Question about Akai LCT2721AD 27 in. LCD Television
My Aksi LCT2721AD LCD tv does not turn on.The power light is on,no picture.I looked real close and no pic, so it's not the back light.The built in DVD doesnt accept dvds.I opened it up and no leaking caps, or even slightly cracked capacitors /condensers,I looked real close.Nothing visibly wrong with the power board.No warranty and I live hundreds of miles from repair man.Please help. summerlander2005@yahoo.ca
  • summerlander Feb 04, 2010
    No sound either, Just a power light on.
  • 111 Answers
Do you have sound?
Posted on Feb 04, 2010
Turn tv on, audio but only flashing pic, then turn off and turn back on same thing, 3rd time have full pic
This problem will occur under two circumstances
1, Faulty electrolytic capacitors in the power supply board
2. Faulty back light inverter board.
Fist of all check is there is any faulty capacitors in the power supply board. If you find or not try to replace all the electrolytic capacitors in the power supply board. In most cases this will solve the problem. I have added the some video which will help you
The second one is the inverter back light inverter board. There is no repair possible with the inverter board. You have to replace the board with a new one. As you didn't mentioned any model number of your tv its not possible to attach a picture of the exact inverter board. The back light inverter board will look like one in the picture
Ajin
Feb 09, 2012 | Sanyo 42 in. LCD TV
Akai lct2721ad The TV was working fine when we turned it off and now it won't come back on. No red lite. The tv has had very little use. Is there a master power switch that might be tripped. thank...
Check the power source?Yes.Try tv unplug,replug it back an hour later.The tv now resetting it back to factory setting.The tv should work now.Not,than the power supply board is dead.That the board,where the power a/c cord plug into.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacemrnt.
Sep 08, 2010 | Akai LCT2721AD 27 in. LCD Television
LCD TV Akai 27" NO PICTURE, NO SOUND, JUST A POWER LIGHT
Could be an open internal fuse or power supply failure
Mar 26, 2017 | Akai LCT2721AD 27 in. LCD Television
Akai LCT2721AD TV just has a red light on. it wont power up at all.
I had the same problem with mine. I took the back off of it and found 3 blown 1000uF capacitators in the power supply. I replaced them and now it works fine. Cost me about $1 compared to $100 at the shop.
Nov 20, 2009 | Akai LCT2721AD 27 in. LCD Television
Lcd tv has no picture
The inverter pcb inside the tv has probably gone bad. The inverter lights the small fluorescent tubes behind the panel for back light. Take a bright flashlight and hold it close to the front and see if there is any picture. You have to be patient with this method and look real close. If you see the picture it is definately the inverter. Common problem. Thanks
Oct 28, 2009 | Sharp 32C-240 32" TV
TV turns on sound but no picture
Turn the tv on and get close to it and see if you can see ghost images. These will be normal images but will be very faint and look like shades of grey. You don;t want to do this in real bright direct light but a normal light or day light works. You can also hold a flashlight up near the edge and see if makes it easier to see.
If you can see an image and have normal sound then your problem is the back lighting system. This can be the lights bulbs or leds or the power supply for them. Repair cost should be under $150. I don't think you have any warranty left but check ASAP if you do as it may not last much longer.
If you have no picture and no sound then this is usually a problem with the receiver section. Can't suggest what cost would be as it can range from cheap to a bunch depending on what is wrong.
As always with any lcd tv or monitor make sure you know what a replacement is worth before you spend repair money. Repairs can sometimes cost close to what a new tv will.
Sep 12, 2009 | Soyo DYLT032C 32 in. LCD Television
Akai LCT2721AD - Power on - Sound on - Black screen (No Picture)
Ive reviewed and assisted anoter person who had a similar problem that caused the tv to malfunctioin simialr to yours. After doing some short research and the other person who had the problem, came to find out that 4 resistors failed on the main board causing this to happen. It also could be the backlight of your Plasma screen tv, or your Plasma screen itself is shot.
I would recomened that if you have no active warenty to give a visual inspection of the Tv, via removing the rear black plastic pannel to see if any of the corisponding chips have any burn marks or excessive heat stress. these items seem to be failing about the 12 month mark
Good luck
May 12, 2008 | Akai LCT2721AD 27 in. LCD Television
AKAI LCT2721AD On/Off Problem
My Philips LCD TV had the same problem. If your Voltage system is 110 AC till 127 AC and no transformator, then it is probably caused by one of the 4 main transistors, which are likely not originalfrom AKAI, but made in Malaysia or closeby there.
My TV works perfectly after 1. Replacing the burned or semi-burend transistors (in the back panel) 2. After repair (=US 60 plug the TV in a outlet from transformator set to 100 V.Good Luck!
Apr 15, 2008 | Akai LCT2721AD 27 in. LCD Television
Akai lct2721ad flashing red light
I would bet on the power supply....these (and other Akai LCD) are notorious for filter capacitors. Look for electrolytic capacitors with a dome-like bulge on the top of them. They are usually located at the top of the power supply board where the power output lines run out.
Hpe this helps you out....
Sep 23, 2007 | Akai LCT2721AD 27 in. LCD Television
Akai LCT2721AD 27 in. LCD Television Logo
366 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
