Question about AEG 23 in. Favorit 50750Vi Built-in Dishwasher
AEG Favorit dishwasher fault
Wont turn on. Plug, fuse & power OK.
  • kingslea Apr 04, 2008
    Switch on then we have to wait for up to 10 mins for indicator lights to come on. It washes fine but cannot switch off after a cycle because of timewasting delay. Not yet contacted a repairer.
Check time delay function - press til '0' appears or repeatedly til all time delaying diodes do not light
Posted on Jan 17, 2009
AEG FAVORIT DISHWASHER, PUMP KEEPS GOING WHEN TURNED OFF, UNLESS TURNED OFF AT MAINS
check the sum pump drian valve make sure it not cog up with tash because if it block can cause the drain pump to ruin ok
Nov 02, 2017 | AEG Dishwashers
How do I fix problem F3 and spray arm faulty on my KO FAVORIT 8080
F3 - The anti-flood protection system has activated.
When in operation the fault message F3 appears in multi dispay:
  • First close the water tap.
  • Pull out the power plug.
  • In the case of hard-wiring: turn off the electricity supply, remove the fuse and disconnect.
  • Check float microswitch and float of styrofoam.
  • Find and remedy water lakeage in the bottom of dishwasher.
Dado
Jan 22, 2015 | AEG Dishwashers
Dado
AEG Favorit 60870 Dishwasher not starting
Matthew, in most cases when a circuit board repeats the same action over and over, there was a short and loss of communication with associated controllers. Obviously you have power to the control unit, so that means the instructions from the controller to the solenoids is lacking. You are correct in assuming the board needs replacement, however you must determine is the cost for replacement is worth the time and effort. An old machine means one repair after the other. If its relatively new; then it may be worth it.
Mar 10, 2014 | AEG 24 in. Favorit 60870M Free-standing...
Message -spray arm blocked
Check water pump inside the machine for its full speed.If the speed is low check the capcitor and replace.
May 27, 2010 | AEG 24 in. Favorit 80860iW Built-in...
Our AEG Favorit Sensorlogic dishwasher has had no power to it
Open the lower front panel and locate where the water inlet hose is connected. Shut the water off under the sink, disconnect the hose at the water inlet solenoid, then put the loose end into a bowl or pan and turn the under-sink valve on slowly. Do you get water flowing from the hose? If so, then check the solenoid water inlet valve for damage. If the coil is ok, the valve part may be stuck closed. It should make a firm 'click' when the timer is set to start the machine (leave the hose loose). If it doesn't click, the coil may be bad, the valve may be stuck, or the timer is not sending 115 volts to the solenoid. Try a new valve first. If still no click, you may need the professional service. Good luck!
Mar 26, 2010 | AEG 23 in. Favorit 50750Vi Built-in...
AEG Favorit 665i. Lower arm does not turn
im not sure about this if the upper arm is working ok,because the lower arm gets the pressure first then sends it to the upper arm,if the water pressure to the machine is ok then the lower arm is at fault take another look at the lower arm something is not right with the lower arm.adrian;;
Jan 22, 2010 | Dishwashers
Wont heat or dry dishes
USUALLY THER IS A SENSOR ELEMENT FOR HEATING TEMPERATURE MAY BE FUALTY ..
TRY IT ..
THANK YOU
Jun 14, 2009 | AEG 24 in. Favorit 40630 Free-Standing...
Dishwasher keeps cutting out
Has the door got heavier recently?
Mine had a spring break which fell onto the electrics and shorted them. Unplug and empty it, then tip it up to see if you can see a loose spring. If it is then replace or re-fit the old spring, I have posted instructions and pictures here:
http://www.howtofixanything.co.uk/howto-260.html
Jan 24, 2009 | AEG 23 in. Favorit 50750Vi Built-in...
Aeg f88050im
Hi i just repaired mine. There was no fuse in it i found the timer control has a tranformer that goes from 240 volt or 115 volt in USA to 12 volts only the on off switch worked .
Oct 31, 2007 | AEG 24 in. Favorit 50730W Free-standing...
AEG 23 in. Favorit 50750Vi Built-in Dishwasher Logo
832 people viewed this question
Top AEG Dishwashers Experts
Oloyede Monsuru
Mike
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
