Question about Braun MULTIMAG SlideScan 4000
Random black lines on scanned slides
Hi all, got a bit of a wierd one. I'm currently over half way through a run of 6,000 slides, and the slidescan has started to place black bands on the slides in random positions and random thickness. It appears to not be scanner random areas of the slides. I've installed it on several machines with the same results so I know it must be the scanner.
Just wondering if anyone has had this problem before and of course if there was any work around for this.
Thanks in advance !
Dan
  • danjbudd Feb 21, 2008
    Thanks for your help. I have already tryed your suggestions prior to posting but with no effect. As you can see from below, its getting even worse now, I can't even do a single slide now.
    Spoke to my supplier today and he has got in contact with Braun in Germany who will hopefully be ringing me today so I will keep my fingers crossed.
    Thanks for your help !!
    Dan Budd
The problem is likely to be a failure of the ribbon cable between the scanning head PCB and the mother board. This is a 28 pin cable, the cable run is poor, the type of cable is IMHO not the best for this application and is too short. The continuous flexing of this cable as the the scanner scans results in fractures of the copper. Replacement of the cable is required.
Posted on Feb 18, 2010
  • patrick274 Jun 02, 2011
    Any idea where we can get the cable?
  • 490 Answers
Normally dark lines are a speck of dirt sticking on to the glass and when scanned continuously, it appears as a line. Clean the glass thoroughly. Ensure the slides are dust free. If the lines are appearing in different locations, it means the dust gets removed while scanning. Line in the same place could be because of glass is scratched. The above is common with roller scanners.
For fat bed scanners, there will be no scratch on the glass. It must be from the slides/documents
Posted on Feb 21, 2008
  • Mohan Sriraman
    Mohan Sriraman Feb 23, 2008
    From the picture you had displayed, it appears that the scanner is faulty. It could that it is not capturing the data. You can check if the lighting is okay by keeping the top cover open. If the lighting is not okay, then you can try changing the light source. Some scanners use cold white light and some use RGB LEDs (Red Green Blue Light emitting diodes).
    If the light is okay then the problem could be in data capture.I have no solution for this as it appears to be totally a hardware problem.
Scanning 110 Instamatic slides on Epson Perfection V700 photo scanner
Hi Stanley - does this youtube video help? http://www.youtube.com/watch?v=EcALdbbCnSk
If not, let me know and we can investigate further.
Regards,
Justin.
Jan 17, 2014 | Epson Perfection V700 PHOTO Flatbed...
Black lines on scan
Dear all
I have the same problem Please Help
Mark
Jun 04, 2010 | HP ScanJet 2300C Flatbed Scanner
Preview results in random croppings, rotations, and added pics
Hi I'm having a similar problem and haven't managed to fix it. Have you solved it? Thanks Martin
Mar 07, 2010 | Epson Perfection 4990 Flatbed Scanner
My Braun 3650 is scanning everything RED, I changed computers and is still scanning red, any idea why it's doing that?
See previous fix for black lines problem is likely the same i.e fractures in the flexible cable between the scanning head and mother board, changing this cable will likely cure this fault.
Oct 05, 2009 | Braun MULTIMAG SlideScan 4000
Scanning slides produces black images. Slide
Make sure the white document matt from uner the lid has been removed. Also in Epson scan make sure you have changed the document type from reflective to Film and Colour positive.
Jul 03, 2009 | Epson Perfection V350 Flatbed Scanner
Canon Pixma ip1500 is printing but very wierdly. random lines will not show up in black. If i change the color everything is fine but black will skip lines and such. Please help! Can't turn in job...
Your printhead is plugged and needs cleaning. If you remove the inks and then the printhead, you can wet and fold a paper towel and just dab the printhead gently on the wet towel. When you see a solid black line on the paper towel your printing should be improved.
Jun 23, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
Narrow straight line runs across all scanned images
by shutterup
I solved my problem.
It's pretty personal, but I hope it can help others.
First: I might have created the problem myself because I slightly adapted the slide-mount.
Why?: Some time ago I had some unwilling films the automatic! film-mount wouldn't swallow, so I had to use the manually operated slide mount.
I adapted a slide housing a bit, so it could take and transport film.
To be short: In the end, there was transparent, (but also reflective) material inside the Coolscan V housing, close to the slide.
I removed it.
Second, I turned the scanner 45 degrees, and gave it a calculated whack on the side. (like you did with your tele in the 6ties, but a bit more carefull )
Don't know which one did the trick, or both. I can send a sample.
Mar 29, 2008 | Nikon CoolScan V ED Film Scanner
OMG HELP!!PLEASEEEEEEEE WIERD LINE SHOWING UP
plesw see your LCD settings or remove your screen wipe if and then fit it and restart
Oct 21, 2007 | Nintendo Wii Console
Funny half screen problem
Nope, Sorry to tell you, there is most likly a coupling capacitor or the vertical sweep IC itself could be defective. Although if you have had some sort of solid state Printed circuit board training, this should not be to hard to find, with a can of freeze spray. Unfortanatly this set has no user replacable parts inside of it, as everything is soldered into place and there is no easy fix. Although depending on how old the set is, is going, Im sure, to determine if you want to invest any cash into this thing. Without any training it would be a crapshoot Im afraid! So stay safe and seek the assistance of a pro. Good Luck Please do not forget to rate this!
Oct 16, 2006 | Sanyo DS31520 31" TV
Open Questions:
See all Braun MULTIMAG SlideScan 4000 Questions
Braun MULTIMAG SlideScan 4000 Logo
236 people viewed this question
Top Braun Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Are you a Braun Office Equipment and Supply Expert? Answer questions, earn points and help others
