I have a 56" sonyrear projection tha was bought new in 2003. When turned on it has horizontal green lines that bend up a little. It shuts off the power light blinks but you can still hear sound.
  • 69 Answers
Try turning down the screen voltage on the focus screen adjustment block behind the speaker grill
Posted on Feb 07, 2010
SONYREAR PROJECTION TV -NEW LAMP-TV FLASHES RED 5 TIMES AFTER IT SHUTS DOWN-
It depends on your model #, However, here's one set of diagnostics that may help. If you could post the model # it would be a little easier to get the exact answer.
http://www.techlore.com/article/15444/Understanding-Sony-Television-Blinking-Codes/
Also, Check the Lamp Door, make sure the Latch is seated correctly and securely, if it's not, you can get the same result, no image. Hope this helps
Jun 02, 2011 | Televison & Video
Panasonic tx51p100h shows horizontal blue then shuts off
la fuente de alimentaciom y vulve a revisar minuciosamente le convergencia poedes tener una resistencia elterada o abierta
Aug 26, 2009 | JVC AV-56WP74 56" Rear Projection...
TV turns on with a green screen with curved horizontal lines.
It seems you may have a serious problem with your video board. That's why you are getting those symptoms. It's better if you replace it asap!
Aug 04, 2009 | Mitsubishi WS-48315 48" Rear Projection...
Sony Trinitron 20" TV (KV-2093R) Suddenly Shut Off
2 things that will cause that vertical IC or Yoke! Listen to this one went on service call 2wks ago Customer had a 50 INCH1988 pioneer big screen replaced 3 capacitors resolder poor connections TV is now working like New ?
Jun 23, 2009 | Sony KP-51HW40 51" Rear Projection...
Picture distorted
this a problem with the motherboard. not the lamp.
Feb 05, 2009 | Toshiba 56HM195 56" Projection HDTV
Screen flashes green a couple times then shuts off
you need a new green CRT. The lines were retrace lines which are the first sign of a tube developing a short eventually the green will short completely and cause the set to shutdown.
Feb 04, 2009 | Sony KP-57WS510 57" Rear Projection HDTV
Green lines on screen
That symptom is caused by a bad dmd board. This will help: make sure you use all digits of model number when you order or lookup parts. This is located on a sticker on the side of your set. Also, you can price "rebuilt" light engine or dmd assy. and check for core value of your defective one. Good luck, Russmann.
May 26, 2008 | Samsung HLR5667W 56" Rear Projection HDTV
Green lines on my Sony projection
Those are called retrace lines and they are the result of the blanking pulse not having the desired effect. This could denote a problem in the Horizontal section of the TV. In this case the green gun is not being turned off as it goes back to the left side of the screen.
Sep 20, 2007 | Sony KP-57WS500 57" Rear Projection...
Horizontal Lines
The unit most likely has a short in the horizontal section and would require repair by a service center. Go here to find a JVC repair center in your area http://maps.jvc.com/cAscList/
Sep 18, 2006 | JVC AV-56WP74 56" Rear Projection...
Televison & Video Logo
66 people viewed this question
Top Televison & Video Experts
