Question about Jensen XA2150 Car Audio Amplifier
Is this amp enough to power a 15 inch sub - Jensen XA2150 Car Audio Amplifier
  • 24 Answers
No it will not be able to it will burn up in a matter of min. its only capable of 75 watts per chanel maybe 200 watt bridged its a good 2chanel door speaker amp
Posted on Feb 06, 2010
4 Suggested Answers
SOURCE: most power out of amp w/out blowing subs
you may only be able to get but so much out of the subs. If you turn the bass down a little so the that you dont drive the subs so hard you may get a little more wattage out of them
Posted on Apr 09, 2009
  • 173 Answers
SOURCE: digital audio dhc 2754
no thay need 1000 rms each i would go with a hifonics bxi2010d amp from vminnovations.com for around $300
Posted on Apr 03, 2010
  • 256 Answers
SOURCE: I Have a Sony Xplod 800 watt amp and 2 12 inch Sony Xplod subs
You should definately bridge them. Firstly, lay the 2 speakers face down next to each other. Note the connections +- +-. The first + will go to the amplifier. The next terminal(-) will be connected to the next speaker(+). Take the last(-) and connect to amplifier. Please note that your amplifier has a bridge section which is normally the first + and the last- on the two channels. Connect your woofers on the bridge.
Posted on Jun 09, 2010
Need a wiring diagram to hook up two 10 inch subs and 15 inch sub a kicker 250.1 amp
Series or parallel? Single, dual voice coil? I'm not sure you have the right size amp for all 3 speakers. And I wouldn't wire the 10's together with the 15. The larger sub is going to have a larger power demand. You could wire the 2-10's together on this amp, and get another mono amp for the 15.
Oct 02, 2014 | Car Audio & Video
Signs of a blowed 15 inch subwoofer
Melted voice coil? Short circuited voice coil due to overload? does your amplifier work properly? Is the (-) properly grounded? If the SUB is in working condition and there is nothing wrong with the amplifier.
1) The amp is not powerful enough to run the sub
2) The amp is not properly grounded or powered
3) Remote Sensor wire is not connected
4) RCA Cables or Hi - input sensors are not connected
Check out the installation to verify or the sub may be damaged
Apr 25, 2013 | Tsunami Car Audio & Video
I have 2 15 inch L5 solo baric subs and need a amp?
the 15" l5 is rated at 750 watts rms so i suggest you get an amp with atleast that much power because if you get a amp weaker than that you run the risk of clipping your subs and blowing them
Jul 15, 2010 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
I have two 12 inch rockford p1 punches powered by an 800 watt sony explode amp (2 Channel) and i want to install another 15 inch kicker with a 1200 watt amp not sure the model, i got it from a friend and...
I have a similar setup & I just run the second amp straight off the other amp by running positive & remote wires directly from 1 amps positive & remote inputs to the others amps inputs. But my head unit has RCA inputs, (sub in & front & rear inputs) so from my 4 channel amp I run 2 6 inch alpine S's to the front to the front RCA inputs of the head unit, & 2 Pioneer 440w 6x9 inch speakers to the rear inputs. & my 800w 12 inch sub from my 2 channel amp to the sub woofer inputs on the head unit. Has blown my eardrums for nearly 12 months now great stuff! Hope this has helped
Mar 12, 2010 | Sony Car Audio & Video
I have a rockford fosgate punch 150 and it will power a small 5 1/4" speaker, but doesn't seem to push my 15" subwoofer. I am reading 4ohms across the sub so I'm assuming that it is fine and that there is...
amp is way too small to power a 15 inch sub. But you should get some sound out of it, not silence. You can use a 9 volt battery to test your sub, if the sub pops when the 9 volt is placed across it's terminals then it's ok. If it does not pop then your sub may be bad, or the coil may be frozen. (It can still read 4 ohms if frozen). If your amp powers smaller speakers fine, you know it's not the amp. If the sub tests ok, then verify your connecting it properly to the amp's correct bridging terminals.
Jun 12, 2009 | Rockford Fosgate Punch 150S Car Audio...
Power requirement sub zero 532
115 volts on a 15 amp circuit
May 19, 2009 | Sub-Zero 632 / S
Problem when hooking two 12 inch subs to one amp
the amp is no where near strong enough that sound you hear is called hard clipping and it will destroy your subs in minutes. depending on what model JL subs you have I can sell you a better amp.
Dec 30, 2008 | Planet Audio VX602 Car Audio Amplifier
Digital audio dhc 2754
Mar 26, 2008 | Digital Audio 1000 WATTS HIGH CURRENT...
Is it enough
Audiobahn subs are not too powerful and they can not handle too much continuous RMS, be careful they will heat up and tear off the voice coils off ur subs. run about 100 - 150 RMS at 75 HZ to each sub and keep the gains at about 3/4 this way you will avoid blowing out your subs. It also depends on the amp? What kind of amp is it?
Let me know if you wish. Otherwise
Oct 21, 2007 | MA Audio HK4000D Car Audio Amplifier
Jensen XA2150 Car Audio Amplifier Logo
220 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
