Question about Kenmore Dishwashers
A Kenmore model 15522000 type 280-1 dishwasher will not drain
A Kenmore model 15522000 type 280-1 dishwasher will not completely drain at the end of the cycle. I do not have a manual and do not know how to do the basic trouble shooting for this problem.
I scooped out the water and found a spoon jammed in the drain area. Works like a charm now.
Posted on Feb 05, 2010
Model 665.13929kq11. Why isn't it draining completely?
Dishwasher is draining slowly , and not completely ... - iFixit
https://www.ifixit.com/.../Dishwasher+is+draining+slowly+,+and+no...
iFixitJun 26, 2014 - I have a kenmore dishwasher (about three years old) ! ... with a solid plug in the drain tube for situations where a dishwasher isn't connected.
My Kenmore Dishwasher Won't Drain and is Leaking- How ...
? 5:35
https://www.youtube.com/watch?v=u7uaA2NZKl0
Nov 14, 2011 - Uploaded by mkbrennan13
This is a video to help someone fix their dishwasher. It's a How to fix your dishwasher that won't drain. If your dishwasher isn't draining and ...
How to fix drain problem with kenmore dish washer - YouTube
? 6:46
https://www.youtube.com/watch?v=ZMPXn6XgRkk
Aug 16, 2010 - Uploaded by itdatanow
Kenmore dishwasher would not drain. ... How to fix drainproblem with kenmore dish washer ... Is Your Dishwasher DrainInstalled Properly?
Dec 12, 2015 | Kenmore Dishwashers
Kenmore 15652 model. won't drain
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller.
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat.
Hope this helps... Please post back for any further assistance.
Daniel
Apr 22, 2011 | Kenmore 24 in. 15652 Built-in Dishwasher
Kenmore dishwasher 15522000 will not drain at end of cycle I took off front lower panel removed clamp at drain and water is barely dripping
Hi
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Jan 07, 2011 | Kenmore Dishwashers
Dishwasher will not drain completely
dishwasher will not drain.kenmore model.
I have taken it apart can not figure our how to take out last plastic part a bowl shaped black plastic.
Mar 22, 2009 | Jenn-Air 24 in. JDB1250 Built-in...
Hello Tom,
Glad that you were able to find something out of place in the check valve ( like the gasket) which in turn was restricting the ball in that check valve from being in the right position. I'd be willing to bet that your problem is solved..
Regards,
Rick
Dec 01, 2008 | Whirlpool Dishwashers
Kenmore Ultrawash QuietGuard 3 Dishwasher not draining or rinsing
Not draining may either need new drain motor. or something is blocking the drain pipe.
Spots on dishes means you are using to much detergent or the wrong kind of detergent.
Your owners manuel should tell you what type to use.
Nov 18, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Hi Claire,
Are you using rinse aid?
that may help with the film.you may also have stuff down in the trap causing the water to drain slow.
Nov 05, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore dishwasher drainage problems
I have the same model -- and USED to have the same problem! We tried lots of things (bleach in the water, etc.). . . . and finally discovered it was a simple, standard concern. The drain tube from the dishwasher to the sink pipe was clogged with grease (looked like lard).
The way i knew it was clogged is that I disconnected the tube from the sink pipe, and tried to blow through the tube. It wouldn't let any air get through.
So once the dishwasher was empty of water (i removed the tube, drained into a big pan, and bailed a lot), we disconnected both ends of the tube.
With the tube in a trash bucket, I blew from one end (cleaned it off a bit first), and the "lard" came out. Drains beautifully now -- and did not require a plumber.
If you do this, be SURE you place the tube back ON the fittings EXACTLY in the same position and shape as before. This makes there are no new kinks or bends introduced into your drain tube.
Hope this helps.
E-mail if further questions!
Jonathan
May 30, 2008 | Kenmore 24 in. 16352 / 16354 / 16359...
Dishwashers Logo
752 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
