Question about Polaroid i733LP Digital Camera
Card Locked I have only used the camera a few times. I let another teacher use it, and now it says "Card Locked". It will not ler me take a photo, download pictures, anything. Have any suggestions?
  • 3 Answers
THIS HAPPENED TO ME TO!! I can help :D To unlock your card, you need to take your memory card out of your camera. On the side of the card there is always a little switch. (very small on the thin side) Push the switch up or down (depending on what way it already is...do the opposite) and it will be unlocked!
Posted on Feb 20, 2008
I have twice lost all the images from my nikon ds3100. i have a sandisk card. I have no idea how this has happened. do they automatically delete after a few days?
It could be a card error. Don't worry, you can recover photos from camera with camera photo recovery software. You may download this picture recovery software called asoftech photo recovery that helped me before. download it from
http://www.asoftech.com/apr/
You need to take the memory card from camera, and then connect the memory card to computer with card reader.
May 02, 2011 | Cameras
! this card cannot be used comes up after I took a few photos
No need to worry. It's just that as your computer is new so you will have to install the driver (the software that came with the camera) once again.
If you have the CD then install it from there or you can download it from here.( Nikon Transfer)
If you are still unable to download the pics from the camera then the best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive.
Good luck and have a nice day.
Thanks for using Fixya.
Jul 29, 2010 | Nikon COOLPIX L18 Digital Camera
Memory card is locked, how do I unlock this?
Problems typically are pretty rare with Panasonic Lumix digital cameras. On those occasions where you do have an issue, though, look for an error message on the Panasonic camera for some clues as to how to fix the problem.
he seven tips listed here should help you troubleshoot your Panasonic camera error messages.
  1. Built-in Memory Error error message. If you see this error message with your Panasonic camera, the internal memory area of the camera is either full or corrupted. Try downloading photos from the internal memory. If the error message continues to appear, you may need to format the internal memory area.
  2. Memory Card Locked / Memory Card error message. Both of these error messages are related to the memory card, rather than the Panasonic camera. If you have an SD memory card, check the write protect switch on the side of the card. Slide the switch up to unlock the card. If the error message persists, it's possible the memory card is corrupted and needs to be formatted. It's also possible the memory card was formatted using another device that is not compatible with Panasonic's file structure system. Format the card with your Panasonic camera to fix the problem ... but keep in mind that formatting the card will erase any photos stored on it.
  3. No Additional Selections Can Be Made error message. If your Panasonic camera allows you to "save" photos as your "favorites," you may find this error message because the camera has a limited number of photos that can be labeled as favorites, usually 999 photos. You cannot mark another photo as a favorite until you remove the favorite label from one or more photos. This error message also may occur if you're trying to delete more than 999 photos at one time.
  4. No Valid Picture error message. This error message typically refers to a problem with the memory card. Most of the time, you'll find this error message when you try to play back images from the memory card and the memory card is corrupted, empty, broken, or has been formatted with another camera. To fix the memory card, you must format it, but formatting a memory card causes all photos stored on it to be lost. Try inserting the memory card in another device or in your computer and try downloading any photos stored on it before formatting it with your Panasonic camera.
  5. Please Turn Camera Off And Then On Again error message. At least this error message says "please." This error message most likely occurs when one of the parts of the camera's hardware is malfunctioning, usually a jammed lens housing. To try to fix this problem, start by turning the camera off for a few seconds before turning it back on. If this doesn't fix the problem, try resetting the camera by removing the battery and memory card from the camera for at least 10 minutes. Replace both items and then try turning the camera on again. If the lens housing is jamming as the lens moves through its zoom range, try gently cleaning the housing, removing any debris or grime. If all of these steps don't fix the problem, you'll probably need a repair center for the camera.
  6. This Battery Cannot Be Used error message. With this error message, you've either inserted a battery that's incompatible with your Panasonic camera or you've inserted a battery that has dirty contacts. Gently clean the metal contacts with a dry cloth. In addition, make sure the battery housing is free of debris. You sometimes may see this error message if you're using a battery that's not manufactured by Panasonic. If the third-party battery is working OK to power the camera, you probably can ignore this error message.
  7. This Picture Is Protected error message. You'll see this Panasonic camera error message when the photo you've selected has been protected from deletion. Try working through the camera's menus to figure out how to remove any protection labels for the photo files.
Keep in mind that different models of Lumix cameras may provide a different set of error messages than is shown here. If you are seeing Panasonic camera error messages that aren't listed here, check with the user guide for your model of Panasonic Lumix camera for a list of other error messages, or visit the Support area of the Panasonic Web site.
Jul 11, 2010 | Panasonic Cameras
My Canon G7 won't take photos -"Card Locked" message on all cards
Could be one of a few reasons, try emailing the site: camerasandparts.com I don't have their email address but it should be on their site. Their amazing if you need help with a Canon Powershot, that's all they deal with. Good luck
Jun 04, 2010 | Canon PowerShot G7 Digital Camera
Card Error/Card Not Initialized Fault
Use a separate cardreader to download your pictures.
Aug 24, 2009 | Fuji FinePix S1000FD Digital Camera
Locked memory card
Your camera is telling you the lock switch on the card is locked.
Take the card out of your camera and look on the side. There will be a little switch. One side of the switch says locked and the other side says unlocked. Move the switch from the locked position to the unlocked position and it will work for you.
Rob
Mar 09, 2009 | Canon PowerShot A620 Digital Camera
Pictures are distorted when downloaded and viewed
Im attending high school and we just got new mac computers with PH3 on them, when we fix the photos or even view them with out opening them in Photoshop they are goin to look distorted... We asked our teacher if theres anything we can do and she said no... sorry
Dec 16, 2008 | Panasonic Lumix DMC-FX12 Digital Camera
Polaroid i830
Sounds like a power problem. Recharge the supplied LiOn battery. Clean terminals and contacts with a pencil eraser.
If this fails, return it.
Jan 26, 2008 | Polaroid i733LP Digital Camera
Please help
hi Ruthie, dont get tense,there are so many data recovery software available on net, just download it and recover your sister's wedding photo. but i think you did not format your memory card regularly,that's why it happened. so dont forget to format regularly after recover your photos. good luck...
Jul 30, 2006 | Nikon Coolpix 4200 Digital Camera
Polaroid i733LP Digital Camera Logo
26 people viewed this question
Top Polaroid Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
