Question about Garmin nuvi 200 Car GPS Receiver
I have a garmin nuvi 200 and we lost the car charger so we brought a new car charger and it hardly charges and when its plugged in all we get is the garmin screen and there is no way we can use it when its plugged in. we have tried plugging it into the house the car and the cmp its all the same just the garmin screen shows. and its hard to go on a trip when the gps needs to be charged and you cant get the driections. How do i fix this
    Top Expert:
  • Garmin Master
  • 77,186 Answers
I think your battery has failed, you will need to send the GPS back to Garmin for a new battery, the battery is not replaceable by the consumer, it requires special tools, if u don't have them u can destry the GPS
Posted on Feb 04, 2010
My Nuvi 200 will not charge and the USB port
My condolences. I would suggest you plug the unit in to your computer's USB port using an appropriate data cable (in case you no longer have the Garmin data cable, there are lots of devices, including cameras, that use such a cable with the large USB plug at one end and the mini-USB at the other). That would give you a handle on where the fault lies -- in the auto charger cable itself vs the nuvi's socket. If the nuvi charges from your computer, you're halfway home; if not, I suspect the cost of repairing the nuvi's USB jack could exceed the cost of a replacement unit.
Mar 16, 2010 | Garmin nuvi 200W GPS Receiver
Garmin Nuvi 200 - pic if a sat nat connected to computer whenever I charge to the cig lighter? It had been fine for 6 months now recently come up. Do I need an upgrade or new charger?
I recommend the update, since it is the free alternative of these choices.
There are three steps to take to get your Nuvi running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
___________________
Nuvi 200 series manuals available here.
Feb 14, 2010 | Garmin nuvi 200W GPS Receiver
I bought my Garmin Nuvi 200 a couple of weeks ago but now it won't turn on even when I plug it into the charger. What can I do?
I can help you fix your Garmin Nuvi 200W.
Not being able to start up is a sign that the system software or firmware of your Nuvi has become corrupt.
I hope that helps.
___________________
Jan 15, 2010 | Garmin nuvi 200W GPS Receiver
Have a phone charger 12 volt that fits and charges the nuvi 200 but with it plugged in it wont show anything but a computer and nuvi on screen. unplug and it works but only for a while til needs a new...
thats because the phone charger is wired different to the gps charger , u need a genuine charger, if when pluged into pc it takes longer to charge, best to have gps turned off while charging from pc..... if it still does not work/ hold charge battery in unit gone , caused by being in active for over 3 months
Dec 29, 2009 | Garmin nuvi 200W GPS Receiver
Today i turned on my garmin after a few months, it was working will for about 2 min, then it lost satellites, so I turned it off, then tried to turn it back on, but it never turned back on. the battery...
If the GPS's internal battery is allowed to discharge too far, it will not be possible to recharge with the card charger, until it is brought up to a certain level. Connect the nuvi to a computer with USB cable overnight. This will trickle charge the internal battery to a level that will allow the car charger / cradle to keep the GPS charged from that point on. Anytime the car charger fails to recharge the internal battery, the USB charge method will have to be performed first.
Oct 21, 2009 | Garmin nuvi 200W GPS Receiver
My garmin 200w shows garmin screen then goes black even with charger plugged in
sorry . some problem with your charger .try using another charger
Sep 20, 2009 | Garmin nuvi 200W GPS Receiver
Garmin 200 won't turn on, flashes "Garmin" screen when plugged in
I connected the unit to the car charger instead of the USB charger and then held down the reset for 10-15 seconds, after which the system would show the computer connection on the charger and then boot up when not on the charger.
Aug 04, 2009 | Garmin nuvi 200W GPS Receiver
Garmin nuvi 200 pick up charger as a usb cable
The problem is very simple... The GPS unit perceives whatever you plug in depending on the power supply figure.
If you car charger is not giving enough power, then the GPS perceive the cable as being connected to a pc.... thus not charging. Check with an car electrician if you can raise the power supply on your car...
Nov 24, 2008 | Garmin nuvi 350 GPS Receiver
Nuvi 200 GPS
We did not have a charger to plug in the GPS to charge, so my husband plugged it into a battery charger. I guess the battery charger was low, so it drained the unit rather than charging it. It was so low it would not come on again. I have an electric charger that adapts the car charger into AC current, so I tried that and the unit came on. Problem solved and the GPS is working again. Thanks for responding.
Jun 20, 2008 | Garmin nuvi 200W GPS
Garmin nuvi 200 Car GPS Receiver Logo
135 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
