Question about Kenmore 463845504 Grill
Is kenmore grill master flame model number 415154000 is operating on LP gas and briquetes at same time, or LP gas only.
  • 32 Answers
SOURCE: Kenmore Master Flame Grill
CHECK TO SEE IF THERE IS A SHUT- OFF VALVE IN THE LINE
Posted on Apr 08, 2008
  • 36 Answers
Burner will not light:
Here is a couple things you can check:
1. Gas injector not insert in venturi tube.
2. Clogged gas injector
3. Obstruction in gas line.
4.Spider webs in venturi tubes.
5. Misalignment Of collector box and burner.
6.Dead Battery.
7.Check hose to make sure it is not kinked
8.Check Hose to make sure it wasn't chewed by squirrles
9. If it is LP gas, Could be out of gas.
Other Issues:
Could be the way the grill was turned on and off, that also can be an issues. In your manual it will tell you how to do it proper, this could make it not light or have a low flame. If there is not hing in your manual, I will be happy to assist you.
Fireplace-Girl
Posted on Apr 29, 2008
  • 360 Answers
SOURCE: i am looking for a manual and parts list for a
Exploded view and parts here -->click here<--
Please take the time to give this solution a fix ya rating
clarkco
Posted on Mar 07, 2009
dniro592006
  • 121 Answers
SOURCE: low pressur on gas grill
orfices are possibly clogged with spider web
and the check to see if your dial on tank is fully open and check to see if your tank is almost empty...
Posted on Jun 02, 2009
  • 26 Answers
SOURCE: Need advice and owner manual for Kenmore grill
Many Owner's Manual can be found online. Go to the Home page of Manage My Home and hold your mouse over the square labeled HOME in the upper left of the page. A drop-down menu will appear, choose the option Products and manuals and then enter the model information and follow the steps.If the manual is not available there, you might need to order a replacement hardcopy through your Sears Store or online through Sears. To find a parts diagram or list for your model online, go to www.Sears.com and select PARTS or go directly to www3.Sears.com
Posted on Jul 22, 2009
I need the assembly manual for a char-broil LP Gas Grill model # 4638975. Much appreciated!
The model number you listed 4638975, does not match any current Char-Broil models.
Please check again, confirm and let me know the correct model number.
Thanks for choosing FixYa.
Sep 20, 2011 | Char-Broil CharBroil Master Flame Gas...
I need the plate that goes over the briquet for model # GB C621 A-M Grand gourmet grill?
Karla, what type (brand) grill do you have? The Model Number (GB C621 A-M ) is not a Brinkmann model number. Nor, do any of their grills use briquets.
Please advise. Thanks.
Apr 07, 2011 | Brinkmann 810-2300-B Grill
Does the patio caddie use any kind of charcoal or lava rock
Your model Char-Broil LP Gas Grill use Lava Briquets on the lower grate above the burner(s). Any generic type will work. Just space them in evenly on the grate in one layer. You'll probably have some left over. So store them in an airtight container for future use (replacement).
Jan 26, 2011 | Char-Broil Patio Caddie 4654870 (LP) Grill
Can't operate more than one burner at a time
It could be something very simple. Remove the tank from the unit. Open and close all valves on the unit. Reattach the tank and SLOWLY open the tank just a little bit so as not to trip the safety mechanism inside it. Then retry.
Low flame on Outdoor Gas grill
Sep 29, 2010 | Brinkmann Charmglow Stainless Steel LP...
Ducane lp gas grill flame pulsates
Have you replaced the battery ? They do rust and lose contact over time outside.
Apr 14, 2010 | Char-Broil Commercial Stainless Steel...
Propane gas flame is not hot. Do I adjust the air
Here is something to try if it is LP Gas:
Here is a Tip to fix a grill that not getting hot:
1. Turn the gas valve knob off. then close LP tank valve knob.
2. Unscrew the plastic hose coupling knob from the LP tank. You may hear a slight "hissing" sound as pressure is released this is normal.
3.Wait a minute then screw the coupling knob back on to LP Tank.
4.With lid open.slowly open LP tank valve.
5.Relight the grill the proper way by turning gas valve knob to ON position while turning the igniter knob at the same time.
6.After you are sure the grill is lit preheat the grill for 30 minutes.
This was called purging the line or releasing the air out of the line.
Another thing your orifice could be clogged with spiders or dirt. If it is LP gas check to make sure your hose is not kinked.
Mar 23, 2010 | Ducane Affinity 3100
Problem with Gas flow on multi burner gas grill
Is it safe to assume that the 4th and 5th burner has a poor flame also? It sounds like a fuel starvation issue. Have you tried replacing the regulator? The regulator is the some what square shaped thing that is on the black LP hose or on the manifold (the part that has the gas valves on it), if it is natural gas. Also try cleaning out the burners and the gas valve orifaces. These will sometimes get clogged with spider webs or food particles. Another thing that can cause a problem is if you have one of those LP gas guages on the tank. I found that it was blocking the gas flow. I tried re installing it but it still caused a problem.
Nov 30, 2008 | Grilling
6.Dead Battery.
Other Issues:
Fireplace-Girl
Mar 16, 2008 | Kenmore 16225 Grill
Kenmore 463845504 Grill Logo
698 people viewed this question
Top Kenmore Grilling Experts
Dan Webster
Dan Webster
Gary Kenady
Gary Kenady
Paul Carew
Are you a Kenmore Grilling Expert? Answer questions, earn points and help others
