Question about Canon PRINTER/COPIER/SCANNER All-In-One Laser
I just want to use the scanner even though the printer is broken is this possible
Replace paper
Hi,Its possible that you're printer rollers need cleaning. Try going into you're control panel..click on printers and scanners....Right click and go to properties..There should be an option to do a maintenance check on you're printer... Do a Nozzle..roller...head and alignment clean....
Once this is complete print a test pageHope this helps youRegardsMichelle
Mar 08, 2012 | HP DeskJet 3740 InkJet Printer
Hello i have HP n2600 almost all toners are at 90% but i am facing the problem that got a line in middle of page in every print and also the color are so fade..please help me
Try to run some test like..Ink Test, Drum test. It is in the menu button of the printer. From running a test you will see the exact problem youre encountering.
Mar 11, 2011 | HP Color LaserJet 2600n Printer
My print copy is unclear, even though the ink level is full and I cleaned the heads
There are two possibility
1. Re - install the printing software which is available in the cd given to you at the time of purchase
2. Replace a new cartridge
Your problem will be solved or else call technician.
Thank you
May 07, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Epson Artisan 800 Scanner leaves blue/grey stripe on side.
I had this exact same issue with two Artisan 800's. I was told it was a hardware issue. Both were returned under warranty to Epson. Have since had problems with ADF and that printer was returned. Warranty has now ended. Expecting to buy a new printer shortly: they last about 4 months before having problems. It won't be an Epson even though that's all I've owned for 10 years
Sep 17, 2009 | Epson Perfection V100 Flatbed Scanner
Brother mfc-440cn printer printing crooked
There is the possibility that the scanner assembly has jumped a tooth on the drive belt on one side so the scanner is just slightly crooked. To correct this the scanner assembly would have to be taken apart enough to correctly line the assembly back up. I wouldn't recommend that you try this yourself unless you have some experience at this sort of thing. Contact Brother for an authorized repair center near you for assistance.
Sep 04, 2009 | Brother MultiFunction Center MFC-440CN...
I can not use the scanner. What should I do?
first of all, even though your printer may be wireless, most scanners require a wire from your computer to the scanner. If you have been trying to scan in wireless mode, try this and let me know if it solves your problem
Jul 14, 2009 | HP PSC 1210 All-In-One InkJet Printer
In Canon MP160 i dont want to use its printer so is it possible to use only its scanner even it has dry or dammy cartaige?
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
ptttq15
Jun 16, 2009 | Canon PIXMA MP160 All-In-One InkJet...
I have had a lexmark printer/fax/scanner for about 3 years. I have never used the fax part. The printer works perfectly well but about a month ago the scanner stopped working. Can you please help. I do not...
Possible, your printer has worked out whole its resource. Even though his(its) repair technically possible, he will be expensive. Your warranty service was expiredabout 3 years. Think about buying new. Good luck.
I have bought itself from Epson.
Mar 06, 2009 | Lexmark X7170 All-In-One InkJet Printer
HP officeJet V40
I do not believe you can share the scanner across the LAN as the software does not support this.
Windows only supports the sharing of certain hardware such as printers but not scanners, even though that is attached to the printer but uses different drivers and software to work.
Dec 10, 2007 | HP OfficeJet V40 All-In-One InkJet Printer
Canon PRINTER/COPIER/SCANNER All-In-One Laser Logo
16 people viewed this question
old marine
old marine
