Question about Sony Handycam DCR-DVD92 DVD Camcorder
Disk error 13:02
I have always used maxell dvd in my sony dcr-dvd92 (bought it 12-01-05). i have never had a problem until now! when i turn the camera on it tells me there is a disk error. the dvd is not scratched...there is nothing wrong with the dvd. it will not even let me review ones that i have previously recorded. the last time i useed the camera was mid november and it worked fine. it was stored in the bag. i rarely use my camera! this is frustrating!!
  • Anonymous Mar 11, 2008
    I have been getting C13:02 errors come up on my Sony camcorder DVD92E. It happens usually after you are part way into the disk. You can view the pictures you have taken previously on the disk before you have had the error, but not use the disk to take any more pictures or recordings. You can format the disk after, and reuse it and then the same thing happens part way through. It happens time and time again, and I have tried new disks, and it still happens. Do I just need to take it to get repaired somewhere, or is there an alternative??? The camera is a couple of years old and I would say it has been used enough to use up 20, 30 minute disks with recording and photos.
  • Anonymous Jun 01, 2008
    I having the same problem it give me 13.02
    President:
  • 4,402 Answers
SONY C:13:01 ERROR
1. cleaning the laser lens with isopropilic alcohol and q-tip
2. Try the reset button on the bottom of the camera. Tilt your camera and look below the LCD Display Backlight button on the bottom edge of the curved portion of the camera. You will need a paperclip or tip of a ball point pen to push the recessed little button. Place the camera on a level surface and try again. We find that the camera is very sensitive to tilting, as it gets older.
3. Make sure you format format at was FAT not fat32
4. All you need to do is "Quick format" the disk with the CAMERA rather than the memry stick plugged into the computer drive.
5. For sony error c:1301 using mini cd's: there is a program that recovers data from cd's that works with disk that have this error. It called "cdroller" Homepage is : www.cdroller.com
6. just take the memory stick off and re-insert it lot of times.. just keep doing it.
Posted on Feb 20, 2008
Just bought one 2nd hand, I can't find the charger input :-)
This camera uses a separate battery charger. It won't charge in the camera. As you didn't get the charger with the camera, you will have to obtain one. I found lots of them by searching for "DCR-DVD92 charger" on Amazon.
Nov 06, 2010 | Sony Handycam DCR-DVD92 DVD Camcorder
Sony handycam dvd92 battery warning light comes on even after battery is charged. bought new battery same problem
Yes the good old DVD camera, you like millions of others get this problem with that model, it is looking like DVD disk cameras have a 84% break-down problem, we need to get Sony to start to make proper cameras that use 8mm tape again, it is a media which does work well.
Jun 22, 2010 | Sony Handycam DCR-DVD92 DVD Camcorder
Problem formatting mini dvd+rw disc
The full user manual is available at:
http://pdf.crse.com/manuals/2587623111.pdf
If the procedure fails, the disk may be corrupt but you might try formatting the disk on your pc.
Hope this helps. Please rate reply if it does thanks.
Feb 24, 2009 | Sony Handycam DCR-DVD92 DVD Camcorder
Finalize cd-rw on Sony HandyCam DCR-DVD92
hi dear
you can finalize your dcr in record position
going to disc manager find the finalize
and finish
oke
Mar 28, 2008 | Sony Handycam DCR-DVD92 DVD Camcorder
Sony DCR-DVD92 drive error
i have a canon camera with a similar problem.
it would not allow me to finalise unless the power adaptor was connected to the camera.
not sure if this will help you?
cheers, joe
Mar 08, 2008 | Sony Handycam DCR-DVD92 DVD Camcorder
have you looked at sony's website?
http://esupport.sony.com/US/perl/model-tutorials.pl?mdl=DCRTRV19
Dec 11, 2007 | Sony Handycam DCR-DVD92 DVD Camcorder
Mini DVD Camcorder Problem
You will never be able to recover the information. Sony's system really will have problems with third party brands; there is particular engineering that makes this so. In my shop (Sony authorized), I have seen this problem many times. If you insist on using other brands, get used to problems. As your laser assembly wears it will become more problematic. Good luck, magic seadog
Jun 14, 2007 | Sony Handycam DCR-DVD201 DVD Camcorder
Fuzzy picture (dirty lens?)
http://esupport.sony.com/US/perl/news-item.pl?mdl=DCRTRV19&news_id=161
May 26, 2007 | Sony Handycam DCR-DVD92 DVD Camcorder
Sony handycam dcr-dvd92e
Here is the link to the user manual for your camcorder; http://esupport.sony.com/US/perl/model-documents.pl?mdl=DCRDVD92®ion_id=1 page 72 should tell you what you need to know. Please note that you have to use a DVD-RW in order to be able to delete items; a DVD-R will not allow this. Hope this helps - please ask again if you still have trouble :)
Apr 06, 2007 | Sony Handycam DCR-DVD92 DVD Camcorder
Sony Handycam DCR-DVD92 DVD Camcorder Logo
481 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
