Question about Select Jazzy Used Electric Wheelchair
I have a Jazzy it has a full charge on the battery but I can't get it to move the horn works and the light comes on on the control but I can't get it to work. Has it got a on and off switch on it
Engage the motors on both sides with the lever under and near the motor!
Posted on Feb 05, 2010
Pride jazzy 1113, controller light scroll back and forth, wont move, i bought one new battery, it has full charge other battery is a little over 10 volts. is there way to test charger with volt meter?
The voltmeter should read 29 volts when on. You should never replace one battery and leave an old battery in the chair. Replace them both at the same time.
Oct 17, 2013 | Pride Jazzy 1113 Power Chair
Battery charger light doesnt work showing that the batteries are being charged.
okay first of all check that the batteries can be seen from the charger socket, otherwords get a electronic meter and insert the probes in the two outside holes , do you get a reading on DC ?
Nov 29, 2012 | Pride Mobility Jazzy Select Wheelchair -...
My battery charger for my Jazzy 600 does not light up or get warm when I plug it in. The chair has not been used for months.
I tried to charge my jazzy. The charge light (red) remained on for several hours. Finally I moved the wire slightly the charge light turned green than faded to red. What is my problem? Your solution would be greatly appreciated.
Jun 04, 2012 | Pride Jazzy Select 6 Indoor Power...
Battery fully charged chair levers engaged to drive position chair still will not move.. Jazzy 600.... Tried unlock/lock tried putting it in neutral back in drive with levers still wont move please...
Has your scooter been sitting idle for several weeks, or has it been connected to the charger 24 hours a days for a long time? If so, the batteries may have become damaged and will give you enough power to turn the controller on but not enough to make the motors run.
If the lights come on and are steady, the manual brake levers are in the drive position and the chair still will not move, I recommend replacing the batteries. If anything else were wrong, either the lights would flash or not come on at all.
I hope this information is helpful to you, good luck!
Dec 20, 2010 | Pride New Jazzy 600 Power Wheelchair by...
My chair was going along fine and then suddenly ground to a halt with just one red light constantly flashing at a steady rate. There is no drive! If you press the horn button a second light comes on but...
If the scooter was sitting unused for a long period of time, the gel inside the batteries may have gone solid and will not allow a full charge. You may need to replace the batteries due to the damaged cells. If you know the brand of controller that is on the scooter, you can look up the lights codes here:
http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Oct 08, 2010 | Pride Jazzy Select 6 Indoor Power...
When charging my jazzy, do I unplug any plugs that controls my jazzy, or leave all plugged in? the reaon ask, green light will not come on the charger, which is onboard charger, unless I unplug controller...
No JJR all the plugs need to remain plugged in. On the Pride chairs the light on the charger will only come on green when the batteries are fully charged. When you unplug the controller the charger thinks the batteries are fully charged and the light comes on. Now the problem is the batteries. If they are old or you have a bad battery then the charger never senses a full charge so no green light. Hope this helps
Aug 26, 2010 | Pride Jazzy Select 6 Indoor Power...
My Jazzy won't move.
If your batteries are truly charge they should read around 24.5 VDC. And if the freewheel lever is engaged and you still have no movement your probably need to get into a service tech. Also check the circuit breaker on the chair.
Mar 31, 2009 | Pride Jazzy 1113 ATS Indoor Power...
Select Jazzy Used Electric Wheelchair Logo
88 people viewed this question
Top Select Health & Beauty Experts
wcdoc1953
wcdoc1953
Scooter Doctor
Scooter Doctor
Colin Taylor
Are you a Select Health and Beauty Expert? Answer questions, earn points and help others
