Fault 19,001,46:34558 on xerox 8400 can you help?
  • 316 Answers
Hello,this is print-head calibration error.HFD server failed due to NVRAM operation. This fault only occurs when the printer is set in manufacturing mode,program fault.Nothing you can do,you should take your printer to repair center.
Posted on Feb 04, 2010
Xerox on a 8400 faults code 37004 403B25998 what does it mean
37,004 is a printhead error, specifically that a Reservoir heater isn't drawing power from the power supply.
The printhead 650-4303-00 is expensive, unfortunately.
Whit
Item, Inc.
May 06, 2010 | Xerox Phaser 8400 Laser Printer
Xerox fault 37,004.40 : 134924
It tends to be the problem of heater assembly in printer .Ensure you have proper power supply to printer , if there is any interruption of power then printer won,t be having enough power to function properly and you get this error message . To solve these problem completely you need to contact service person to get it serviced .
Hope this helps.
May 03, 2010 | Xerox Phaser 8400 Laser Printer
Xerox Phaser 8400 Fault 37,008.44:9490
this is a Preheater error 37,008.44 I will put the link below so you can see how to fix it the repair for that error is on page 105
https://www.office.xerox.com/partners/products/Phaser8400/SQRG/8400_85XX_Service_Manual.pdf
Jul 23, 2009 | Xerox Phaser 8400N Thermal Printer
Service message: Fault 37,004,40:50081
Hi abonk:
This is your problem.
37,004.4x - PEST_FAULT_RESERVOIR0_HEATER_DISCONNECT
PEST - Reservoir0 Disconnect Reservoir0 is not drawing the expected power from the
supply.
1. Run the printhead Reservoir Heater test.
2. Verify printhead wiring.
Your preheater needs to be replaced.
Xerox Preheater Part # 119641980
This part will have to be replaced by a certified Xerox technician.
Hope this helps
May 22, 2009 | Xerox Phaser 8400 Laser Printer
On bootup of Phaser 8400 recieve fault 37,004.40:117545
PEST Fault 37,004.40: xxx
Printhead reservoir 0 disconnect:
Reservoir is not drawing the expected power from the power supply.
Service manaul states the the printhead needs to be replaced.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 10, 2009 | Xerox Phaser 8400 Laser Printer
Anyone help with fault code 08.007.41.122.171 xerox phazer 8400 pleas
That is normally a RAM failure. You can try going to the back of the machine and opening the plate which covers the memory stick or sticks, depending on how much memory you have. Remove and reseat the memory. You may have had a memory failure, memory dump or electronics module failure. Kind of a difficult one to trouble shoot.
May 06, 2009 | Xerox Phaser 8400 Laser Printer
Error in xerox phaser 8400
37,004.40: PEST - Printhead Reservoir 0 disconnect. Reservoir 0 is not drawing
the expected power from the supply.
One of the printhead cables may have come partially unplugged. Also, an ink spill on the circuit board could lead to this problem.
Apr 13, 2009 | Xerox Phaser 8400 Laser Printer
Xerox phaser 8400 error code
That code is a jet heater code.The most likely problem is a bad print head, the second most likely bad item is the electronics module that supplies the 40-50 volt source to the print head heater.
Sep 22, 2008 | Xerox Phaser 8400 Laser Printer
Fault code
well..it's a system error code..is this an older machine, by chance?
Aug 20, 2008 | Xerox Phaser 8400 Laser Printer
PHASER 8400
1, The NVRam memory is corrupted.
2, A jet heater is not working
3. the electronics module is bad.
Parts possibly bad are the NVM, the Print Head or the Electronics module.
Hard without a manual to determine, all are expensive.
May 30, 2008 | Xerox Phaser 8400 Laser Printer
k24674
jasbo
jasbo
