Question about GE Advantium 120 Convection/Microwave Oven
Sparks coming from underneath turntable. - GE Advantium 120 Convection/Microwave Oven
  • 72 Answers
Check for black spot on support for turn table and floor of unit, sand them back to the metal serface and paint if cavity is not stainless steel, if turn table is not turning replace the motor as this could cause this issue as well.
Posted on Feb 04, 2010
My kenmore elite 721.66462500 has turntable that attempts to turn but it sparked and popped underneath and seems it won't turn. All else works-IS IT SAFE TO USE?? kenmore elite 721.66462500
When platter doesn't turn, food will not cook evenly. The motor must be replaced. No harm will come to the oven if you continue to use it.
Nov 05, 2017 | Kenmore Microwave Ovens
My turntable doesn't turn
Sounds like the turntable drive coupling is broken. In the bottom of the microwave where your turntable is, underneath that is a small drive coupling that the motor shaft pushes into. if the motor doesn't turn or the coupling, which commonly has a D shape shaft to keep it from slipping, is broken, the tray will not turn. One quick test it to remove your tray and see if you can turn the coupling easily by hand, if you can you probably have a broken drive coupling. The turntable motor is very difficult to turn by its shaft. so if it turns easily it is probably a broke coupling. NEVER force your turntable around by hand or you can break that coupling.
May 12, 2014 | Panasonic NN-S963BF Microwave Oven
My GE 1800 microwave turntable has stopped turning
There is a motor underneath the microwave that rotates the turntable. The motor may not be getting power or the motor may have failed.
Feb 11, 2013 | GE Profile Over the RanMicrowave....
How to remove the turntable plate
At the base of the spindle of the turntable is a c-clip. Use a table knife or flat screwdriver and needle-nosed pliers to carefully remove it. The turntable can be lifted off. Take care to not damage the belt underneath, if a belt-drive turntable.
If luck is with you, all it needs is a thorough cleaning.
Jan 17, 2013 | Microwave Ovens
T783sf sparks from turntable coupling
No it is not safe to use, the windings of the motor are shorting against the coupling, solution! the turntable motor must be replaced in order to resolve the situation.
Jun 19, 2012 | Panasonic NN-T783SF 1350 Watts Microwave...
Turntable doesn't work
Remove turntable.
It is possible that the rollers on the driving arm underneath have become dirty and are slipping on the underside of the turntable
Feb 11, 2011 | Microwave Ovens
The turntable on my NN-A554 microwave won't rotate, could it be the belt?
You require a new turntable motor. Easy enough to fit from underneath the cavity.
Ask a dealer for the turntable motor, they are relatively inexpensive.
Dec 27, 2010 | Panasonic NNA554 Convection/Microwave Oven
GE Spacemaker JVM1631BB005 making noise
Many thanks to e3enigma above! I removed the synch motor under the turntable; all other microwave functions work fine and the grinding noise is gone, hooray! A trip to the appliance parts store tomorrow for a replacement synchronous motor and all should be well. Thanks again!
Jan 06, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Spacemaker 1800 Turntable
If the noise goes away when you turn the turntable off, it sounds like you have a turntable drive motor that is going bad. They are fairly easy to replace and not terribly expensive. You can access the motor by leaving the oven in place and UNPLUGGED. Remove the bottom panel. You will need to remove the turntable coupler (the plastic piece that spins the glass carousel) and remove a few screws in order for the motor to come out through the bottom of the oven. There should also be a quick connect plug that plugs into the motor. The motor runs about $35 and the turntable coupler (if you wish to replace it as well), runs about $8. The part numbers are 769741 and 769278, respectively at repairclinic.com. I hope this helps you.
Jul 07, 2007 | Kenmore 66469 / 66462 / 66464 Microwave...
GE Advantium 120 Convection/Microwave Oven Logo
485 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
