Question about Apple Cinema Display 23" HD Monitor
Displays Lamp Error - Apple Cinema Display 23" HD Monitor
  • 316 Answers
Hello,lamp inside the TV has some working hours as all the lamps.You can take it to a repair shop to change the lamp or you can try to change it by yourself.But if you don't have any experience i recommend you to take it to an expert
Posted on Feb 04, 2010
Please my heater lamp is not lighting.
U need to check whether the exposure lamp is light ON or not when u turn ON the machine
If not light ON, then exposure lamp unit or connectors might be faulty
Dec 21, 2015 | Toshiba E-Studio 160 All-In-One Laser...
Projector will not turn on. Lamp light displays red and temperature light displays red.
I'm sorry to inform you that there is an internal error in the projector. Turn the projector off and unplug it. Contact Epson for help.
Feb 27, 2011 | Epson PowerLite® 83c LCD Projector
Screen displays "printer error fuser temp"
Disassemble fuser unit and inspect thermistor and thermostat for dirt or damges, and heater lamp for damages.
Good luck.
Feb 08, 2011 | Xerox Phaser 3100MFP/S Laser Printer
Copier displays H4 error code and would not copy
detail for error code H4: Fusing section low temperature trouble
•The set temperature is not reached within the specified time (normally 3 min) when warming up or resetting from pre-heating. Cause:
  1. Cause thermistor trouble
  2. Heater lamp trouble
  3. Control PWB trouble
  4. Thermostat trouble
  5. AC power trouble
  6. Interlock switch trouble
Solution:
  • If the heater lamp blinks normally:
  1. Check the thermistor and its harness.
  2. Check the thermistor input circuit in the
  3. control PWB.
  • If the heater lamp does not light:
  1. Check for heater lamp disconnection and
  2. thermostat disconnection.
  3. Check the interlock switch.
  4. Check the AC PWB and the lamp control
  5. circuit in the control PWB.
good luck
Oct 13, 2010 | Sharp AL-1457 Black and White Copier
I have a RICOH FT 4022 copier and it displays E 5 error code. It does not allow copying. I have checked the fuser unit and its ok. What could be the problem? Do I need a reset code to solve it and where do...
The E5 code is the fuser malfunction error.
E52 fusing lamp warm up error.Possible causes thermistor open,heater lamp open,thermofuse open.
E53 fusing lamp overheat.Thermistor in shortcircuit
E55 fusing thermistor open
When service call E5 conditions occur they cannot be cleared by turning OFF/ON the power switch.To reset turn ON the main switch,turn DIP switch 101-1 ON and OFF(the DIP switch is located in rear part under main supply board).,and turn the main switch OFF and ON.
Nov 11, 2009 | Office Equipment & Supplies
Copier fixing problem
Hi
The A-3200 error indicates a scanner lamp problem.
It can either be a loose connector or more likely a lamp or inverter PCB.
Another cause can be incorrect shading position, by moving the contact glass this may fix it.
Jul 07, 2009 | Kyocera Copystar CS-1620 Black and White...
I WANT TO KNOW THE MEAN OF ''ERROR 06'' IN HP SCANJET 8270 AND THE POSIBLE SOLUTIONS... THANKS
If LCD displays Error 06 or Error 09 , the TMA might require service
Press SCAN PICTUREc00068011.jpg button once (see Figure 3 above). The TMA lamp should turn on (see Figure 4 above). If pressed a second time, the TMA lamp turns off (if TMA is detected). NOTE: The scanner carriage lamp should be off when the TMA lamp is on and should be on when the TMA lamp is off. The only time the TMA could not be detected is if the accessory cable is not plugged into scanner
Jul 02, 2009 | Office Equipment & Supplies
Error code E677
677 error is printer board error.u check conection( lpt port or usb cable loose conection.printer board loose conection.remove all conection and conect all conection i mean reinsert conection ) then this error come u will service u r printer board(re insolve printer softwere).803 error is expouser lamp end side blocked change u r lamp u r 803 problem is ok
Jun 01, 2009 | Canon iR 1600 Laser Photo Printer
How can I solve error E214 of my canon 6260 photocopier
The error code deals with the scaner / mirrors or lamp. When you turn the copier "ON" will the scanning lamp turn on? If not your Lamp is blown or it could be the thermal fuse for the lamp, but it is most likely the lamp. It could also, mean that the Lens is not moving into home position.
Jan 05, 2009 | Canon imageRUNNER 210S Copier
Apple Cinema Display 23" HD Monitor Logo
220 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
