Question about HP Pavilion Media Center m8100y PC, Intel Core 2 Duo processor E6550 2.33GHz, 4GB DDR2-667MHz dual c... PC Desktop
How do I enable the IR receiver so other programs can access it? It works fine to control the media center computer but I have other software for transferring data from my dive computer which can't access the module. My actual HP model is the m8187c media center. Thank you!!
  • Nadamamasboy Feb 07, 2010
    I did the 'DISCOVER' but it doesn't find the transceiver as it's already added to the system as 'Microsoft eHome Infrared Transceiver' . The remote control for my computer works as it should. My external device communicates with my laptop so I know it works too. When I try to use my software on my home PC, it can't communicate with my external device.
    I've gone through Windows help (Windows 7 32 bit) and found no solution.
    My irda device shows up in 'Device Manager' under 'Human Interface Devises' as a 'Microsoft eHome Infrared Transceiver' --- It also shows up under 'System Devices' as a' Consumer IR Device'
    When I right click to check properties, I'm not given any options to enable the device in either area.
    I hope this helps, thank you for your time!
    Keith
  • 641 Answers
Windows restricts this to Media Center only, figures, because windows is owned by Microsoft which is proprietary software and next to another operating system like GNU/Linux, Windows is a failure. Try running Ubuntu before you install it to the hard drive. Try it to see if your IR receiver works in the apps you want to unlock now. If you need any Ubuntu help, contact the ubuntu forums, I'm in there as well.
Posted on Feb 10, 2010
    Brigadier General:
  • 4,090 Answers
Make sure any other unit has IR enabled in its BIOS If you are using USB type IR on other units Install the software on that unit. then go to run program invoke DISCOVER. on both the sending lready have one assigned from previously) So discovery may see it anyway. you will be asked to enter some type of code use a simple one 1234 and follow any other instructions on screen.Once both units see each other exit and start transferring files. Be aware some units may use a different IR protocol and not be compatible with your master unit. Please rate my help++++Thanks for using FIXYA
Posted on Feb 07, 2010
HP TSGH-IR02 Remote Control how to install
This document pertains to HP Media Center computers with Windows XP, Media Center Edition.Use this document when the remote control does not work correctly with the Media Center software.Troubleshooting the remote controlUse the following items to troubleshoot when the remote control does not respond or when the remote control does not work properly. For example, when a key is pressed the selection moves all the way to the top or bottom of a list, or moves a selection many different places instead of the item you were trying to select.Before attempting these steps, make sure that PC has been updated with all of the latest Windows updates. Many updates for Media Center, like Update Rollup 1 for eHome Infrared Receiver, can be downloaded easily through the Windows Update software Tool.
Make sure that the batteries for the remote control are installed correctly and charged.Make sure that the front of the remote sensor is unobstructed, within a 45-degree range, and is less than 26 feet (8 meters) away. Disconnect all devices that use a USB connection except to the receiver, keyboard, and mouse. Restart the PC, and then try the remote again.If a pressed button repeats itself (sticks), unplug the IR receiver from its USB connection, wait one minute, and plug in the IR receiver. If the pressed buttons continue to repeat, alter the lighting conditions in the room or move the location of the IR receiver. Other remotes and HP Media Center PCs within range can also cause this issue.Try pressing the Enter key on the remote after changing a channel.If the remote control works when using the media center software, but does not work when changing the television channels, re-configure the Media Center software settings for the cable set-top box or satellite receiver
Point the remote control towards the IR receiver and press a button. A faint red light should appear on the IR receiver. If the light appears, then the problem is probably in the software that is using the remote control (most likely the configuration of the Media Center software). Close the software, restart the computer, and then re-open the software to solve this issue.
Troubleshooting the IR receiverThe IR receiver is the small device that receives the signals sent by the remote control. Use the following steps to test and reset the IR receiver.Disconnect the IR receiver from its USB port on the computer, maximize the Media Center window if it is open, and then reconnect the IR receiver. Test again.Point the remote control towards the IR receiver and press a button. A faint red light should appear on the IR receiver. If the light appears, then the problem is probably in the software that is using the IR receiver (most likely the Media Center software). Close the software, restart the computer, and then re-open the software to solve this issue.Click Start , right-click My Computer , and then select Properties .Click the Hardware tab and then click the Device Manager button.Click the plus sign next to Universal Serial Bus Controllers.If the eHome Infrared Receiver is listed under Universal Serial Bus controllers, Windows is properly detecting the IR receiver. If eHome Infrared Receiver is not in the list, or there is an exclamation mark or a question mark on the device, perform the following until eHome Infrared Receiver appears correct in Device manager:Unplug the end of the USB cable on the IR receiver from the computer and plug it into the same USB port.Plug the end of the USB cable on the IR receiver into the front USB port on the computer.Disconnect all other USB devices, leave the IR receiver plugged in, and then restart the computer. Plug in other USB devices after the IR receiver shows up in device manager.Figure 1: IR receiver listing in Device Manager
Testing the remote controlUse the following steps to check the responsiveness of the remote control:
  1. Open the Media Center software by double-clicking the Media Center icon the desktop or by pressing the green Start button on the remote control.
  2. Click Settings , and then click General .
  3. Click Check Your Remote , and then click Next .
  4. Press the numbers on your remote control. The corresponding numbers on the numbers on the screen should glow when each button is pressed. A faint red light should also glow inside the IR receiver each time a button on the remote pressed.
  5. Click My control is working properly , and then click Next . Do not click I am having problems with my remote control as this will not do anything.
  6. Click Finish after you are done.
Dec 17, 2011 | HP Computers & Internet
Windows XP, error message!! Media Center TV don't work now, etc.. Error message pops up all the time!!! After I loaded a RipTiger software, had to unistall but still left with this pop up message!!! Media...
Try going into Control Panel, Add/Remove Programs, click on the Media Center software, if listed, and see if it gives a choice to Change and/or Repair. You'll probably need your Windows CD if/when it prompts for it.
Oct 28, 2009 | Microsoft Windows XP Media Center Edition...
My laptop responds to tv remote
you can turn off the IR on the laptop or put black tape over it!
Sep 19, 2009 | Microsoft Windows XP Media Center Edition...
DishNetwork IR Remote Control Problem
First the only way the 6.3 will work is if it has the green number 1 on the tab facing you. Assuming this is the case you will need a new remote. This primarily is the remote for the second room away from the receiver. Thanks for using Fix Ya.
Apr 15, 2009 | DISH Network IR Remote Control
HP dv8135 notebook Remote IR receiver doesn't install HID driver
It appeared you might need to down the newer version of the driver.
HP Media Center PCs - Troubleshooting the Remote Control and the IR Sensor
http://h10025.www1.hp.com/ewfrf/wc/fastFaqLiteDocument?lc=en&dlc=en&cc=us&docname=bph07914
Mar 24, 2009 | HP Pavilion dv8135nr PC Notebook
When playing/ripping a cd the drive stops after 1 song
Open Control Panel. If you use Classic View, select Default Programs otherwise select Programs, then Default Programs. Select 'Set program access and computer defaults.' Select 'Continue' at the UAC prompt. Click on the expansion arrows on the right hand side of the 'Custom' option. Scroll down to where it says 'Choose a default media player:' Select anything except Windows Media Player' and make sure that the 'Enable access to this program' checkbox is checked, then click OK. Click on 'Set program access and computer defaults' again. Click the 'Continue' button on the UAC prompt. Click on the expansion arrows on the 'Custom' option again. Scroll down to 'Choose a default media player:' and select Windows Media Player, again ensuring that the 'Enable access to this program' checkbox is checked. Click on OK, close all open windows, and reboot the machine. This should solve the problem.
If you still have problems, let me know and I'll look for other options.
Jan 20, 2009 | Microsoft Windows Vista Home Premium with...
I can't access my router through the URL.
Linksys will not allow you to access admin on your router on a wireless adaptor by default. You will have to enable it or use a wired connection.
Is file sharing enabled on the computer you are trying to get the media files from?
Aug 21, 2008 | Linksys Wireless-G WRT54G Router
PARENTAL CONTROLS WINDOWS VISTA MEDIA CENTER
Hi, I recently wrote a program to easily crack ANY Windows Media Center Parental Control Access Code. On a fast enough computer this can be done in under a minute. The program can be downloaded at http://www.mediafire.com/file/uzfzwmmuinf/MCPC-Bruteforcer.exe -- Enjoy!
May 09, 2008 | Computers & Internet
BB + dongle(e.d)
use this drive,
http://www.team-mediaportal.com/files/Download/Drivers/Remotes/MCERemoteReplacementDriver/
Mar 05, 2008 | Televison & Video
HP Pavilion Media Center m8100y PC, Intel Core 2 Duo processor E6550 2.33GHz, 4GB DDR2-667MHz dual c...  PC Desktop Logo
52 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
