Question about Canon PIXMA iP1600 Printer
Error message says ink cartrage not in properly when i open the lid it will not retract
  • 163 Answers
Try re-starting the printer.
Hope this helps!
Posted on Feb 04, 2010
Cartrage replacement
From the user guide:
Cartridge Error (1102, 1203, 1204, or 120F)
1 Remove the print cartridges, and close the cartridge carrier lids.
2 Close the scanner unit.
3 Disconnect the power cord from the electrical outlet.
4 Reconnect the power cord to the electrical outlet.
5 If the button is not lit, press .
6 Reinsert the print cartridges and close the cartridge carrier lids.
7 Close the scanner unit.
If the error does not reappear, the problem has been corrected.
If the problem reappears, one of the cartridges is not working properly. Continue with the following procedure to
determine which cartridge is not working properly.
6 Reinsert the black (or photo) print cartridge and close the cartridge carrier lid.
8 If the error:
• Reappears, replace the black (or photo) print cartridge with a new one, close the cartridge carrier lid, and close
the scanner unit.
• Does not reappear, reinsert the color print cartridge, close the cartridge carrier lid, and close the scanner unit.
9 If the error reappears, replace the color print cartridge with a new one, close the cartridge carrier lid, and close
the scanner unit
Aug 19, 2012 | Lexmark X9575 InkJet Printer
How do i get to the ink cartrage when i need to replace it
The steps to removing the ink cartridge and replacing it are rather simple. Keep in mind; however, if these steps are not done properly, there are a number of errors that could occur that could keep your printer from printing at all.
The first step is to write down the printer name and brand.
Remove the empty cartridge with care while taking care not to cause any damage to the printer.
If the user already has a replacement cartridge in his possession, then he simply opens the printer's lid while the printer is still on.
Opening the printer's lid when switched on will cause the printer cartridge seats to move into place, allowing the user to remove or reinstall cartridges.
Remove the cartridge with care then replace it with the new cartridge. Close the lid and print a test page.
The one thing to always keep in mind when changing the cartridge is to handle the cartridges with care.
If the user's ink cartridge has a print head, the user must use extra precautions to ensure that no contact is made with it.
If the cartridge has a seal at the bottom, care must be taken not to break the seal.
Nov 24, 2010 | HP DeskJet 940c InkJet Printer
I have installed a new ink cartrage but the
Restart the computer. Turn off the printer. Turn the printer back on after the computer is fully started.
Mar 29, 2010 | Brother MFC-210C All-In-One Printer
After installing new ink cartrages the two red lights keep flashing and I can't check the cartrages to see if they are seated properly
Do you have a message on your screen ??? Try printing a document or opening the print manager and see the error message - that looks like a maintenance error when your pads need to be serviced after a set number of prints.
Press the button to set the carriage in ink change position - while your carriage is in the ink change position UNPLUG YOUR PRINTER.
ONce printer unplugged from electrical wall socket - remove all carts, and then place them back one by one making sure you use the right color for the right slot - make sure they snap in securely, close the latch.
Now plug in your printer and wait for the initialization process and see if this works....
If you still get the blinking lights, you will need to locate the error message - your printer pad counter has reached its maximum and it needs to be serviced and reset.
There are reset software out there, but you need to change the pads or divert the tube to a tank outside your printer.
Sep 26, 2009 | Epson Stylus C86 InkJet Printer
My Printer won't print, Amber light won't stop flashing.
Install the new cartridge for permanent solution for this error.
Sep 17, 2009 | HP DeskJet 940c InkJet Printer
Same problem help
first try to remove the ink cartrages and close the lid after doing it.
after the system recognizes that there are no inks replug the ink cartrages and turn of the printer and PC/NB and after about 10 secs. turn all of the devices on and try to check it again.
Aug 21, 2009 | Canon PIXMA MP460 All-In-One InkJet...
Empty Ink Cartrage message when cartrage still has a lot of ink.
I'm going to provide you a solution worth many dollars now you can use your left over half filled cartidges and in future also use the cartridges to the extreme.
1. Go to menu and select manual override for toner cartridges and then only replace toner when the print quality starts to suffer. This can save you thousands of dollars over the life of this fine printer.
2. download and read this
http://74.125.153.132/search?q=cache:9mwf_bY_x-AJ:www.refill4.com/refillinstructons/pdf_downloads/Full-RefillInstructions.pdf+brother+mfc+5840+override+cartridge+empty&cd=6&hl=en&ct=clnk&gl=in
Jul 26, 2009 | Brother MFC-5840CN All-In-One InkJet...
HP Officejet T45 keeps telling me I have the wrong Ink Cartridge
Clean the cartridge contacts and the printer contacts as shown here.
Regards,
Bob Headrick, Microsoft MVP Printing/Imaging
Jan 17, 2009 | HP OfficeJet t45 All-In-One InkJet Printer
Refill colored ink, what holes, lexmark x5470
To open the printer, just above the front control panel you use both hands & pull upwards. The whole top of the printer will open up. The ink cartrifges will be close to the center of the opening. The printer should be on for this. There are two ink cartrages. The one with the black lid is for your black ink. There is a small tab in front of the cartridge lid. Push down on the tab & the lid will open. Remove the old ink. Remove the tape that is protecting the the bottom & copper back side of the new ink. Place the ink into the printer. The copper back that runs from the bottom & up the back side about 3/4" goes into the printer cartridge. The colored ink goes into the other cartridge holder, it's lid is blue. Again press the tab just in front of the lid & it will pop open. Repeat the above removing the protective tape & install the ink.
The ptinter will want to run either a test page or allignment page or both. You will need your manual. If you do not have your manual you can download it from this site. Click the link below.
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=f7f0a21c03aee016b79da0cdbb74cf9f&q=Lexmark+X5470
Click "Start download" & save it to your Pc.
Have fun!
please vote...
Jan 20, 2008 | Lexmark X5470 All-In-One InkJet Printer
Canon PIXMA iP1600 Printer Logo
old marine
old marine
