Question about Canon imageCLASS D880 All-In-One Laser Printer
We have two canon image class D880 printers in our office. The ADF feeder will not pick up the paper and feed it through the scanner section. We have about 6,000 and 9,000 copies on these. I have cleaned the ADF rollers with Alcohol and it will work for a day or so. Is there a part I can replace to eliminate this problem?
  • 150 Answers
Never clean feed rollers with alcohol. Lift the automatic doc. feed cover up. You will see 2 grey rollers. Clean them with 409,fantastic or water. The rollers are available. A pain to put in. Steven
Posted on Feb 05, 2010
What does document in ADF mean
Hello, Thanks for using Fixya today.
ADF is auto document feeder, used to feed a document into a scanner or printer. The error is associated when there is a document or paper jam at the document feeder, or paper trail.
This would happen mostly on scanners and all in one printers after witch a document is left in the feeder or there was a paper jam occurrence. We hope this answers your questions today?
Please contact us again if you still have a issue, or need help with anything else.
Thanks for using Fixya.com
Best regards,
Rulds2008
Jun 14, 2011 | Canon PIXMA MP830 All-In-One InkJet...
I have canon 320 MX, and I recived all the time a messege - document in the ADF, I press OK , then I recive a second messege - close the feeder cover and eject the document.NO documents are in the printer...
Hi!
look more closely on the ADF section, if there is no paper remains then you must need to check if the paper feed sensor is not press down or stuck. This sensor, a small plastic latch slide is responsible for detecting load paper in the ADF section. Check if there is something that keeping it stuck in that position. You will need to open the cover of the ADF section to do this.
Hope it works.
Oct 02, 2010 | Canon PIXMA MX310 All-In-One Printer
The feeder in my office copier is not feeding the paper thru it. It only copies if you manually put it on the glass.
Hi, you need to open the adf cover, check for any leftovers of paper or clips, or... also clean the pick up and feed roller with alcohol by piece of fabric.
Also have on mind that the feeder is only for plain paper usage.
Sep 08, 2010 | Canon imageRUNNER 1023iF Black and White...
What to do window says check document open ADF?
That means: open adf cover ( auto original feeder ) and remove jamed paper.
Probably adf needs some maintenance, clean rollers.
Jul 05, 2010 | Canon imageCLASS D880 All-In-One Laser...
Canon Imageclass D880 automatic document feeder problems
Clean the ADF rollers and pad with alcohol.
Check to see if your ADF has done over 90 000 copies and if it has, change the ADF pick up assembly only.
Good Luck
Oct 19, 2009 | Canon imageCLASS D880 All-In-One Laser...
Image class 780 ADF jamming problem
The problem could be with the ADF rollers. First open the top ADF cover and clean the rollers gently with some isopropyl alcohol on a soft cloth, let dry for about 10 minutes. Also check to see that the top seperator pad is not worn out. This pad should be cleaned as well. If this does not work the ADF rollers and the seperator pad will have to be replaced.
Sep 08, 2009 | Canon imageCLASS D880 All-In-One Laser...
Top feeder not working MF6550
One or both of the ADF hinges are bad. The ADF cover doesn't close all of the way causing feed failure of the original and shading on the side of the copy because the scanned original is not fully contacting the **** exposure glass on the front operators side.
Feb 27, 2009 | Canon imageCLASS MF6550 All-In-One Laser...
Adf
this is a dealer only item, if it's not pulling paper and you can see the feed roller turning,you may just need new feed rollers,but you would still need to order those from you local canon dealer
Sep 18, 2008 | Canon ImageClass D880 Copier
Feed will not take papers
your feeder is having problem.get the printer serviced
Apr 03, 2008 | HP Scanjet 8290 Digital Flatbed Flatbed...
Will not copy
If the paper isn't feeding in the ADF (automatic document feeder - upper paper feeder) then the ADF roller assembly will need to be replaced. Try a copy on the flat glass area. If it work, then it's the ADF, If not then the upper scanner assembly with have to be replaced.
Apr 28, 2007 | Canon imageCLASS D880 All-In-One Laser...
Canon imageCLASS D880 All-In-One Laser Printer Logo
360 people viewed this question
old marine
old marine
