Question about ASUS P5RD1-VM Motherboard
I can't use HDD sata on mainboard ASUS P5RD1-VM
My mainboard is ASUS P5RD1 and with HDD ATA I used normal, everything ok, but when I use HDD SATA (only 1 HDD) and setup new windows (windows XP), I can't boot into CD or HDD for setup windows, I tried use Ctrl + A to utility Uli Raid Bios v1.13 to setup but I can't use anything on it.Please help me.
  • 2 more comments
  • Anonymous Apr 04, 2009
    My mainboard is ASUS P5RD1 and with HDD ATA I used normal, everything ok, but when I use HDD SATA (only 1 HDD) and setup new windows (windows XP), I can't boot into CD or HDD for setup windows, .Please help me.
  • henrytoy Apr 10, 2009
    the sata disk is not listed in the bios setup but on boot if i press the F8 there is ans option like RADI (Serial No. Of )
  • manmit_mit Apr 25, 2009
  • angelho May 07, 2009
    my HDD is a IDE type. My sata driver disk (floppy disk) was damaged (the disk is too old!). where can I download the driver?
    President:
  • 2,351 Answers
Things need to be turned on in your bios patrohi. This is why windows didn't boot to the SATA. You need to use your manual & make sure the, Serial ATA Controller is [Enabled]
Within the Advanved menue under SouthBridge Configuration.
At the Main menue the SATA drive should be listed.
Boot settings need to change as well. At Boot Settings Configurations. Make sure your SATA drive is listed.
Boot order should list like, Floppy 1st, CDROM 2nd, SATA 3rd. The SATA will not list as a SATA but the model number of the SATA drive. Once all these settings are set save & exit. Your drive should show up for work & the windows CD should load.
Posted on Feb 21, 2008
    Problem Solver:
  • 15 Answers
Boot from CD rom hit F6 when prompted and install sata driver. then you should be good 2 go. If your using a sata cd rom, swap it for a a ide during o/s install then reinstall after o/s install is complete also enable sata in bios 1st as well. I had the same board with a pent D 3.0 that clocked to 4.122 with OCZ ram.
great board but old usb 1 sata 1.5 ..
Posted on Feb 23, 2008
  • HARE BUTLER
    HARE BUTLER Feb 23, 2008
    Serial ATA Controller [Enabled]
    This option allow you to enabled or disabled the function of Serial ATA
    Controller. Configuration options: [Disabled] [Enabled]
    M1573 RAID Function [Enabled]
    Allow you to enabledsor disabled the function of M1573 RAID.
    Configuration options: [Disabled] [Enabled if using 2 hd's enable
    find these under south bridge settings.
At the Main menue the SATA drive is Not Listed.
I want to install xp sp2 on Sata HDD The motherboard is P5RD1-VM but there is error set up did not find any hard drive plz tell me settings of bios to sata compataibale
It's likely a problem with your connection cable from the HDD to the motherboard. The bios shouldn't have to be set up for the HDD to be recognized through a sata port.
Jul 17, 2011 | ASUS P5RD1-VM Motherboard
I have an asus p5rd1-vm motherboard. I found problems on installing windows xp using sata hdd. Please help me to install windows xp2 as i am not using floppy drive.
The Windows installation CD does not have a SATA driver. You need a SATA driver of a floppy disk or turn off SATA native driver in the BIOS.
Please click on this link and follow my instructions on how to Install Windows on a SATA hard drive :-
http://www.fixya.com/support/r4335035-installing_windows_xp_sata_hard_drive
I suggest you install SP3 (service pack 3) rather than SP2, it contains the latest bug fixes. The SP3 cannot be installed from a floppy, it can be downloaded from Microsoft, it is a large file approx 300Mb, I suggest you install it from a CD if you can borrow one.
Aug 09, 2010 | ASUS P5RD1-VM Motherboard
HDD problemon asus motherboard p5rd1-vm
You need to install the SATA drivers that belog to your specific motherboard.
When you are installing Windows thru your Windows CD, there is a moment at teh beginning of the process that you will be asked to press F6 if you want to install 3rd party drivers.
That is your call.
Once the SATA drivers are installed, you will be able to continue with your Windows installation.
Don't forget to rate this answer if it helps.
Dec 11, 2009 | ASUS P5RD1-VM Motherboard
Sata HDD NOT DETECTING IN XP SETUP
If you're using a scsi card and connecting the hard drive to the card you need to have the scsi set-up floppy disk. When the blue screen starts during windows installation watch the bottom of the screen. It will tell you to press F6 key then to insert the floppy disk.
If you're using a sata drive connected directly to the motherboard (not in a raid configuration) you shouldn't need anything but the windows disk. The motherboard drivers and utilities disk should have the files to create the scsi install disk.
Sep 11, 2009 | ASUS P5RD1-VM Motherboard
Asus P5VD2-VM SE don't detect sata hdd
What processor are u using & which OS have u installed? Try using WinXP_ServicePack-3.........sodeep
Mar 20, 2009 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
2 Sata Hdd not supported
Hi rafiqbrush, let me go over a few things for the P5B MB.
There is a total of 5 serial ATA SATA drive ports on the board & one ATA IDE/PATA port.
The 4 main SATA ports are numbered, 1 - 4. Your primary SATA drive must be connected to SATA port 1. Your second SATA drive must be connected to SATA port 3. See page 2-26 in your manual.
All SATA drives are seen as master drives. Once the two SATA drives are connected (As per manual), boot to the bios main menu.
At the main bios menu make sure your bios shows both SATA drives. Than go to the bios title "Boot". Make sure your primary SATA drive 1 is listed in the boot order. Save & exit the bios. (SATA drive 1 must have windows installed on it).
Link to Asus P5B web site;
http://support.asus.com/download/download.aspx?modelname=P5B&SLanguage=en-us
Good luck rafiqbrush!
Thank you for using fixya.
Mike
Dec 10, 2008 | ASUS P5RD1-VM Motherboard
How to install SATA HDD for asus motherboard P5RD1-VM?
Do you have previous Seegate Harddisk or SATA one?
If the SATA is installed previoulsy then it is not to much difficult to install a new SATA HDD. But if you are trying to install Sata on Seegate HDD or in combination then it can not be done.
Let me know in either case, with more detail as you can provide here (For OS, Hardware Specification etc)
Thanks
Nov 15, 2008 | ASUS P5RD1-VM Motherboard
Sata hdd detected but problem with booting&installation
i have sata hdd 160 gb of seagate and hdd detected in raid channelbut when start installing window it shows message press enter for fresh installation "no hdd found please check power card,bios configuration
Jun 30, 2008 | ASUS P5RD1-VM Motherboard
ASUS P5RD1-VM raid controller
1. put Motherboard Cd (come with p5rd1vm) in cd/dvd rom.
2. BIOS configur as boot from cdrom.
3. restart machin Motherboard CD boot with press enter
4. command line shows 4 option
5. Select 1st option for exact and proper copy ULi sata driver for winxp.
6. Insert floppy press enter
7.you see d copy procedure.
8.then this floopy insert when winxp setup asking F6 for additional driver.
Thank you.
YOGESH JADHAV
Sep 29, 2007 | ASUS P5RD1-VM Motherboard
ASUS P5RD1-VM Motherboard Logo
2,391 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
