. Remove the RAM. Leaving a basic "empty" motherboard with just a video card or onboard video working, power it up. The mother board should POST. If it does, and ignore the BIOS whingeing that it has no toys to play with, I would say the mother board is OK.
Then add RAM and test again. Then add hard drives.
If the display shows multiple pictures, it is possibly set at the wrong resolution. With the machine basically working, now is the time to set up an 800X600 basic SVGA resolution. After that is should be a case of downloading the correct drivers for the hardware.
Hope that helps.
Jan 02, 2011 | Computers & Internet
I have a PCchips M701 that wont boot after long time I dint use.
It's unlikely that the BIOS itself has been "erased".
The BIOS is "software", recorded on a small "Eraseable Programmable Read Only Memory" chip.
It takes a piece of hardware, an 'EPROM-writer' to update the contents of the chip. Or, the BIOS can be updated by a "BIOS-update" from the manufacturer of the motherboard.
The BIOS has "settings" -- the battery on the motherboard should supply a "trickle" current to the chip that holds those "settings" -- like an alternator provides a "trickle" charge to recharge your automobile's battery.
Try using the "BIOS reset" jumper on the motherboard, to reset those "settings" to their default value, and then try to boot the motherboard.
Jun 10, 2010 | PC Chips (M925G) Motherboard
C500 Laptop won't come on power button just flashes
Have you tried attaching an external monitor when the LCD screen is disconnected from the motherboard? this connector is located under the keyboard strip – a piece of plastic just above the keyboard.
If it works, this way, then the video cable isn’t seated properly in the connector on the back of the screen. Plugging the video cable back in should fix the problem.
I don’t know how comfortable you are with taking apart laptops but I think that this information could be useful for you.
Source: http://www.asklaptopfreak.com/laptop-notebook-help/2006/08/08/laptop-powers-on-and-shuts-off-immediately/
Sep 28, 2009 | Compaq Computers & Internet
Recover BIOS d845gebv2 motherboard my motherboard does not boot.monitor displays intel desktop board in blue screen
Right after you power the computer on start tapping F2 rapidly on the keyboard until you are in the BIOS setup. When you are in the BIOS setup, check to see that the computer recognizes your boot device and that your boot order is correct. Also, if you have changed any jumpers on your mainboard; change the back.
Sep 19, 2009 | Intel D845GEBV2 Motherboard
System unable to boot and showing signs of motherboard audio device conflicts(device type realtek)
hi iasmeer,
-to just boot up without any sound device,
remove any soundcards from the PCI- slots, disable the onboard sound device in the BIOS!
It looks like you are facing IRQ conflicts, your computer cannot handle all the hardware devices installed.
to solve this,
in BIOS set IRQ management so that the BIOS handles the PCI devices(set everything to auto),
disable the plug'n'play-operation system option to prevent windows from doing the same thing again( it'll then just take the IRQ information provided by the BIOS)
now enable the onboard sound device and make sure you have all
the drivers for the onboard devices(sound, LAN-card etc.) fitting your operation system on CD or thumb-drive, boot up and install the drivers.
Restart and by chance everthing isO.K. by now.
if not, please come back with more information on the sound device(onboard or not) and the winversion, so we perhaps can find you the appropriate driver(if you don't have it on the CD you purchased together with the mainboard..?)
Good luck
Sep 07, 2009 | ASUS P5GC-MX FSB1066 Motherboard
DFI LanParty DK 48 Motherboard, LED Error Code: 88? Does not boot, LED displays 88.
From the manual - Code 88 is "There is no "88" definition on the Award BIOS code. (BIOS program executed the wrong process therefore showing the wrong POST code.)
1 of 2 problems:
1. The BIOS - Mixed-up BIOS data, which is fixed by resetting CMOS information
2. MB is defective. (NB chip may be defective.), which you have to RMA to manufacturer
Oct 22, 2008 | Computers & Internet
No boot or bios or display at turn on.
I had exactly the same problem with my kids PC last week, also an Asus on an AMD flatform. I reset the BIOS and clean install the OS and now its working fine. You have to reformat the harddisk, cause in my case it doesn't show its exact capacity when I it hooked it up as slave drive with my own PC. Maybe a virus did it.
Apr 07, 2008 | ASUS P4C800 Deluxe Motherboard
ASUS PCH-DL Motherboard Logo
104 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
