Question about Brother IntelliFAX 5750e Laser Fax
Received blank pages. Could this happen if the
Have a Brother 5750e and we received blank pages. Could this happen if the toner runs out?
    President:
  • 3,085 Answers
Make a copy of something to be sure. It will tell you when you are low on toner
Posted on Feb 04, 2010
Hi. i hope you can give a suggestion with our brother intellifax 2820. Whenever printing a received fax, the machine prints out a blank page in between each received page. so, for example, we receive pg1,...
press "menu/set, 1, then 3. you should see "paper size" on display. select "letter" if thats what you are using, and press "menu/set" again, then "stop/exit" to back out. next, make sure your "fax" button below display is green, then press "menu/set, 2, 1, then 5.using your arrow keys, select "on". press "menu/set" then "stop/exit". that should do it.
hth,
razors
Mar 15, 2010 | Brother IntelliFax-2820 Laser Fax
Printing blank pages when receiving fax
Ask if the ones sending are sending legal size, it may be using 2 sheets to get all from a legal size document.
Jul 29, 2009 | Brother MFC-8460N All-In-One Printer
Top of page prints OK. Bottom blank
My first guess would be phone line problem. Print out an activity report (if you don't have a users manual you can download it at www.brother-usa.com ) and check to see if you have had any communication errors. If you notice no errors then make 50 test copies. If your test copies look good then I would lean towards a phone line problem. if they come out like you have described then I would start with your toner and drum first, second laser and third main board.
May 27, 2009 | Brother Office Equipment & Supplies
Received "Low Toner" message. Replaced toner with new Brother cartridge still have "low Toner" meaasge and [printer will not print.
Please check if you removed the Plastic Tapes which is placed in the side lock of the new Toner Cartridge.
Apr 24, 2009 | Office Equipment & Supplies
Toner all over the page with bubles
REPLACE THAT BAD RECYCLED TONER CARTRIDGE
Jun 18, 2008 | HP LaserJet 4350 Printer
Copies and incomming faxes are blank
Take your drum unit out and inspect. It just might be out of toner. Look at the silver pins that contact the drum unit.
Apr 22, 2008 | Brother IntelliFAX 5750e Laser Fax
Faxes received are so light, the page looks blank
don't forget to try other fax-paper... your's might have already expired.... if this doesn't work... the printer's heater might need changing.
goodluck... hope this helps.
Feb 26, 2008 | Brother IntelliFAX 4100 Laser Fax
Blank pages after installing new drum
when replacing the toner did you remove the plastic film sealing the toner? if the drums receives no toner you will get blank pages. please check
hope this helps
good luck
Oct 25, 2007 | Brother HL-2040 Laser Printer
Can not receive faxes or blank pages com thru!
Can you make a copy and get a good print? Does the blank pages come from different people? If you still get a blank from making a copy, then try a different toner and or drum unit. Hopefully it is still under warranty.
Aug 01, 2007 | Brother IntelliFax-2820 Laser Fax
Brother IntelliFAX 5750e Laser Fax Logo
91 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
