Question about Samsung CLX-3175FN Color Laser All-in-One Printer
My 3175 is jamming on the paper rollers each time I try to print. The paper feed through partially and then jams; with the printing done half way down the page. I have had a good look inside at the front and at the back. Is there a small bit of paper in a back recess? NR
    President:
  • 2,306 Answers
That model has a problem with the exit sensor, it gives false jam errors. It is in the upper left side above the fuser. The part number is 0604-001393 and I believe www.precisionroller.com has the part.
Posted on Feb 04, 2010
Testimonial: "This sounds great and hopefully will work if I can get the part in the Uk. NR"
Lexmark X4550 all-in-one Paper feeds only half way then jams
Frances;
I'm not Lexmark certified; however, paper motion fails are generic in nature. Paper motion fail can be a bit difficult to diagnose at a distance...
* If it jams at every sheet then check to insure there is not a bit-o-paper stuck from a previous jam.
* If it has been an issue that has been increasingly getting worse than I'd replace the pick-up roller(s)
* Lexmark's support page for your printer is below. (You can also find a service prover too)
* Parts order for your printer is also below. You can determine at the support page if your comfortable replacing pick-up rollers in that model printer.
support lexmark com Service Parts
Note:
* Frequently people tear a jammed sheet when it comes out leaving pieces behind. BAD! When you get a torn sheet in your printer insure you retrieve all the pieces. Those left behind guarantee a jam on your next try.
* Paper jams not caused by debris in the path or worn pick-up roller(s) is beyond user maintenance.
Mar 03, 2015 | Lexmark X4550 Wireless All-in-One Photo...
Paper jams on epsonXP605 expression printer
Printing photos from the back feed? Using special photo paper? Try cleaning the paper rollers that feed the paper. They get slick.
Sep 03, 2014 | Epson Expression XP- 605 Inkjet...
Paper Jam. It starts printing and stops half way through its print cycle, says paper jam, in fact their is no jam.
check if this is happening from all trays... if such clean the paper feed rollers... if still happening clean any other rollers in paper path... if still happening then you have a bad sensor that keeps tripping at the wrong time... but more than likely this is only occuring with one tray... clean your feed rollers and it should be ok... still not ok... then replace feed rollers... there is also the possibility that your fuser is shot... your can tell if your fuser is shot if... when you put your hand near it... it doesn't feel like it could burn you... if you can actually get to touch it and its cool to the touch... then you got a bad fuser...
Dec 18, 2009 | Office Equipment & Supplies
HP laserjet 4L paper jam after printing one page.
You need the pick up rollers replaced. Call your service centre to replace pick rollers as these are feeding the pages crocked
Aug 31, 2009 | HP LaserJet 4L Printer
Paper jam in Panasonic KX-
Your document feed is separate from your received and report prints so that's why your reports are printing ok and the document feeder jams. When you open up the doc feeder and look inside the machine you will see a roller and above it on the cover that opens you will see a rubber pad. Clean both the roller and pad (in fact anything in there that is rubber) with a rubber cleaner, alcohol, or even soap and water on a cloth without it been dripping wet. You will probablt find that they are very dirty. The roller feeds the document in so that needs to be clean and the pad helps to keep all the other docs from feeding in at the same time and that should be very clean so it produces good friction.
Jul 07, 2009 | Panasonic KX-FHD331 Plain Paper Thermal...
Paper pulls to the right, jams, won't print, tried different paper still won't print
Sounds like the feed rollers need cleaning.
Clean the feed rollers, lint free cloth,bottled water.
wait for them to properly dry
Revolve the feed roller bar as you clean them, to clean the feed rollers all the way round, remove all particles from them.
Check you ADF grips are set correctly, if not you will get mis-fed sheets. check the tray is sat properly too or mis-feeds.
Check paper size is correct in print properties too.
Should be good then
Try print.
Regards
Richard.
Apr 21, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Epson cx3800 paper feed problem
no you might have a paper jam somewere and mabe you ink rollers are dry you might have to tell the printer to to a pre test and clean and if there is a paper jam it should be a slot on the back by the roller should be a tap that shows the tollers look for a pice of paper jammed somewere in the roller you migh have to take the paper out to inspct it for a paper jam and if none mabe the print heads are dry and it dosent feed the paper then could be it ok clean the print heads tell the printer to to a roller clean and then after that if no paper jam no were try printing a page take all the paper out and feed it manually and if it prints then some printer want feed if you have filled the paper tray up try putting less and then try
Jan 29, 2009 | Epson Stylus CX3800 Printer
Paper doesn't feed
It could be a few things, but the times I've had similar problems it was either caused by the feed/gripper rollers in the paper trays being worn out, thus not feeding any paper or feeding half a sheet and then jamming.
Or, it could be that the elevator in your paper tray isn't lifting, but if it's taking paper it's probably the rollers.
Jan 12, 2009 | Canon Office Equipment & Supplies
Hp 4300 laserjet
Does it jam at the fuser when doing a single print?
These machines have a Maintenance kit required every 200 000 prints, these MK's include all feed rollers, a transfer roller and the entire fuser assy. To replace the kit fixes all issues I've seen in these printers besides when the cartridge affects print quality.
If it is jamming at the fuser on a single print done via the printer operations panel, and your paper is fresh, it could only be the feed roller having trouble gripping the paper or the fuser not turning/stuffed.
Feed Kit, I have my doubts as to this being your problem
Maintenance Kit Fixes 98% of the time
Was is noisy before it died?
I have seen a few with stuffed fuser drive gears but not many and customers could hear it wearing.
How many prints since last MK? via keypad print a configuration page, count is there ie pages since last maintenance xxxxxx
Jan 31, 2008 | HP LaserJet 4300n Printer
Samsung CLX-3175FN Color Laser All-in-One Printer Logo
969 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
