Question about LG 32LC7D Television
32" 32lc7d after a few minutes, flickers, then goes dark.
Was on my computer using my 32' 32lc7d as a monitor through hdmi. After a half hour the screen started to flicker, then flicker faster, then went out. Sound is still working, with green light still on. I turned off the tv. minutes later turned it on. immediately i checked all inputs and they were fine. after a minute, the same process started over again. Letting the unit turn off and cool again then starting it up again, and it lasts a bit longer this time. Is there a specific part that is overheating that needs to be replaced? Does the tv have fans?
  • LG Master
  • 458 Answers
There are no fans in this model but it looks like either the backlights in the screen are breaking down after they have warmed up or a problem in the inverter board, again part of the driver circuit breaking down after a period of time. They inverter boards can sometimes be replaced seperatly but usually come with a new screen which if the backlights are at fault then the screen would need to be replaced.
Posted on Feb 04, 2010
Occasional odd coloring and backlight flickering
Please check it monitor color adjust button. If ok then you check it monitor cable if change possible then change it or power cable also proper connect. If not solved contact Good Monitor technician.
Thanks.
Feb 17, 2014 | Apple Cinema Display 23" HD Monitor
Dark screen and flickering on the laptop computer model pcg 61611L
I would check the GPU by connecting an external monitor before booting it, that will allow the external drive to automatically work.
Jan 02, 2014 | Sony VAIO Computers & Internet
P2770h monitor flickers. progressed into the monitor shutting down after a few minutes. the monitor power on light flashes in a slow dim.
Is this happening while your are playing games or you are doing a specific task? If not try to change your connectivity cable (HDMI or DVI)
Aug 28, 2013 | Samsung P2770H SyncMaster Widescreen LCD...
My Samsung screen flickers on powering on until it stops after a few minutes. what can I do? Thank you all.
Unplug it and let it sit for a half hour and plug it back in, or call the company themselfs with the 1-800 # they give you.
Jan 02, 2013 | Computers & Internet
I have a Dell Ultrasharp 1907FPV, it's a few years old. Whenever I start my computer, the moniter stays dark and the green power button does these quick flickers. Eash flicker cycle takes less then a...
You don't have a short-circuit. That would have blown the protections or even the monitor. Refer to the manual, that flashing light may be a code that tells you the problem. I don't think the repair would be expensive...
Nov 29, 2009 | Dell UltraSharp 1905FP 19" LCD Monitor
My screen only displays after 4 /5 hrs
Try a different screensaver.
Also look in the display properties by simply right clicking the desktop and clicking properties.
Then locate power management.
the initial seems to be a bad screensaver judging by the 20 minutes, but the 4-5 hours seems to be a sleep mode that bypasses the screensaver issue.
Jul 23, 2009 | Computers & Internet
KDS Computer Monitor loses video one half hour after booting up.
first, how long have you had it. if it has intergrated power supply,(does not have a big square box made onto the power cord) nine time out of ten your power converter/supply is going or is bad. return for a replacement. to the manufactuer not the store. they should replace it free of charge, if their honest. samsung has some models with this same problem.
Mar 18, 2009 | KDS K717s 17" LCD Monitor
Monitor flickers unless brightness is at 100%
Try monitor menu select Memory Recall and press that, should clear right up
Mar 08, 2009 | ViewSonic VA1912wb Monitor
Flickering then off
Problem is with Invertor Board maybe defective 2SC5707 transistors.
Samir
Jul 28, 2008 | BenQ FP71E 17" LCD Monitor
Dimension of image change when displaying clear or dark image
Same problem Picked up this monitor about half a year ago, a Viewsonic A91f+, and have been having some issues for a while now concerning what appears to be shifting in the monitor image, but that is about the best I can describe it as. It is most noticable when a large dark area meets a light area, like text or window edges. This "shifting" only occurs on the right side of objects and seems to show most often after I switch resolutions more than a few times, usualy due to gaming. Ive also noticed it happening from running random programs that dont require resolution changing/flickers but this happens FAR less often. -photograph of the effect- As you can see, its pretty subtle on a darker background, but Ive had no luck carturing it on a light one. Anyone have any idea as to what is occuring on this monitor and how it could possibly be fixed? Possibly an issue with magnets? For a while, I did have a small headset hanging off the the monitor on the side that the images "shift" towards, but even taking those off and away havent fixed it. Currently the only fix I have found for this is to shut my monitor off for 5-30 minutes, depending on how bad the "shifting" is when I find a time break long enough to fix it.
Jan 12, 2006 | ViewSonic G790 19" CRT Monitor
LG 32LC7D Television Logo
316 people viewed this question
Computer Repairing
Computer Repairing
