Question about Kenmore 63942 Dryer
Dryer interior light and motor will not turn on
I have a Kenmore 80 series dryer that suddenly stopped working the other night. Also the interior light does not come on when the door is opened.
I checked to make sure it is plugged in and I also reset the circuit breaker.
It just wont run anymore when any cycle is selected.
  • Kenmore Master
  • 2,330 Answers
Plug something else into the wall outlet to make sure you're getting power there and try changing the bulb.if there is power check the door switch,move the paddle in and out and you should hear a clicking sound,if you don't change out the door switch,also check the back of the dryer at the block where the power cord connects to the dryer and make sure you have power there.also is there a gfi plug anywhere near the dryer that might have to be reset,i've seen this,also i've come across whoever wired the outlet switched the hot wire and the neutral around so when the machine is plugged in the wiring isn't correct
Posted on Feb 06, 2010
  • Sal DeAngelo Feb 06, 2010
    what did you find?
Kenmore series 80 heats and turns fine but stops after 30 minutes or so at any heat setting
Does it restart after it cools down? If so your motor may be overheating and shutting down.
Jun 20, 2012 | Kenmore series 70 80 90 Dryer Motor...
Kenmore 80 Series dryer's drum is making a thump
I would check all the screw's to make certain they are tight. That was my problem when mine was making noise. Look on the interior of the drum.
Jan 01, 2012 | Kenmore Dryers
My series 80 Kenmore dryer won't start
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 30, 2011 | Kenmore 800 6983 Electric Dryer
I have a used Kenmore Series 80 dryer & the drum stopped turning
Good day,
Not hard to do but check the 2 rear wheels that support the drum and change at the same time if needed. Inspect the belt tensioner as well.
Here's a good tutorial on the belt change.
http://www.wikihow.com/Replace-a-Dryer-Belt-on-Whirlpool-Models
Dec 15, 2009 | Dryers
Kenmore Dryer 90 Series will start but suddenly stop...
Hello , Sounds like your motor is over heating , it will run until the sensor shuts it down from getting to hot , it is most likley because the motor is covered in lint and needs cleaned. Hope that helps.
Dec 30, 2008 | Dryers
80 series front load dryer will not turn.
It almost has to be the belt as the heating element won't come on without the motor turning.
Jun 26, 2008 | Kenmore 62802 Electric Dryer
Kenmore 80 series stop turning
most likely a bad motor; expensive.
May 19, 2008 | Kenmore 63942 Dryer
Kenmore 63942 Dryer Logo
260 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
