Question about Pioneer Audio Players & Recorders
Speed of Pioneer PL-Z81 Turntable
The speed switch on my 20 year old Pioneer Turntable PL-Z81 seems to be broken as it will only play at 45rpm. Is this a simple part to change given that I can still source one from somewhere please?
ctf1800
  • 4402 Answers
SOURCE: Turntable speed
most of these were belt driven, if that the case check to see if the lever is connected moving the belt to the slower pully
Posted on Jan 04, 2008
SOURCE: Pioneer PL-570 turntable (c.1973)
pioneer PL 570  tone arm drops and turntable shuts off,  what gives?
Posted on Jan 16, 2009
petraman7
  • 1175 Answers
SOURCE: PL-88FS with modern HDMI Receiver
Hi...
If the new receiver doesnt have a specific input in back labeled "phono" , You WILL need a preamp for the phono. Then plug the preamp into the AUX or other available input
Posted on Jan 19, 2009
  • 42 Answers
SOURCE: pioneer pl 990 turntable
Lift off the platter mat, then lift off the platter from the spindle - gently.
Underneath the platter is a sub-platter around which you place the belt - it should be held there by the stretch of the belt while you turn the platter back up the right way and place it back on the spindle.
Turning the platter by hand, you should see a small pulley come into view through one of the holes in the platter. You then stretch the belt slightly so that it slides over the pulley. Take care not to twist the belt while doing this.
Posted on Jan 24, 2009
  • 104 Answers
SOURCE: I have a Pioneer PL-A35 turntable. I had the belt
the may be a 'dead spot' on the motor, try to jump start it by spinning it with your fingers several times. it's a longshot but it might work
Posted on Apr 17, 2009
Turntable doesnt start till platter is in 45rpm position
If you look underneath the deck you will find that the arm is linked by leavers to switches that trigger the motor. Clearly the one that for LP's has become bent out of shape and no longer pushes on the switch. Or the switch itself has broken or become bent, making no contact with the motor.
Nov 07, 2015 | Audio Players & Recorders
Pioneer pl a45d
Hi Javier,
How to change the belt? how to replace belt on pioneer pl x300 pioneer pl x50 turntable .
A place to find the belt. Pioneer PL A45 PL A45D Realistic LAB 1500 TURNTABLE BELT T245
Manual with schematics. Sign up and free. Pioneer PL A45 Manual 2 Speed Belt Drive Turntable Vinyl Engine
How to set it up after you put the belt on.
How to set up Turntable cartridge alignment overhang VTA VTF vibration...
Another look on how to change a belt on a turntable? How to Replace Turntable Belt on Belt Drive Turntable
It is straight forward. Patience. Fare. Well.
May 16, 2014 | Pioneer Audio Players & Recorders
1970's vintage Pioneer PL-630 turntable w/ speed variation proble
THIS IS HOW!!
http://www.audiokarma.org/forums/showthread.php?t=92333
Mar 01, 2010 | Pioneer Audio Players & Recorders
I have an old Pioneer stereo auto turntable PL-5.It is rarely used and worked fine until my grandson started to turn the turntable by hand and I think backwards.Now it speeds up and races.Can this be fixed...
if the speed is constantly fast the drive belt may have ridden up on the top part of the motor pulley.inspect and refit.if the speed varies check operation of 33/45 switch.
Dec 15, 2009 | Pioneer Audio Players & Recorders
Pioneer PL-12D TURNTABLE. Plays too fast.
Judging by your message I guess it's a secondhand machine, you have either been given or purchased. I suspect that someone might have played around with the speed preset to the motor. Take a look around the deck see if you can find it, sometimes there are two, one for each speed. They should correct it, unless something has gone.
Aug 23, 2009 | Audio Players & Recorders
Turntable 45rpm speed has stopped working
Check that the lever is actually making the contact with the 45 rpm switch position and completing the circuit as it would seem everything else works. The only other thing it could be is a break on the pcb, but that is unlikely.
Oct 17, 2008 | Philips Audio Players & Recorders
Pioneer PL-300 Turntable plays records too slow
i think it is a belt driver table. you can find a replacement belt maybe. but if it is servo controlled motor driven then adjustments to sped setting has to be done.
May 03, 2008 | Audio Players & Recorders
Turntable speed
Dec 31, 2007 | Sony PS-LX250 Turntable
378 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
