Question about Welding Tools
I have a Lincoln IDEALARC SP250 the screen keeps going hay wire
  • 10,865 Answers
Hello. You may have an internal system fault. To check for this turn the input power off for a few seconds and then turn it back on. If that does not solve the problem, check the input voltage. Make sure that the input voltage matches the nameplate rating and the reconnect panel configuration.
IF the problem is still present, the next step is to call your Lincoln dealer. Good luck with it. Regards, Joe
Posted on Feb 04, 2010
I have a lincoln idealarc constant voltage model R3S 325 LN 7 control mix weld machine how often should this machine be maintenance and what is some signs that it needs to be maintenance
There is very little maintenance that needs to be done. Take the covers off of both the wire feeder and the welder and gently blow out the dirt. Do not just blast everything with air as you could create problems. If everything is working right don't worry about anything else.
Aug 19, 2015 | Lincoln Welding Tools
Lincoln sp-150 idealarc will not arc any more ground output checked ok fuses checked ok incoming power 230v ok output term for + voltage to wire on spool nopower when trigger pressed.continuity from
There is a temperature activated switch near the transformer that will turn off control voltage until the transformer cools. There is also a fuse for the control voltage. That would explain why the motor won't run. There's a possibility that the trigger switch in the handle is bad too.
Oct 15, 2014 | Welding Tools
NEED A WIRING DIAGRAM FOR A DC-600
Here's your Lincoln Idealarc Owner's Manual.
If this was helpful, please rate it 4 thumbs up - thanks & good luck!
Sep 25, 2011 | Lincoln Electric K1297 AC/DC 225/125 Stick...
Not getting a starting arc when foot pedal is depressed on our Idealarc TIG-250/250.
Hi:
The foot control has a micro switch in it, this one must be worn out. Take it to your nearest werlder shop (like praxair... www.praxair.com ) and ask for the microswitch by brand and model of your foot control. It's easy to replace. Probably the welder shop must order it, since it's noy pretty common for this switch to go bad, but it happens, specially on old welders.
Jun 22, 2011 | Lincoln Electric Welding Tools
I just need to know what my sp250 idlearc lincoln mig welder is single phase or three phase, my gurage has three phase running in how do i wire in ,if single phase
Hi:
Your Machine is single phase, and it could be a 208/230V or a 230/460/575V depending on the model. Check what kind of voltage do you have at your garage first, before attempting to do the following:
On a three phase wiring you will have 4 wires with the following colors; green, red, white and black. If you have 208/220/230 volts available at your garage you can connect the green, white and black wires, always green being the ground cable in the middle, black and white don't matter which side you screw them in.
Before attempting to connect a 480V to the machine check machine's plaque information in the front (or back) for real voltage, because this voltage can burn the PC board of you machine. The same color sequence applies to the 480V.
Good luck.
If this was useful to you, please vote.
Mar 19, 2011 | Welding Tools
While welding aluminum in AC mode (with continuous high frequency), the 50 amp circuit breaker in the house emits a loud buzzing. The machine is electrically grounded to a 8 foot grounding rod. Anny...
The machine is probably taxing the capacity of the power circuit and it's breakers. While the machine may be pulling less than 50 amps average, the high frequency modulation is likely producing peaks over 50 amps. Changing out the 50 amp breakers might help and again may not. The whole circuit should be rated at least 25% over expected current draw. The grounding system is to protect you, not the machine. Good luck!
Dec 14, 2010 | Garden
Lincoln Idealarc tig 250 has no high frequency
Check high voltage transformer and capacitor, also check point gap circuit to ground.
Jun 20, 2009 | Welding Tools
Need suzuki sp250 repair manaul
Often your local library will have manuals that folks have given them. It's worth a shot.
Mar 14, 2009 | 2003 Suzuki RM 125
Welding Tools Logo
55 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
