Question about Aiwa Z-L500 Shelf System
Turntable During a recent move, the drive belt from my turntable became totally detached. I cannot figure out how to correctly re-install it. I have successfully removed the turntable and exposed the interior, but don't clearly know where to "string" the belt.
  • 104 Answers
Http://www.archive.org/details/Turntable_Belt_Installation
above is a generic video that applies to almost all belt driven turntables including yours that will show how to install the belt and a few other things.
Posted on Feb 12, 2009
JVC turntable AL-E300 turntable slowing down when tone arm moves iacross
Even if the belt looks fine it's almost certainly the problem. You mentioned "cleaning" - if you got any kind of fluid on the belt it might act as a lubricant and reduce the friction between the belt and the drive wheel, causing the turntable to slow when the tone arm puts a drag on it. The problem may go away when the belt dries out.
Nov 23, 2013 | Audio Players & Recorders
Playing records too slowly
It's likely that the belt has moved off where it should be. If the stylus was damage it would slide across the record or cause poor sound. It would not affect the speed unless there was too much pressure on the stylus, but you would feel that as the head of the arm would feel heavy.
May 24, 2013 | Crosley Conductor CR73 Turntable
Turntable out of Tune
it will be the turntable speed not exact
quality turntables have bars all around the circumference and when the speed is correct under a fluro light those bars will appear as stationary or using a strobe light set at 50 or 60 cycles a sec
bars going anticlockwise are too fast and moving forward are too slow
quality tables have a small knob or screw to adjust motor speed
Jul 27, 2017 | TDK Tvt2002 Usb Belt-drive Turntable
My KD-291RC has power but my turntable wont turn. I touch the needle and I can hear its on and when I move the arm towards the record or set it on it it will not turn. Help?
Your turntable is belt-driven, it's likely that the belt just fell off. The belt lives under the turntable. On my turntable (a totally different model) the turntable lifts off.
Apr 13, 2009 | Kenwood KD-291RC Turntable
Drive belt on Sony turntable
Usually, for most turntables, the belt goes on the bottom of the platter first. Then you put the platter back on the turntable. From here you should see an opening on the platter where you can 'grab' the belt. Pinch the belt, and then wrap it around the rotating motor's shaft. This is usually at the top left side - around the 10 o'clock position.
- OPTiC
Turntable Technician
www.1200s.com
Sep 07, 2008 | Sony PS-LX250H Turntable
I have a Sharp VZ 2500. The drive belt lies in pieces at the bottom of the player, so I can assume it needs replacing. I've bought the belt, but have no idea where it goes. Can you help?
you have to remove the front cover first. then detach the two wire connectors attached to the turntable circutry. Also detach the pushbutton pannel. remove the two screws that fix the top plastic cover inside the turtable housing. then the two big screws that fix the turntable to the main body will be visible. remove them and you can detach the turtable unit out. then remove the circuit board behind the turntable. you can then put the belt between the big disc and the motor pulley on the corner. Good luck
Aug 03, 2008 | Sharp Audio Players & Recorders
Turntable rotating slowly or not at all
First and foremost, are you sure you installed the correct replacement belt, and installed it correctly? Just ruling out the obvious. Now, if you installed the belt correctly, then the only other thing that could cause this is a bad motor. Not an expensive part, but with labor, it might be cheaper to just buy a new one. Figure the part itself is about You will more than likely be able to remove the cartridge/stylus and use it on your new turntable, just make sure the tonearm is the same style as your existing turntable - P-MOUNT Tonearm. If you buy another belt drive, you might even be able to keep the belt you purchased as a back up - might fit! Here is some part info on your turntable: - Belt - Part #SJY90080-3 - $5.99 - Motor - MOTOR, 4 VDC, .2 WATTS - Part #SDMB5E - $19.99 Labor - 30min This is just to give you an idea of what it would cost to replace the motor. I put the belt part # on there, just so you could verify that you bought the correct part. Hope this helps some. - Justin
Aug 02, 2007 | Technics SL-BD22 Turntable
Aiwa Z-L500 Shelf System Logo
896 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
