Question about Maytag Washing Machines
I have a maytag performa PAV2360AWW. It makes a screech on spin
I have a maytag performa PAV2360AWW. It makes a loud screeching noise in the spin cycle. When I shut the washer off, the tub stops immediately. I have turned the washer on its back, and the pully turns fine in both directions but I hear a grinding sound.What can I do? the washer is too old to spend too much money on it. I am a plumber by trade, can I fix it myself or do I need a technician. I have a service manual.
  • 3,741 Answers
If the noise is a squealing or grinding sound, you are likely looking at a bad seal and bearing.
If the noise is a knocking sound, it's more likely a suspension or out of balance condition.
check out the transmission pulley and transmission.also check the agitator shaft. Sounds like you have two problems.....one, something is restricting the flow of water.....Check the pump closely...The squealing could be coming from the pump also. Flip the machine back up against the wall and then look underneath. You will see the pump pulley. Take off the blet and turn the pulley slowly.....Is it make noise. lets make sure there isnt somthing under the agit ,, remove the dispenser off the top and take the screw loose inside the agit and pull it up off the shaft
The inside of the agitator--where the transmission shaft attaches--can become worn, and strip out the spline that allows the agitator to properly grip the shaft. Then the transmission shaft rotates back and forth as it should, but the agitator doesn't move properly. If this happens, you may need to replace the agitator and/or the transmission spline. The transmission could have either of these problems: Older washers have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may not agitate properly or at all. The transmission may have a worn or broken gear, or some other internal problem. If you suspect a transmission problem, you may have to call a qualified appliance repair technician to repair it.
You can get required parts from www.repairclinic.com
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Posted on Feb 04, 2010
My Maytag washer model MAV208DAWWmakes a loud screech at the end of the spin cycle, and the clothes are sill wet
That is the brake. Your clutch maybe wearing out. Or the belt maybe slipping because the rollers for the motor maybe wearing out.
Jan 15, 2016 | Maytag Washing Machines
Screeching noise when agitating and spinning. abrupt stop when turned off. I have a performa model # pav2300ww
you will need a tech tool from your local appliance parts distributor called a brake tool and a brake
Jan 23, 2011 | Maytag Performa PAV2200
My maytag dryer was making a loud screeching noise and then stopped spinning or heating
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
dgsghs
Feb 10, 2010 | Maytag LSG7806A Front Load Stacked Washer...
Loud screeching noise when the wash and spin cycle ends
You either have something caught between the tub and basket or a bearing bad.
Eric
Jun 29, 2009 | Maytag Washing Machines
A screeching sound during agitation cycle only.
sounds like a bad clutch. check the transmission out for ware and inspect the clutch as well. make sure the brake is not dragging as well.
May 22, 2009 | Maytag Washing Machines
Loud screeching noise when spin cycle is on
Good morning! Possibly the noise was due to improper placement of load into the spinner which should be within its capacity load. best regards.
May 02, 2009 | Washing Machines
Loud screeching noise on spin cycle
I have the same problem...during SPIN it make a LOUD SCREECHING sound.
Apr 20, 2009 | Maytag PAV2300 Top Load Washer
Maytag Performa pav2300 spins slow does not agitate
My performa 2300 makes a loud screech when it stops spinning. What is going on?
Jun 19, 2007 | Maytag PAV2300 Top Load Washer
Washing Machines Logo
307 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
