Question about Sharp FO 760 Plain Paper Thermal transfer Fax
Sharp FO610 Fax
Just connected this fax and I have no dial tone but all other phones in house show line in use. If you raise handset and manually hang up you receive engaged signal. My phone line has ASL2 but all outlets have filter. Have tried other sockets and disconnected modems to no avail
Cops
  • 64 Answers
SOURCE: Sharp UX B20 Plain Paper Fax
http://www.sharpusa.com/files/fax_man_UXB20.pdf hope this helps Cops
Posted on Oct 08, 2007
SOURCE: OUTGOING FAXES FOR SHARP UX 108 THERMAL FAX MACHINE
I need the operation manual
Posted on Jan 20, 2008
SOURCE: Error on Sharp fax UX-B700
I just came across this list of error codes (see link below). The specific ones you are referring to would probably indicate line noise, but could also be something as simple as a loose line cord. I've even seen this happen when a line cord has the retaining clip broken off so it makes and loses contact as the machine vibrates during use.
http://www.marylandcopier.com/Faxerrors.html
~Sherlockphones
Posted on Feb 13, 2009
  • 75 Answers
SOURCE: black lines printing out on sent fax
If you make a copie and the lines are on the copie then the optics's are dirty, white out, ink or fourn oblrct on glass.
If you have clean the optics and the lines are still there then the C,C,D, needs to be replaces the part that reeds the documents.
more then what the fax is worth sorry.
Posted on Feb 16, 2009
  • 408 Answers
SOURCE: sharp ux-117 roll paper fax/phone need manual
http://www.usersmanualguide.com/sharp/faxes/ux-108_178_188
Posted on Mar 06, 2009
I cannot send fax
Hi there!
For you to send a fax with the Brother Fax you can try these steps:
1. First make sure that you have a dial tone by lifting the handset or just by pressing the hook/speakerphone button. Once you have verified you have a dial tone press the hook button again to return to the main screen or hang up the handset. LCD should display the date & time
If you don't have a dial tone make sure that the telephone line cord is connected on the fax machine's Line jack. If you don't have a dial tone still, connect it to another working outlet. If you don't have a dial tone still, connect a working telephone on the wall jack to see if you'll get a dial tone. If you get a dial tone on the regular phone then problem is either with the line cord or the fax machine.
2. Once you have the date & time on the LCD screen, Load the document that you want to send on the automatic document feeder which is directly above the LCD screen.
3. The LCD screen should change from the date/time to "Enter Fax No. & Press Start" Once you got this screen dial the fax number and then press Start.
Hope this helps. Rate if it works.
Thanks!
Apr 02, 2011 | Brother IntelliFAX 2600 Fax
Fax problem
I want to make sure I understand this completely. You get no dial tone from the fax machine when hooked up to VOIP. In the past, was there an audible dial tone from the fax, or did it just dial silently and give you an error if there was no tone? When you said you got a dial tone by connecting a phone to the ext phone port of "the machine" did you mean the fax machine? If you get a dial tone by running a phone through the fax machine, then the line is good. I have used a fax machine over Sunrocket before they went defunct, which used the same technology base as Vonage - so it should work. If you used to get an audible dial tone when using the fax, and no longer do, and you are geting a dial tone on a regular phone that is connected to the ext. port of the fax machine, then the problem has to be in the fax machine itself, not the VOIP. If you can verify that, we can go from there.
Oct 08, 2007 | Brother MultiFunction Center MFC-440CN...
I have a Brother 775 intelli fax machine. I can't send a fax. After loading the document, when I go to push in the fax number, the numbers do not register. I unplugged the machine from the power and the...
Hi there!
For you to send a fax with the Brother Fax 775 you can try these steps:
1. First make sure that you have a dial tone by lifting the handset or just by pressing the hook button. Once you have verified you have a dial tone press the hook button again to return to the main screen or hang up the handset. LCD should display the date & time
If you don't have a dial tone make sure that the telephone line cord is connected on the fax machine's Line jack. If you don't have a dial tone still connect it to another working outlet. If you don't have a dial tone still connect a working telephone on the wall jack to see if you'll get a dial tone. If you get a dial tone on the regular phone then problem is either with the line cord or the fax machine.
Thanks!
Mar 30, 2011 | Brother IntelliFAX 775 Plain Paper Thermal...
Ux-p100 fax dont have a dial tone
Check your phone line by plugging a spare hanset into the wall socket (Incoming line) and listening for a dial tone on this. No dial tone - faulty line connection.
Also check you have plugged in to the correct socket on the back of your fax.
Dec 09, 2009 | Sharp UX P100 Plain Paper Thermal transfer...
Multifunction phone/fax/copier machine
Hi sythonk
1. Make sure you have a telephone cable connected the jack labelled "LINE" on your brother machine.
Go through the Menu on the LCD, Initial setup, dial tone, choose the correct dial tone PULSE or TONE.
Exit from the menu.
Pick up the handset on the fax machine, and dial your nuber to make a phone call. (To send a fax, dial the number without lifting the handset.)
Hope this will work for you. If it solved your problem, give a please rating
Cheers
luciana44
Sep 06, 2009 | Brother Office Equipment & Supplies
Hi i cant send a fax
First thing is to ensure that you have dial tone by picking up the handset on the fax machine and listening for dial tone.If there is no handset take a standard house phone and plug it into the jack where the fax machine was inserted. If there is dial tone on the phone then I would advise you to turn the power off the fax for two minutes then power back on. If there is no dial tone on the phone line contact your vendor or local phone carrier and report NO DIAL TONE
May 30, 2009 | Lexmark F4270 Plain Paper Inkjet Fax
Failing to connect with phone line...
Have u connected the handset to the side below the hand cradle. & the line coming frm the wall should be connected to the line in on the printer & not the Extn. If its connected to the line in on the back of the printer,u should get a dial tone. U can also place a paper in the scanner & then press the option under fax till u get on hook dial.. that should also give u a dial tone.
Jun 26, 2008 | Lexmark X4270 All-In-One InkJet Printer
HISSS on line; no dial-tone; no fax in or out
it sounds like you may not have any dial tone. the hiss [white noise] you are hearing is from the dsl modem.try plugging a regular corded phone into the jack to check for dial tone.if there is none,call your phone company.also try plugging the fax machine into another jack where you know there is dial tone.
good luck
wg
Feb 02, 2008 | Brother FAX-2920 Plain Paper Laser
Line error when trying to send a document
Check the line for a dial tone on the machine. Either the handset, onhook or speaker phone button. This will test if any comunictions boards have failed in the machine. If you have a dial tone the fax is ok
Next try a manual transmission. Basically make a normal phone call with for example using the handset but have your original in the fax ready to go, ring the fax number when you hear the other fax pick up you press the start button.
Don't forget the other fax may have a problem.
Jan 31, 2008 | Sharp UX-B20 Plain Paper Inkjet Fax
Can't send out fax
Make sure the phone cord is connected to fax machine in the place marked LINE, then make sure the phone cord is connected to the wall jack. Pick up your handset and make sure you have a clear dial tone also. If you are dialing long distance make sure you have the long distance service.
Nov 09, 2007 | Brother IntelliFAX 1840C Plain Paper...
Sharp FO 760 Plain Paper Thermal transfer Fax Logo
368 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
