Question about Canon PIXMA MP780 All-In-One InkJet Printer
Alert light on says to press ok button, nothing happensm always says check printer push ok
    President:
  • 2,306 Answers
That's an older model, it gives no error code until you enter service mode and get the code. Service mode is only available to service techs since there several things you can do in there that could ruin your printer. You can find the nearest Canon service by calling 1-800-828-4040
Posted on Feb 04, 2010
Where is sync?
Pairing a Nokia Lumia 520 to a 2013 Ford Escape
1. To Find "Bluetooth" on the Nokia Lumia 520
  • Slide your finger left on the display.
  • Press Settings.
  • Press Bluetooth.
2. Turn on Bluetooth
  • Press the indicator next to "Status" to turn on Bluetooth.
3. Pair a Bluetooth device with your phone
  • Make sure the vehicle (parked in a driveway) is turned on and engine running. Go tot he Phone Menu, System Settings, Add Bluetooth Device, Push OK, The Sync System will display a 6-digit PIN number. Use the Seek Arrows to change to Special PIN (the system will display 0000), Push OK.
  • Your phone now searches for devices and after a moment, a list of Bluetooth devices within range is displayed.
  • Press the required Bluetooth device (the tab should say Sync).
  • Follow the instructions on the display to pair the Bluetooth device with your phone. Enter the 4-digit PIN
  • The new device is displayed on the list of paired devices.
  • Press OK on the console screen to set as Primary Phone, set 911 Assist and Download Phonebook. Be sure to check your phone screen and check "Always Connect" and Yes to approve the phonebook download. Be sure to check to see is there is also a request to Always Connect for SMS (texting) alerts.
4. Return to the home screen
  • Press the Home key to return to the home screen.
Your phone should now be paired the Sync system. Use the Voice button on the steering wheel to start the process (say "Phone"). Use the Phone icon to answer (a quick push) or hang up (push and hold down for about five seconds).
For more info www.fordtechlane.com Ford Tech Lane Driving you on the fastlane of vehicle technology
Mar 05, 2014 | Nokia Lumia 520 Smartphone - Wireless LAN...
Can not print ,shows in lcd "unable to print 4F"
Hi there you'll need to reset the printer.
Try this solution:
1.) Unplug your printer.
2.) Plug your printer press the MENU + MONO + ARROW UP. (Press it rapidly one press at a time)
3.) select 8 by using the arrow buttons ,push OK and select 0 and push OK
4.) then numbers appear looks like this ###:### ###:###.
5.) now push the MONO button until the purge:#### appears on the LCD
6.) Select 2, push ok, select 7,push ok,select 8,push ok, select 3,push ok
7.) - switch off the printer ,switch it on
- ready to print
- CHEERS!
email me if I helped you. . ryuuzaki182@gmail.com
Sep 07, 2013 | Brother DCP-J125 All-in-One Inkjet Printer...
How do you connecct the wireless printer to my wirelss router
  • On the printer,push the MENU button,push the up or down button to go to select network then press the OK button.
  • under network menu go to WLAN then press the OK button to confirm the selection.
  • under WLAN menu go to setup wizard then press the OK button
  • when Network I/F switched to wireless is displayed ,press OK to accept.the printer will search for available networks.
  • select your SSID or network name on the list it will display then press OK.If it only showed your SSID then just press OK.
  • Use the a,b and OK buttons to choose the one of the options below:
  • no authentication or encryption or password , select open system ,press OK then choose none for encryption type.press OK.
  • No Authentication with WEP Encryption:Choose Open System, then select and press WEP for the Encryption Type and press OK.
  • Authentication with WEP Encryption:Choose Shared Key and press OK.
  • Authentication with WPA/WPA2-PSK (TKIP or AES) Encryption:Choose WPA/WPA2-PSK and press OK
  • after selecting the correct option,press OK.Always remember,WEP or WPA keys are case-sensitive.You can use the ? and ? keys to move the cursor left and right. For example, to enter the letter a, press the 2 key on the dial pad once. To enter the number 3, press the 3 key on the dial pad seven times.The letters appear in this order: lower case,upper case and then number.
  • press OK after entering the password.
  • the printer will attempt to connect to the router.If it successful,it will display the word connected on the printer.
note: you need to know the encryption type and password type (wep or wpa) for the wireless setup to be successful.you can get the info you need from your router account page or GUI.
Jul 17, 2011 | Brother MFC 490cw Color Inkjet...
CLEAN UNABLE 46
- pull out the AC plug
- put back the AC plug while holding down the "menu" button and keep holding it (15 sec)
- now you are entering the MAINTENANCE mode and "error 46" pops up in the display
- select 8 by using the arrow buttons ,push OK and select 0 and push OK
- 00:00 00:01 OK (the display is showing this message)
- now push the MONO button 25 times until you see PURGE: xxxxx
- Select 2, push ok, select 7,push ok,select 8,push ok, select 3,push ok
- the purge counter indicates now: purge: 00000
- ready to print
Feb 25, 2011 | Brother DCP 130C All-In-One InkJet Printer
How do I bluetooth pair my i9 phone with my Ford SYNC
On your Ford Sync board, press the phone button. It will start to search for already paired devices. If none is found, press the arrow buttons until you find 'Add Bluetooth Device'. Then, press OK. You'll see it will generante a PIN. Now, make your phone's bluetooth application look for new devices. After a while, the Ford Sync device will appear on the phone screen. Select it, and make the the bluetooth application proceed. When a PIN (or pairing code, or passkey) is requested, enter the PIN generated by the Ford Sync device.
Hope it works for you.
Regards, Carlos
May 20, 2010 | Cell Phones
Our epson stylus rx500 printer has been saying ERROR: Printer Error --> See documentation & call for support
this means that you may need a reset your ink waste counter. try to perform this
For the RX500 - Hold down "clear + setup + on"
continue to hold the buttons until the printer had powered on, then off again, then back on. Once I noticed that the LCD had flashed a blank screen, I let go of the 3 keys. In the LCD window I was given access to 3 options using the select keys.
The first had something to do with calibrating the scan light, the second option said "startup." The 3rd did the trick. An abbreviation resembling "ink pad level" was what I was looking for. Here is where I forget what I did... I think that I pressed "OK" on the keypad,. It did nothing. Then I think that I held down the clear button for around 10 seconds. When I let go of the clear button, the LCD read "Press Power to Reset." All better now!
post me a review should this work sir / ma'am coz it did for me
Sep 23, 2009 | Epson Stylus Photo RX500 Printer
HP CLJ 4700 empty display, no answer
When the display is light and printer is ready for printing but does not pass pages:
There are still jobs in the memory buffer of the printer.
This could be solved by pushing the oval select-button.
Notice:
1. Entering the oval select-button also activates the new control panel settings (when they have been changed).
2. Printer control panel settings could have been changed over a network cable: checking the settings is a next step when problems do
disappear.
Aug 12, 2009 | HP LaserJet 4700 Printer
No print
Hi there you can try this.
Canon IP 2000 / 3000 INK counter reset
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
All the best Pineworks
Feb 14, 2009 | Canon PIXMA iP2000 InkJet Printer
How do I take it off wireless?
Hi
To turn the wireless OFF.Follow the instruction.
1.Push the SETUP button
2.Press down arrow key until you see "NETWORK"
3.Highlight it and press OK
4.There Look for WIRELESS RADIO by pressing the Down/Up arrow key.
5.Select WIRELESS RADIO Highlight it and press OK.
6.Now select OFF to turn Off the Wireless transmitter in your Printer.
Reply me with the Result.Always Glad to Help.
Thank You
Riz
Mar 16, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Canon PIXMA MP780 All-In-One InkJet Printer Logo
74 people viewed this question
old marine
old marine
