Question about Haier HSW02C
The freezer in my Haier HSW02C is not working properly, and it is leaking water.
  • 3,230 Answers
Well first of all let us know that from where it leaks - from the bottom front of the refrigerator or freezer door, from the back of the refrigerator, from the inside ceiling of the refrigerator, from the inside back wall of the refrigerator
Underneath the front of the refrigerator. Please reply for mode help or information.........
Thanks
Posted on Feb 04, 2010
Model # hsw02c compressor gets hot hear clicking sound but wont cool
Sounds like bad start device (relay/overload) Good Luck!
Apr 14, 2014 | Haier HSW02C
Haier Refridgerator
Your freezr drain is blocked or frozen. What you need to do is remove the ice rack then in the front of the freezer you will see 2 or 3 plastic plugs on the freezer floor remove the plugs and there might aso be some 1/4 inch screws farther in on the freezer floor. also remove the back of the back of the freezr and then lift out the bottom floor. under the evaporator you will see a lot of ice or just fod blocing the drain. I will bet its all full of ice. Carefully remove all the ice and hot water will help once you get the buk of it out. The hot water will make sure the drain is not blocked with ice. Once its al clear install in the reverse order and things should be good. This is a common problem with this unit.Good Luck
Jul 12, 2007 | Haier HSW02C
I have a haier mini fridge model #HSW02C when i plug it in it humms for a few seconds then it clicks then i hear nothing could this be the relay? any sugestions?
I would say that the motor is humming because it is not turning and the click is when the overload control switches the power off. It may be a start run capacitor blown out but it may be a seized compressor motor. have a fridge mechanic check it out.
Oct 13, 2013 | Haier HSW02C
RRTG18PABB HAIER LEAKING WATER FROM FREEZER TO FRIDGE PORTION
Make sure it is not the fill tube from the ice maker first. Yes I would think ice or sludge is blocking the defrost drain and causing water to flow into freezer and then to the floor. Here is more about leaking refrigerators=> Leaking Refrigerators
Every refrigerator is made different so these are examples only. The key is to find if ice or just gunk has blocked you defrost drain. Unplug and then remove the rear panel in back of freezer. We need to see if the water is overflowing the condensate drain tray or if the blockage is in the turn the drain leads down back of your refrigerator. If you run into any problems along the way of repair please let me know, Thanks, Sea Breeze
How to Fix Fridge Water Leak
Dec 05, 2012 | Haier RRTG18PABB (207 cu ft) Refrigerator
Haier refrigerator hsw02c does not run
These are pretty simple units. If you look on the back you will see a schematic. More or less there is an overload protector in series with the thermostat in series with the compressor. If the overload protector is not open and there is still no 120VAC at the compressor with the thermostat turned all the way up then the answer is a bad thermostat. If there is 120VAC at the compressor and it is not running then the compressor is bad. That's about it.
Jun 09, 2012 | Haier HSW02C
My Haier mini fridge (model # HSW02C) is freezing everything in it's contents no matter what number setting (1-7) it's on. Is 1 supposed to be the coldest setting, or is 7? What should I do?
Hello
Number 1 may be the warmest.Set it to 2 or 3 and give it some time,a couple of hours to level out.
If this does not work try a higher number.
If still no luck then the thermostat or sensing bulb is bad and should be replaced.
Mar 24, 2011 | Haier Refrigerators
Model hsw02c, 1.8 cuft compressor hums and then i hear a click and it doesnt do anything
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 01, 2010 | Haier HSW02 Compact Refrigerator
All i ear is a clicking noise nothing comes on and the compressor gets hot
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Aug 14, 2010 | Haier HSW02C
Haier mini fridge model hswo2c not working
on its side? considering the chemicals inside the freezing elements, it needs to sit upright for 24 hours before you plug it in, or you may break it. so if thats what you mean, why is it sideways?
Jul 24, 2010 | Haier HSW02C
Freezer Noise. Water leaking in Fridge.
you need a repair man.you have a defrost problem and your drain is clogged.
Mar 09, 2009 | Haier HTE18WAA Top Freezer Refrigerator
Refrigerators Logo
Top Haier Refrigerators Experts
John Tripp
John Tripp
geob91
doggzzz
Level 1 Expert
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
