Question about Tomtom GO 910 GPS Receiver
Need to reset my tom tom how do I open the case
  • yadayada
    yadayada May 11, 2010
    this requires special tools.
    Champion:
  • 243 Answers
Hi, for a reset you dont have to open the case. go tomtom.com, select support, search reset, and read all possibilities. i suggest to go first for a soft reset. good luck.
Posted on Feb 24, 2010
Tom tom go 710 will not switch on
I guess that you have already made sure the battery is charged enough to power the Sat Nav.... In the back of the Tom Tom where the cradle attaches, there is a tiny hole at the top where you can insert a small object such as a sewing needle in order to press the reset button; However, you may find that like mine the hole doesn't line-up with the button and therefore you can't reset the unit unless you remove the casing. if this is the case it's best to search You Tube and watch the short video as to what exactly to do! (it's really not hard)
Hope this helps
Aug 12, 2012 | Tomtom GO 710 Car GPS Receiver
My tom tom wont turn on where is the reset bitton
look for a small hole on the outside case near the sd card reader. might need a paperclip or pin to poke the microswitch inside the hole. simply clicking the switch doesn't work, try holding it for 5 seconds then try to power up. Common problem with GPS devices, (my mio included) is after being plugged in for a long time, the battery life becomes nil and it relies upon the charger. Check tom to xl for further problem solving. google search TOM TOM XL won't power up.
Mar 14, 2010 | Tomtom XL 340S Car GPS Receiver
Tom tom one
You simply need to reset it. Download manual, and it shows you where the reset is.
http://download.tomtom.com/open/manuals/one/refman/3_EN_US/TomTomONE_manual.htm
Mar 11, 2010 | Tomtom ONE GPS Receiver
When I try to connect my tom tom 720 to my lap top a message says usb connection is not recognised
Have you tried to connect to a desk top through the USB port to isolate the laptop or GPS issue.
If you get the same problem with a desktop than I would suggest that you perform a hard reset to the GPS. This is done through the pin hole in the case labled "Reset" insert the tip of a paper clip into the reset hole and reset the device.
If this fails try reloading the GPS software, there are instructions on the Tom Tom web site
Feb 16, 2010 | Tomtom GO 720 GPS Receiver
I have brought this device 2 months back in october 2009,but now it is not catching the satellite,and not showing further route..i have tried couple of time .its not working
You're asking about a Tom Tom, right?
Try hitting Reset.
1) Find the Reset button (in a hole on the bottom of the unit). Press and hold it using a paperclip or a dull pin.
2) Turn the unit back on. Does this solve the problem?
If not, try:
Reset Factory Settings. To do this, first Show All Menu Options (this is from the Preferences menu).
Then, again from the Preferences menu, tap Reset Factory Settings.
Have you made a backup of your Tom Tom? You do this from Tom Tom Home on your home computer.
Nov 23, 2009 | Garmin KasePro GPS Leather Case Bag for ...
My tom tom is stuck on opening page. cannot do anything with it.
Most TomTom GPS have a small reset button underneath. you will need a paper clip to activate the reset button. This should start it up and clear the locked out state you described
Jul 22, 2009 | Tomtom GO GPS Receiver
Tom tom one not turning on used 3 months
I had some problems with the 920. It started to not turn on. The it just died completely. After opening the case and testing the battery. I concluded the battery was dead and Un-chargable.
Which is most likely the case with yours.
Try this first. Then contact customer support.
  1. Check that the battery is charged properly.
    Charge your device for at least 2 hours before trying to turn it on again. Make sure the charging light on your device is on.
  2. Remove the SD card
    If your device uses an SD card, remove it.
  3. Reset your device.
    Use a straightened paper clip, or something similar, to push the reset button for 15 seconds. See the pictures below for where to find the reset button.
  4. Turn your device on.
    Press the On/off button for at least 5 seconds.
  5. Insert the SD card
    If your device uses an SD card, insert the SD card
Unless you are good with electronics. Then id change the battery myself. I used a cell phone battery.
It has worked for the last year.
Regards and I hope this helped.
James
Sketchlab.com
May 28, 2009 | Tomtom ONE GPS Receiver
Tom Tom 910 Green light but does not come on.
Remove battery and disconnect from power for 5 minutes, also remove map card, this will reset the device. Try it out
click;
Repair4GPS: How to Clean, Upgrade, Repair, Mod, Disassemble a GPS ...
see here
http://www.tomtom.com/lib/doc/legal/lw/LW-English-US%20CAN.pdf
To only way you can fix it is taking apart the Tom Tom, checking if the flat ribbon cable and connector to the screen are well in place and eventually replace the display ($80 on Ebay).
Unfortunately this will invalidate the guaranty, and you risk to damage your GPS if you are not a really experienced DIYer. Tom Tom offer one year full guaranty on all their receivers.
Contact Tom Tom and get it repaired:
Support URL: http://www.tomtom.com
Support Phone Number: 978.287.9555
Support Email Address: usainfo@tomtom.com
Hope this may help;
DON'T FORGET TO RATE:
Aug 28, 2008 | Tomtom GO 910 GPS Receiver
Tom tom one battery change
I too dropped my tom tom go 300. It appears the battery was disloged as it will only work if attached to another power source; AC Adapter or cigarette plug. Does anyone know how to open the case to check on the battery?
Feb 28, 2008 | Tomtom GO 300 GPS Receiver
Fix a tomtom
Turn the tomtom on, and then press the reset button on the bottom of the unit with a paperclip. After the reset turn off the unit and then turn it back on. Make sure you have not dislodged the sd card from the unit.
Mar 19, 2007 | Tomtom ONE GPS Receiver
Tomtom GO 910 GPS Receiver Logo
309 people viewed this question
Top Tomtom GPS Experts
Martin Murray
Jon Piercy
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
