Question about Magic Chef Refrigerators
I have a Magic Chef GT19Y8F refrigerator and the freezer doesn't get cold enough to freeze the food.
fridgetech
  • 473 Answers
SOURCE: Magic Chef Refrigerator
Not a themostat. 3 most common causes are defrost problem (frost on back freezer panel), bad evaporator fan motor, or damper.
Posted on Oct 05, 2007
Master_Tech
  • 770 Answers
SOURCE: Refrigerator not cold enough
check the back wall of your freezer for a heavy frost build up rhis is an indication of a defrost problem also make sure the fan in the freezer is working
Posted on May 11, 2008
  • 2920 Answers
SOURCE: Magic Chef refrigerator stop cooling
check the fan relay and the compressor to make sure it is still working...if not there is a capasiter you can replace to get it to work again
Posted on Aug 27, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: freezer not freezing food and fridge not staying cold enough
Check the compressor with a volt meter, if the compressor is getting proper voltage then check the relay. But this sounds like a problem with the compressor
Posted on Feb 12, 2009
heatman101
  • 43501 Answers
SOURCE: My G.E Adora refrigerator freezer
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 18, 2010
MCBR1020W is the model number for the refrigerator in my apartment. The refrigerator fresh food unit is not getting cold enough to keep food cold, this results in food spoiling. What could be causing this...
You could have the lack of air flow or a door seal problem. Could you check the freezer for me, look for frost on the back wall. If not frost, is the fan running in the freezer?
Please get back to me
Sep 08, 2011 | Magic Chef Refrigerators
Magic Chef fridge too cold - defrosted it unplugged it - set the control to 1 and it still is freezing things
On the MCBR170 refrigerator the plastic clip the holds the the temperature probe to the bottom of the freezer compartment will break off and allow the probe to hang freely in the back of the fridge. This could be the problem with the refrigerator. I had this problem and used zip ties to hold the probe in the proper position. (see attached pics). magic-chef-fridge-cold-defrosted-3xqyivebcuprbty0n3yvm4ul-2-0.jpg magic-chef-fridge-cold-defrosted-3xqyivebcuprbty0n3yvm4ul-2-2.jpg
Aug 25, 2011 | Magic Chef MCBR170 Compact Refrigerator
Fridge is freezing all liquids freezer is turned down as low as possible and liquids are freezing
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Feb 24, 2011 | Magic Chef CTB1922 Top Freezer...
The freezer is running but will not get cold enough to freeze food.
Sounds like you need to get the engineer out. If not getting cold its a manufacturers problem
Dec 12, 2010 | Magic Chef 12.2 cu. ft. / 345 liter Chest...
Hi my lower part nolonger gets cold enough to keep fresh foods yet the freezer is working well
Set dials to middle setttings, if the colder /warmer dial is peffed max cold its max cold freezer!!! so move to warmer and the freezer will give more airflow to the reefer , the reefer is reliant upon the freezer for its cold air.
Nov 01, 2010 | Magic Chef CTB1821AR Top Freezer...
Magic Chef MCBR445W1 seems like it dosen,t stop
Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for.
Check on the cold control if faulty, replace the cold control, not having found any other problem, do check on plastic air deflector at the top rear of the frig had been knocked off. replaced it if faulty. As you know, the deflector directs the freezer air toward the front of the frig and the rear of the cold control, which is now functioning properly.
Good luck.......
Aug 01, 2010 | Magic Chef MCBR440 Compact Refrigerator
My Magic Chef mini fridge temperature trouble
That can be very difficult to do with a mini refrigerator. There is just not enough separation between the freezer and the refrigerator.
You will likely just have to find a compromise setting and accept the results.
Oct 20, 2009 | Refrigerators
Does not get cold enough.
HI THANKS FOR YOUR QUESTION.tHE FIRST THING TO LOOK AT IS . iF YOU HAVE FROST BUILD UP ON THE WALL, OF FREEZER.#2. IS THE FAN RUNNING. #3. CLEAN ALL COILS AT THE BACK, OF FRIDGE, VERY IMPORTANT . tHANKS THE APPLIANCE DOC.
Oct 04, 2008 | Magic Chef Refrigerators
Aug 27, 2008 | Magic Chef Refrigerators
Refrigerators Logo
120 people viewed this question
Top Magic Chef Refrigerators Experts
evans_lloyd
Level 1 Expert
John Tripp
John Tripp
vince
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
