Question about Epson Stylus Pro 4800 InkJet Printer
Epson 4800 bad quality printing
I have an Epson 4800 Printer and I have tried to clean the heads with no avail. I did everything Epson sid to do no luck. This is a $2,000.00 printer I should be able to clean it what else can I do?
Howard
  • 677 Answers
Did you use Epson Genuine Cartridges? I have an epson 4800.
ALL…. Epson & Brother Requires Genuine Epson Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Posted on Feb 05, 2010
Does not print
First of all please check the ink level. If it is not finished try followings:
First try to run a cleaning cycle. To do that:
- Load paper in the paper tray. - Access printer utilities. (Right click your printer icon, select printing preferences and click the utility tab to access printer utilities) - Click the nozzle check icon. - Print to check it.
Then click the clean button to clean the print head. - Try it a few times.
İf it doesn't help you can try to run power cleaning cycle. But it uses much ink. There must be enough ink in the cartridge.
Hope this helps.
Apr 24, 2010 | Epson Stylus Pro 4800 InkJet Printer
My epson c46 is not printing black
Is the black ink cartridge empty? If not, have you tried cleaning the print heads? Sometimes, if printers are used a lot, or used and then left unused for a long period, ink can dry on the print heads. While this usually just results in bad print quality, in extreme cases it can prevent the ink from printing at all. Check this article for directions on cleaning the print head.
Feb 19, 2010 | Epson Stylus C46 InkJet Printer
Heads will not clean, done everything Epson Stylus Pro4800 Manual says it has cost me a fortune in ink and waste tank. Is there an easy way to clean heads?
Usually the simple way to clean old ink from heads is to get a container of alcohol from the drug store and either using a Q-tip or paper towel soaked - wipe the print surface of the head to remove the old ink, then run the head clean utility once after. If you cannot reach the head surface, move the print head to change ink position, unplug the printer and fold and lay the paper towel soaked in alcohol under the head and manually move the head back and forth by hand to clean it. You may need several sheets of towel and alcohol to do this. Fold the paper thick enough so it will touch the head surface to clean.
Oct 26, 2009 | Epson Stylus Pro 4800 InkJet Printer
Epson 4800 pro
Make sure that the "Encoder Strip" is clean and in the channel for the sensor located on the back side of the printhead carriage.
Jan 06, 2009 | Epson Stylus Pro 4800 InkJet Printer
My epson pro 4800 large format printer is not working. After changing a black cartridge, the printer will not print any colour what so ever, not a dot of ink on the paper. I have tried power cleans, a...
Epson print heads do dry out and become clogged and professional rectification is expensive.
A fellow I used to know used steam to clean print heads, more than that I can't say...
Sep 29, 2017 | Office Equipment & Supplies
Epson stylus pro 4800 black ink problem
When you put the printhead back into the machine, did you seat the dampers correctly?
Aug 07, 2008 | Epson Stylus Pro 4800 InkJet Printer
Blue lines running through my image
Did u use the original ink cartridges or compatible ones or refilled?
Jan 18, 2008 | Epson Stylus CX6000 All-In-One InkJet...
Epson Stylus Pro  4800 InkJet Printer Logo
220 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
