Question about liftmaster Chamberlain Garage Door Opener Transmitter 300MC
My Liftmaster Formula 1 garage door opener has started to shut unevenly, making one side of the closed door slightly higher than the other. This leaves a gap under the closed door on one side. The door uses 2 horizontal torsion springs each of which get torqued-up by its own pulley and cable system as the door closes. On inspection, I found that when the door is fully open, (i.e. no torsion), the cable which ?winds up? the torsion springs has a little more slack on one side than the other. Thus, as the door closes, the torsion spring on the ?slack? side does not torque-up as much as the spring on the other side. So, when the door is fully closed, there is less torsion on the spring at the ?slack? side, than on the other side. This causes the ?slack? side of the door to be slightly lower than the other side when the door is fully closed, and hence the observed problem. My proposed solution is to adjust the cable pulley on the slack side to even up the slack on both sides. I see the 2 adjusting bolts on the torsion pulleys, and, of course when the door is open there is no tension on the cables, so I assume that as long as I make the adjustment in the door-open position, there should be no danger from the springs. However, before I start adjusting, I?d like to hear from somebody who has had the same problem and can confirm that my diagnosis and proposed fix are correct Thanks Dave
    Scholar:
  • 84 Answers
My friend had the same problem and yes that is what we did. It took a wile to set it evenly. Wouldn't think it would take long but it did. We inadvertently set them to tight and door wouldn't close it would reverse on itself because of the added tension. In the end we did get it though.
Posted on Feb 04, 2010
LiftMaster Pro 1/2 hp 41AS050-1 won't shut. when
Check the resistance down button (There is one for down and another one for up). You may need to adjust the sensitivity. That way even if for some reason the have hard time coming down, less sensitivity may solve that issue.
Oct 22, 2013 | Sears Craftsman LiftMaster Chamberlain...
Garage door will close, stays shut for a few seconds and then opens on its own.
The opener is closing too far. On the side of the opener, you should see 2 white knobs, recessed into the side. Using a flat blade screw driver, adjust the close knob (closest to the door side of the opener), anti-clockwise until the door will close gently on the floor.
Aug 24, 2013 | liftmaster Garage Door 1/2 Hp
Garage door will not close from remote or car. Garage door will open from remote or car; however, it will not close using these controls. The only way I can close the garage door is to press on the manual...
Try reprograming the opener to each remote, if this doesn't work then the command/radio module in the opener is damaged and needs to be replaced. Hopefully you can find one or you will have to replace the whole garage door opener. Good luck.
Jan 21, 2012 | liftmaster Chamberlain Garage Door Opener...
I have a chamberlain liftmaster formula 1 garage door opener I could able to open the garage door using the remote. How ever I was not able to close it using the inside main panel big white color button....
Check to make sure the sensors in the doorway are pointed at one another and the small light on each one is lit and not flickering. If you cannot get both lights to come on you have a bad sensor.
Jul 12, 2010 | Sears Craftsman LiftMaster Chamberlain...
Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+: My craftsman 1/2 hp garage dood does not close whe...
If the main light flashes 10 times when you try to close the door it is a sensor problem. Make sure they are not flickering ever so slightly and that they are not loose on their brackets. Tweak them a little bit.
May 18, 2010 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain Lift Master Pro Formula 1 only makes click sound
Is the door stuck in the open position? If so the trolley is probably jammed against the bolt just in front of the motor unit. Loosen the chain enough to free the trolley and then run the opener until the door is closed. While the door is closed locate the 'up limit' on the side of the motor unit and turn this control 2 complete turns in the opposite direction of the arrow printed on the cover. Tighten the chain.
Apr 03, 2010 | Sears Craftsman LiftMaster Chamberlain...
My craftsman garage door is about 8 years old. It
Make a slight adjustment to the Upward force on the side of the machine. Turn the screw a 1/4 turn each time and test, see if that helps. Also, make sure there are no obstructions or friction when the door opens and closes. Try it manually first.
Feb 18, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door won't stay closed
Check the down limit:
 If the light bulb(s) on your operator are on the front and/or back, the limit adjustment screw is on the left side of the operator (looking from the back of the operator and facing  the garage door).. If the lights are on the sides of the operator then the limit adjustment screw is on the left side (looking from the back of the operator and facing  the garage door)
Jan 03, 2009 | Electrical Supplies
liftmaster Chamberlain Garage Door Opener Transmitter 300MC Logo
793 people viewed this question
Top liftmaster Electrical Supplies Experts
Vince Heuser
tamska1102
Level 1 Expert
ray gallant
Are you a liftmaster Electrical Supply Expert? Answer questions, earn points and help others
