I upgraded from Windows 2000 to XP and may CreataCard Platinum 7 will not work. I tried to uninstall but it won't let me or reload the program
  • Harleen Nash May 11, 2010
    1. Have you tried going into " Add and remove programs" to remove the installed software? 2. Also check to see if the software disk has an "uninstall" feature 3. download the free program called Ccleaner and install, this program will releave the registry entry of this program. Be careful to read all the instructions before cleaning the registry with this program it will remove all and any software . check mark only those programs or temp folders that you are sure you want to remove. You can find this program by doing a Google search.
    Champion:
  • 253 Answers
Get the revo uninstaller it is free.
i hope this helps
Posted on Feb 04, 2010
I have changed my computer to Windows 7 Home premium with 64 bit operating system. I have creatacard 3 and have tried installing it on my system. however it is not compatible with this system , how can i...
Start the "Windows Compatibility Wizard", and tell it that you want to install a "Windows XP" program. Windows 7 will then read the CD, and install the program, and run it in "XP" mode.
Jun 25, 2011 | Broderbund American Greeting CreataCard...
My CreataCard Gold 7 program will not open, I get the message "AGCCard cannot determine configuration." I attempt to uninstall and reinstall the Broderbund American Greetings CreataCard Gold 7...
After uninstalling the program, go to start, Search, for files and folders and put *creatacard gold* in the search box using the asterisks on both sides. Bu sure to delete any files that are found involving creatacard gold7. Then restart your computer. It sounds like you are having a configuration problem. Is the operating system you are using listed on the configuration of the Creatacard Gold program as a operating system that this software will work on?
You could try and reinstall and if using windows, try using the the program compatability wizard found in the accessories folder in the programs folder. This might help make the program work properly. Alternatively, you may have to get a another version of creatacard gold if it does not work with your operating system. Broderbund may have a download on their site to help make your software work on you operating system. Not having any additional details about your issue, I cannot be certain.
Let me know if I can assist you furhter. Please include any details possible about the issue so I may be of assistance to you.
Brian
Jan 08, 2011 | Broderbund American Greetings Creatacard...
Compatability issue
How to install an XP/Vista program on Windows 7
First of all locate the setup or installer file, this will be either in the contents of a CD/DVD (you have to explore the contents of the CD/DVD) under the name "setup" or a downloaded .exe (executable) file.
Right click on the setup file and select "Properties" from the sub menu.
A Properties windows will appear on screen, click on the "Compatibility" tab.
At the bottom of the tab you will see the header "Privilege Level".
Check the box that says "Run this program as an administrator"
Also at the top of the Compatibility tab you will see "Run this program in compatibility mode for:"
Check that box and if you have the option select Windows XP (service pack 3).
Click Apply and then OK and install your program.
NOTE: if you have upgraded from Vista Windows XP mode may not be available depending on how you system was configured.
How to run an installed program on Windows 7
Some programs will install but they won't run on Windows 7. Again this down to compatibility but unlike Vista, Windows 7 has the compatibility mode working down to a tee.
Locate the desktop icon or the program in "All Programs" from the Start Menu or Orb as it's affectionately known today.
Just as in my tip about installing a program it is just the same.
moz-screenshot.pngmoz-screenshot-1.pngmoz-screenshot-2.pngRight click on the icon or file and select "Properties" from the sub menu.
Click apply and then OK and run the program.
NOTE: If you have upgraded from Vista Windows XP mode may not be available depending on how you system was configured.
Regards.
Jul 09, 2010 | Broderbund American Greetings Creatacard...
I have creatacard gold 4 that will not load with windows7 onto a new HP Pavilion computer. I tried the compatabiliy modes and still it will not load . the trouble shooting program says that it is...
Dear,
Your HP computer may be new, but your programs must be compatible with your operating system. If your Creatacard is older, the compatibility most likely stops with Windows Vista. Windows 7 is like a "brand new day". Read the label on your CD. It will tell you which systems it will work on. I had Windows 98 and Windows Millenium. When I upgraded to Windows XP my "create" CD's no longer worked.
Try downloading Avery cards. Be blessed.
Mar 13, 2010 | Broderbund American Greetings Creatacard...
Since upgrading to XP my CreataCard Platinum 7 will not work
Well first of all you can try to uninstall your creata card after then just reboot your system and after rebooting your system just again install the creata card........... let us know if this helps you..... please post comments for more help or information.........
Good Luck!!
Thanks
Feb 04, 2010 | Broderbund American Greetings Creatacard...
I have tried several times to uninstall creatacard select 7. I can't uninstall it. I'm desperate. Please tell me what to do.
Go to Program Files in your computer's main-drive and delete the folder for create-a-card. If that doesn't work, or it says access denied, restart windows in safe mode and try it again.
Jan 25, 2010 | Broderbund American Greetings Creatacard...
CreatACard Platinum 7 won't install on Vista Home Premium
If this is a new install from a new purchase, always give the manufacturer a call because they should know what it is compatable with and walk you thru most common problems.
Aug 23, 2009 | Broderbund American Greetings Creatacard...
Printing CreataCard Platinum 7 with Vista
if there are they will be on their website, but i'm going to say you've probably made that software useless and will have to buy a new program
Jul 25, 2009 | Broderbund American Greetings Creatacard...
Creatacard Platinmum 6 won't work with Windows Vista.
CreataCard Platinum 6 is designed to be used with Windows 95/98/2000/Me or NT 4 and XP, therefore in order to run it in Vista I'd suggest to run your program using Compatinity Mode --> Go to your Desktop --> Right click on the program icon--> Properties-->Compatibility--> select one of the versions above
Nov 12, 2008 | Broderbund American Greetings Creatacard...
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
