Question about AcerScan 620P Flatbed Scanner
Twain.dll error because the driver is for win98 and i want for xp crystal
  • 617 Answers
Posted on Feb 04, 2010
Testimonial: "twain.dll problem "
Scanner twain driver will not install
Dear sir,I am sory for your problem.Please format your oparating system i mean you install new windows.some times optical driver did not read properly data cab file,So hardware driver is not support properly.Windows xp SP3 is not complite version some messing.
Thanks You are success
Tareq
Aug 27, 2009 | Epson Perfection V300 Film Flatbed Scanner
The OEMCFG.dll on Samsung needed
GO TO SAMSUNG/SUPPORT.COM
TYPE IN YOUR MODEL# AND DOWNLOAD THE DRIVERS YOU NEED.
Jul 15, 2009 | Samsung SCX 4521F All-In-One Laser Printer
I need xp driver for Travelscan model 2300
The only website that has the XP driver for this scanner is driverguide:
Other Companies TravelScan Driver Summary
You will need to complete a free subscription with a valid email.
When you proceed to download chose download to hard disk if you want the free service.
Feb 13, 2009 | Syscan TravelScan 2300 Scanner
Twain Error
You will most likely find that the FAU (what the hell is FAU?!) cable that connects the lift-up lid to the lower part of the scanner has at least one of the eight wires within it fractured. This cable was made far too rigid to cope with the multiple number of times that you will be opening and closing the lid and it's a poor do from Canon that they allowed this to get through to production. I tried to obtain a replacement cable from the UK Canon service agents but was told, as expected, that it couldn't supply it. If you're a dab hand with small wires and a soldering iron, it's quite possible to make a repair and save a bit more of the world's resources from going in the dustbin and then buying another equally poorly made, expensive piece of ****, from China.
Dec 25, 2008 | Canon CanoScan 8400F Film Scanner
Twain drivers
The problem was with the scanner,it was not twain compliant
So the 2 ways left with me was :
1.Download twain drivers for my scanner and install it.
2.Use wia32.dll
I chose second option as i didnt found any twain driver for my scanner.
Hope this can help any one.
Aug 30, 2008 | Office Equipment & Supplies
TWAIN ERROR AND CANOSCAN LIDE 20 SCANNER PROBLEMS
Select your operating system and download the driver "TWAIN Driver - LiDE 20 Scanner Driver Ver. 7.0.3.1a_xp" and then download the software "Canoscan toolbox" ...here is the link:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=351&modelid=6624
Aug 04, 2008 | Canon CanoScan LiDE 30 Flatbed Scanner
Error
First I had to find out where the error message came from (scan in my case, see the description of my problem). Apparently Win XP, Me and 2000 have a security function that doesn't let you overwrite existing twain and/or twunk files.
So you have to install these files manually:
Search on the installation CD or in the unzipped downloaded full solution the folder setup\scan, there you'll find the file data1.cab.
Doubleclick it and extract the following files to a temporary folder:
F1922_TWUNK_16.EXE.096CD9AA_35CA_455C_ADCB_36EF6B7F7892
F1923_TWUNK_32.EXE.096CD9AA_35CA_455C_ADCB_36EF6B7F7892
F1928_TWAIN.DLL.096CD9AA_35CA_455C_ADCB_36EF6B7F7892. F1939_TWAIN_32.DLL.096CD9AA_35CA_455C_ADCB_36EF6B7F7892.
Rename these files to twunk_16.exe, twunk_32.exe, twain.dll and twain_32.dll respectively
Copy (and overwrite if necessary) them to the Windows directory (c:\winnt in my case)
Now you can re-install the complete HP software again, in my case it worked and I'm now able to fully use my CM1015 multi-function printer!
Dec 12, 2007 | HP LaserJet 3055 All-In-One Printer
TWAIN error
Here is an actual e-mail from a Canon tech regarding this problem:
Thank you for your recent enquiry regarding your Canon product
Please accept my apologies for the delay in contacting you regarding the
problems you have been experiencing with your CanoScan D646U.
I shall firstly answer your query regarding the TWAIN drivers. There are four
main TWAIN files that are pre-installed with Windows, TWAIN.DLL, TWAIN_32.DLL,
TWUNK_16.EXE and TWUNK_32.EXE. These are included with the scanner drivers to
ensure that a compatible version of the files are installed, otherwise the
scanner will not work. During installation these files are checked for and, if
a later version is already installed, the versions from the disk will not be
installed. I can assure you that the scanner driver will work OK with version
1.7 of the TWAIN drivers.
For the scanner to communicate correctly the Still Image Services needs to be
running in the background. To check this please open the Control Panel and look
under Services in Admin Tools. Please check to ensure that the Still Image
Service is running correctly.
If all this is OK, I would recommend removing the driver in the following way.
With the scanner still connected go to Device Manager. Under Imaging Devices
right click on the CanoScan D660U and select uninstall. After this please
disconnect your scanners USB lead and remove the rest of the driver using the
DELDRV utility. Before reinstalling the driver you must restart your PC and
then reconnect the scanner.
If there are still problems please check that the driver has installed
correctly. The following files should be shown in the driver section when you
look at the scanner properties in Device Manager.
C:\WINNT\SYSTEM32\D064UCPL.DLL
C:\WINNT\SYSTEM32\D064UFW.DLL
C:\WINNT\SYSTEM32\D064UFW.INI
C:\WINNT\SYSTEM32\D064UFW.PLG
C:\WINNT\SYSTEM32\D064UUD.DLL
C:\WINNT\SYSTEM32\DRIVERS\USBSCAN.SYS
C:\WINNT\SYSTEM32\SPOOL\DRIVERS\COLOR\CNS60N.ICC
C:\WINNT\SYSTEM32\SPOOL\DRIVERS\COLOR\CNZ005.ICC
C:\WINNT\SYSTEM32\UCS32P.DLL
C:\WINNT\TWAIN_32\D64U\CANOIT32.EXE
C:\WINNT\TWAIN_32\D64U\CISDS.DS
C:\WINNT\TWAIN_32\D64U\CSUI.CNT
C:\WINNT\TWAIN_32\D64U\CSUI.DLL
C:\WINNT\TWAIN_32\D64U\CSUI.HLP
C:\WINNT\TWAIN_32\D64U\D064UA.DLL
C:\WINNT\TWAIN_32\D64U\D064UUI.DLL
C:\WINNT\TWAIN_32\D64U\IMGENH.DLL
C:\WINNT\TWAIN_32\D64U\IOP.DLL
C:\WINNT\TWAIN_32\D64U\ITLIB32.DLL
C:\WINNT\TWAIN_32\D64U\LTKRNION.DLL
C:\WINNT\TWAIN_32\D64U\README.TXT
C:\WINNT\TWAIN_32\D64U\SCANINTF.DLL
C:\WINNT\TWAIN_32\D64U\SYSERROR.EXE
C:\WINNT\TWAIN_32\D64U\TPM.DLL
All of the files mentioned above that are listed as being in the TWAIN_32\D64U
folder are the exact files that should appear in that folder if you look in
Windows Explorer.
A further cause of the TWAIN error occurring is if there is a conflict with
another TWAIN compliant device, such as a Digital Camera or scanning device
(including Multifunctional devices. If you have such a device installed try
removing its software before reinstalling the scanner driver.
We hope this information is of use to you. However, should you require any
further technical assistance, please do not hesitate to contact us quoting your
Incident number.
To contact us via email, click on the following link:
https://self-service.canon-europe.co...ss.cgi?LANG=en.
Note: Please do not reply to this email using your 'REPLY' tab.
Kind Regards,
Gavin O’Mahony
Product Support Specialist
RCC UK
Oct 27, 2007 | Canon PIXMA MP150 All-In-One InkJet...
AcerScan 620P Flatbed Scanner Logo
160 people viewed this question
Top Acer Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
color wheel light...
Are you an Acer Office Equipment and Supply Expert? Answer questions, earn points and help others
