Printer I have a printer HP 4600 dn and it is spilling the magenta on the paper when it is printing can you help me
HP toner? Third party? It could have been damaged in shipping, or it may be an expired toner. Return if new to vendor. Demand currently dated supplies.
Posted on Feb 20, 2008
How do i adjust the margins from the printer? HP color laserjet 4600 dn printer
Usually in "page preferences" in the file drop-down bar. Then use "print preview" to see if the page looks OK.
Mar 22, 2011 | HP LaserJet 4600dn Color Printer
My network laserjet 4600 only comes out black not color both when printing and just a information page from the device
http://h10039.www1.hp.com/cpso-support-new/pq/4600/home.html
Try the above troubleshooting steps for each color page that prints out for test pages.
Try to click on 'magenta' for instance, and follow the leads to a solution for your black only print problem.
Feb 10, 2011 | HP LaserJet 4600 Printer
HP CP2025 Heavy smears of magenta appear down the right-hand side of paper. Have tried restart and changing paper weight.
It is due to spilled magenta toner leaking from side to the toner cartridge. Take the cartridge out of the printer and clean it. Clean visible inside of the printer. Shake the cartridge lightly in horizontal position to evenly distribute the toner inside the cartridge and put it back. The issue sould be fixed after some prints.
Good Luck!
Appreciate generously, if the solution could have been of any help!
CreativeTECH
Dec 23, 2010 | HP Laserjet Cp2025n Printer
HP color laserjet 4600 dn printer How do I set
From the control panel of the printer, do the following:
1. arrow down once to highlight the 2nd item: "paper handling".
2. press the check button (turquoise color) to select this option.
3. arrow down 2x's until you highlight the "tray 2 size".
4. hit the check button to select this item.
5. You should see a size that is "letter" and there should be a ' * ' asterisk which means that is the default setting. If you see other paper sizes as well, then arrow up or arrow down to highlight the preferred size, and then press the check button to insert the asterisk ' * ' which will set that as the default.
6. you change the paper type as well as paper size for the other trays in the same fashion. Most HP printers will select paper according to the SIZE as well as the TYPE. The printer can "sense" the paper size in the paper cassette tray by the stops that hold the paper. Therefore the printer will choose that paper based upon the SIZE and what you define as its type.
Sep 24, 2009 | HP LaserJet 4600dn Color Printer
Need to have 4600 laser printer in just black ,because of broken
Sorry, my friend, there is no way to force it go B/W and override the error message.
Sep 09, 2009 | HP LaserJet 4600dn Color Printer
Printer hp 4600 dn consumes a huge quantity of toner material especially magenta and black. Toner is exhausted after 3000 copies with mostly copies without pictures. Can it be possible that starting the...
the toners are rated for a certain number of pages based on 15% coverage on the page. print a supplies usage page from the control panel on printer if available to show you how many pages you printer and what the coverage was.
calibration does use ink, but should not be that much.
If you are using non-HP toner, this may be why you don't full life out of them. Try HP toners and see if problem remains.
Sep 02, 2009 | HP LaserJet 4600dn Color Printer
HP 4600 has magenta and cyan marks on back of printouts.
YOU NEED TO REMOVE THE CARTRAGES AND THEN UNPLUG THE PRINTER. CLEAN THE INSIDE WITH RUBBING ALCOHOL AND SOME Q-TIPS.YOU HAVE EXCESS INK ON THE INSIDE OF PRINTER. THIS IS WHY IT IS GETTING ON THE BACK SIDE OF YOUR PAPER. HAPPY NEW YEAR TO YOU.
Jan 06, 2009 | HP LaserJet 4600dn Color Printer
Magenta cast over whole page
IF IT WERE A 4600 SERIES THAT WOULD BE THE DC CONTROL BOARD
Jun 22, 2008 | HP Color LaserJet 2600n Printer
Hp 4600 no cyan printing
Firstoff, if you have tray 1 set to "any size" & "any type" they had problems with it going into calibration to frequently. If you upgrade the firmware this will take care of that. As for no Cyan, check the scanner interlock to insure it is opening the scanner cover. You could also go into diagnostics and disable cartridge check and swap the cartridges around, ie. cyan & magenta, run the print quality pages and see if the problem follows the cartridge. It could also be HV power supply.
Jun 18, 2008 | HP LaserJet 4600dn Color Printer
96 people viewed this question
k24674
jasbo
jasbo
