Question about Garden
I am building my own extention and the regulations say I need to instal a cavity tray for the windows. What is this for and how do I do it?
    Sniper:
  • 82 Answers
The purpose of a cavity tray is to deflect moisture that has seeped through the external layer of brick or mortor back out of the property via the tray. All bricks are porous to different levels (you can tell from the specs how porous).
good explanation here: http://www.lpg-portable-heaters.co.uk/conservatory/cavity_tray.htm
Cavity tray standards information is here http://www.cavitytraystandards.co.uk/viewarticle.asp?id=18
If this helps please leave feedback, if not let me know and I'll try and help some more!
Posted on Feb 04, 2010
I need to get a drawing or schematic diagram for 1992 Capri power windows
You do not restring the cable, it is stretched and that is why it came off, buy a new regulator.
Sep 21, 2016 | Cars & Trucks
What is the cu ft, wattage, size, conventional oven yes or no, all the specs ect of the Kenmore mircorwave model #721.80833500
From the factory manual here:
SPECIFICATIONS
Rated Power Consumption ..............1700W maximum (Microwave oven+Cook top lamps+Ventilation fan)
Microwave Output ...........1100W (IEC60705)
Frequency ....2,450 MHz ±50 MHz
Power Supply .................120 VAC, 60 Hz
Rated Current ................14.5 Amp. (Microwave oven+Cook top lamps+Ventilation fan)
Magnetron Cooling .........Forced Air Cooling
Rectification .Rectification Voltage Double Half-Wave
Door Sealing ..................Choke System
Safety Devices ...............Magnetron Thermostat: Open at 145 °C ±5 °C
Close at 60 °C ±5 °C .....................Oven Thermostat: Open at 110 °C ±5 °C
Close at 0 °C ±5 °C ......................Fuse(20A)
Magnetron ......................2M282J (Toshiba)
Cook top Lamp ...............130 V, 35 W (Halogen)
Cavity Lamp ...................130 V, 35 W (Halogen)
Timer ..............................Digital,up to 99 min.(in each cooking stage)
Tray ..............Tempered Safety Glass
Overall Dimensions ........2915/16"(W)x167/16"(H)x153/8"(D)
Oven Cavity Size ...........231/2"(W)x10"(H)x141/2"(D)
Effective Capacity of Oven Cavity ....2.0 Cu.ft.
Accessories ..Owner 's Manual &Cooking Guide, Installation Manual,
Exhaust Adapter, Exhaust Damper, Mounting Kit and Filter,
Rotating Ring Assembly, Glass Tray, Metal Rack, Guide Tray.
Jul 09, 2011 | Kenmore 80809 Microwave Oven
How hard will it be to replace the window motor, driver side, of a 2002 Chevy blazer? Do I need special tools to do the job?
Motor Replacement - Power Window
Removal Procedure
Be very careful
Hope this helps
Caution: Do not attempt to service the regulator motor withoutreleasing the counterbalance spring tension. The regulator lift arm isunder tension from the counterbalance spring and can cause personalinjury if the motor is removed from the regulator.
  1. Remove the window regulator.
117423422
  1. Drill a hole through the window regulator and the sector gear.
117423423
  1. Install a bolt and a nut through the hole in order to lock the sector gear in position.
  2. Drill out the rivets that secure the power window motor to the window regulator.
  3. Remove the power window motor from the window regulator.
Installation Procedure
  1. Install the power window motor to the window regulator.
117423423
Important: Remove the nut and the bolt that were used in order to secure the sector gear in position.
  1. Install the rivets in order to secure the power window motor to the window regulator.
  2. Install the window regulator.
Jan 01, 2011 | 2002 Chevrolet Blazer
How to remove the window driver side of toyota corrola 1988
Door Glass and Regulator - REMOVAL & INSTALLATION
Front Door
  1. Disconnect the negative battery cable.
  2. Remove the front door panel to gain access to the regulator assembly.
  3. Remove the service hole cover.
  4. Lower the regulator until the door glass is in the fully open position.
  5. Remove the two glass channel mount bolts.
  6. Pull the glass up and out of the door.
  7. Unbolt and remove the inside door panel frame if so equipped.
  8. If equipped with power windows, disconnect the electrical connector.
  9. Remove the equalizer arm bracket mounting bolts.
  10. Remove the window regulator mounting bolts and the regulator (with the power window motor attached) through the service hole.
To install:
  1. Coat all the window regulator sliding surfaces with multi-purpose grease.
  2. Place the regulator (with the power window motor) through the service hole and secure with the mounting bolts. tighten the bolts to 48 inch lbs. (5 Nm). Attach the power window harness if equipped.
  3. Place the door glass into the door cavity.
  4. Connect the glass to the regulator with the channel mount bolts.
  5. With the equalizer arm, raise the glass to the almost closed position and make sure that the leading and trailing edges of the glass are equally distant from the top of the glass channel. If not, adjust the equalizer arm to achieve an even fit.
  6. Install the service hole cover.
  7. Install the door panel and reconnect the negative battery cable. Check window and door for proper operation.
Hope helps (remember rated and comment this).
Aug 25, 2010 | 1988 Toyota Corolla 4 Door
How to change out a window regulator on a 2003 town and country
First you have to remove the door trim there may be screws by the inside door handle and the armrest that have to be removed, also at bottom of trim. Once you have unscrewed the door trim pull trim away from door and undo all electrical connections neccessary. In some vehicles removal of the speaker may be required. Remove insulation material affixed to door to allow access to door cavity. You will need to wedge, tape glass to keep from falling. Remove bolts that hold window regulator to door and glass some of the newer Chryslers may have a locking clip that hold window to regulator remove and separete from glass. remove regulator to the opening and install new one
Oct 22, 2009 | 2003 Chrysler Town & Country
Electric windows don,t move up or down i checked all the fuses i cold find and they all work
Listen for motor when depressing switch, if you hear the motor then you have stripped window lift gear. They sell replacements which are often not necessary as there are 3 small nylon spacers that can be used to solve the problem, these will save you approx $30 per window. The teeth on the lift gear seldom strip out and often, you'll need little more than the 3 spacers to fix the problem. The autoparts store will try to sell you a kit which contains the gear and 3 spacers, if you swap just the gear and do not use the spacers, you will end up with the same problem again.Point is, you do not need to spend $30 on the kit, rather, you can located just the spacers in the self help section or at Lowes. Use the spacers as a reference if shopping for nylon spacers at Lowes. At a savings of $30 per window, it is worth the effort..
When you remove the electric motor, check to see if the cables for the regulator are intact. A visual inspection is an easy way to check if there is a problem. An important secondary measure is to have someone move the window up and down while you observe the drum in the regulator which the cables are wound around. If this operates smoothly, then all you need do is add the spacers to the lift gear and reinstall the motor..
If you need a new regulator, you will need to remove the doorlatch, this will give you access to one of 4 rivets that need to be drilled out to remove the regulator.
There are 2 rivets at the bottom of the door, 2 rivets inside the door cavity where the regulator attaches to the window, there are also 2 nuts at the top of the door, they are recessed but easy to spot. Drill out the 4 rivets, the 2 for the window are tricky to reach but once you remove the handle you will have access to the 4th. Do not drill out the 3 rivets around the motor, there are torx screws that you will remove instead.
Once all 4 rivets incuding the 2 rivets holding the window, the 3 torx holding the motor to the bracket and the 2 nuts holding the regukator are removed, you must pop the window out of its track then remove the defective regulator through the opening on the inside of the door. Do not try to lift it out of the top of the door. Install new regulator then pop window back into track and secure glass to regulator. You can reuse the 2 nuts you removed and you can use 4- 1" nut and bolts with some thread lock to secure the reg and glass, these will be used in place of rivets to install new reg. (If the reg doesn't include new nuts and bolts)
Sep 05, 2009 | 1992 Mercury Grand Marquis
Installing power window on 1993 toyota camry
Take the door panel off. Disconnect the window and tape it up. Remove the regulator out off the door cavity.
Jun 06, 2009 | 1993 Toyota Camry V6
HOW TO GET WINDOW OF A 2002 WINDOW REAR PASSENGER BACK ON TRAC
sounds to me like you may have a broken window regulator. Does the window go up and down still? reason I ask is cause I had a simaler problem with my pass. fr. door window (went down and never came back up) turned out to be a broken cable assem. in the regulator (cable driven design on late model '02's (JAN '02) build date and later) "early" models (JUNE '01-DEC.'01) used "steel track" regulators, an "m' fr'" to remove and install, mine turned out to be a "late" model ( FEB.'02) build date ( thank God!). Anyway, let me know whats up with it if you havent already fixed it. Good luck!
May 18, 2009 | 2002 Ford Explorer
Replace regulator on driver's side window of a 2005 Sunfire
Depends, Front or rear door, power or manual regulator?
Here is the front side/power
  1. Lower the window to the three quarters down position.
  2. Remove the door trim panel.
  3. Remove the water deflector in order to access the window regulator.
  4. Remove the window to regulator nuts (4).
  5. Push the window to the closed position and tape in place.
  6. Disconnect the regulator electrical connector.
  7. Removed the power window regulator bolts (3).
  8. Drill out the power window regulator rivets (2).
  9. Remove the power window regulator (5) from the door.
Feb 09, 2009 | 2002 Pontiac Sunfire
i dont know of any car window regulator that is attached to the outer door skin. generally there should only be 5 mounting screws holding the regulator in the door cavity. 2 on the top 2 on the bottom and one near the regulator motor. when these are sent to the manufacture the lifting plates that hold the glass are in what is called a shipping position. which allows them to install the regulator in the door and then attached the glass. this position is generally half way up the guide rail. so picture the window only being open half way. look at the regulatr that you bought. the position of the lifting plates (glass attachments) is where the regulator inthe door should be in order to get it out. good luck
Dec 14, 2008 | 2005 Pontiac Sunfire
Garden Logo
32 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
